hey leute!
habe eine frage da mein pc ziemlich oft nen BsoD bekommt.
Habe die ganze hardware schon gechecked und die is kommplett in Ordunung (auch Temperaturen passen usw.
habe hier den BsoD mir WinDbg analysiert...mir sagt das aber nicht viel:
vl wisst ihr was (:
hier der Log:
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\Sebastian\Desktop\072211-16910-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.17592.amd64fre.win7sp1_gdr.110408-1631
Machine Name:
Kernel base = 0xfffff800`02a53000 PsLoadedModuleList = 0xfffff800`02c98650
Debug session time: Fri Jul 22 22:41:10.137 2011 (UTC + 2:00)
System Uptime: 0 days 0:45:27.152
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck A0, {9, ffffffffc0000001, 1, 0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : ntoskrnl.exe ( nt+7fd00 )
Followup: MachineOwner
hoffe ihr könnt mir helfen da ich echt schon am ende bin mit diesen scheiß BsoD ><
will endlich das mein system stabil läuft.
mfg h3llowner
vl wisst ihr was (:
hier der Log:
Machine Name:
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
mfg h3llowner
