R
ReLo4D
Ja hallo erstmal
Vorab "Who Crashed" & nähere Infos zur Hardware:
Hardware:
Mainboard: ASUS M5A778L-M LX3
CPU: AMD FX(tm)-4300 Quad-Core Processor (3,8 Ghz)
Netzteil: Sharkoon WPM700 Bronze
Grafikkarte: NVIDIA Geforce GTX 260
Ram: 2x Kingston 4 GB DDR3 PC3-12800 (800 MHz)
Betriebssystem: Windows 7 Professional 64 Bit
Who Crashed:
System Information (local)
computer name: RELO4D
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
Hardware: ASUSTeK Computer INC., M5A78L-M LX3
CPU: AuthenticAMD AMD FX(tm)-4300 Quad-Core Processor AMD586, level: 21
4 logical processors, active mask: 15
RAM: 8571183104 total
VM: 2147352576, free: 1909166080
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Sat 21.06.2014 23:00:58 GMT your computer crashed
crash dump file: C:\Windows\Minidump\062214-20295-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x4ADB3C)
Bugcheck code: 0x124 (0x0, 0xFFFFFA8007D6A038, 0x0, 0x0)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Sat 21.06.2014 21:41:59 GMT your computer crashed
crash dump file: C:\Windows\Minidump\062114-22105-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA8007CAD038, 0x0, 0x0)
On Wed 18.06.2014 23:43:36 GMT your computer crashed
crash dump file: C:\Windows\Minidump\061914-20779-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA8007DF3248, 0x0, 0x0)
Conclusion
12 crash dumps have been found and analyzed. Only 10 are included in this report. No offending third party drivers have been found. Connsider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you.
Beschreibung:
Ich habe mich lange gefragt, ob ich einen Thread in diesem Forum hier erstellen soll (außerdem weiß ich nicht genau, ob der Bereich richtig ausgewählt war). Nun jedoch, bin ich kurz vor dem Verzweifeln und sehe keinen anderen Ausweg mehr. Ich fange jetzt mal ganz von vorne an:
Der PC ist, bis auf die Grafikkarte, erst im Dezember 2013 zusammengebaut worden und ich hatte auch bis Anfang April ca. keine weiteren Probleme. Jedoch trat dann immer wieder ab und zu ein kleines Problem auf, unzwar startete sich der Computer immer wieder ab und zu neu. Windows gab am Anfang nur so eine Standart Fehlermeldung: "Windows wurde nach unerwartetem Herunterfahren wiederhergestellt". Bei den ersten Malen hab ich mir eigentlich auch nichts dabei gedacht, jedoch ist es immer häufiger mit der Zeit aufgetreten, sodass es mir schon seit Mai ziemlich auf die nerven geht, dass mitten im Spiel oder beim schauen eines Streams der PC einfach neustartet.
Klar hab ich auch schon in diese Richtung selbst nach Lösungen gesucht, jedoch keine für meinen Fall passende Lösung gefunden.Ich habe sowohl sämtliche Virenscans, Treiberupdates (inkl. BIOS), Defragmentierungsprogramme als auch Registry-Fixes etc. ausprobiert, ohne eine langfristige Lösung des Problems zu erzielen.
Als ich frustriert festgestellt hab, dass es nicht an softwareinternen Fehlern lag, hab ich die Hardware geprüft. Die Ram Sticks hab ich sowohl nacheinander ausgesteckt und den PC so lange laufen lassen, bis der Fehler wieder auftritt, als auch mit Memtest mehrere Stunden geprüft: Ohne Ergebnis (0 Errors). Dann habe ich die Temperaturen gecheckt, die jedoch keinesfalls auffällig waren, sie waren sogar alle im grünen Bereich (auch unter hoher GPU/CPU Auslastung), jedoch habe ich mir jetzt neue Lüfter bestellt, was aber einen anderen Grund hat. Wie auch immer, mit dem Wissen, dass es also auch nicht die Temperatur war, machte ich mich weiter auf die suche. Dann las ich in einem Forum, dass es an zu wenig bzw allgemeinen Spannungsschwankungen liegen könnte, weshalb ich mein altes Netzteil (CP 750W), worüber ich viele schlechte Kritiken gesehen hatte, gegen das Sharkoon WPM700 Bronze Netzteil austauschte. Frohenmutes dachte ich, dass das Problem gelöst sei, jedoch trat es nur einen tag später wieder auf. Dieser besagte Tag war gestern, weshalb ich nun etwas genervt bin und mir lieber Hilfe von Experten holen will.
Was ich jedoch nicht verstehe: Wieso lief der PC ~4 Monate komplett ohne Komplikationen und dann tritt so ein Fehler auf?
Ich bedanke mich schonmal im Vorraus und entschuldige mich für alle Rechtschreibfehler, die sich zu so später Stunde noch in meinem Bericht eingeschlichen haben.
LG ReLo4D
Hardware:
Who Crashed:
Conclusion
Beschreibung:
LG ReLo4D
