Mobile Footer
Bluescreens aufgrund von Arbeitsspeicherproblemen / Bugs?
Paperflyz
Juni 2022
Hallo beisammen,
ich habe dieses Forum für mich entdeckt, weil ich nun seit längerer Zeit ein gewisses Problem habe.
Mein PC bekommt hin und wieder mal einen Schluckauf. Damit meine ich, dass ich seit letzter Zeit wieder öfters Bluescreens bekomme.
Ich war etwa mal 2 Monate von diesem Problem verschont, aber nun taucht der Fehler wieder auf und heute Abend sogar schon 4x passiert.
Kurze Infos zu den Fehlermeldungen:
Crash dump file: C:\Windows\Minidump\060822-8796-01.dmp (Minidump)
Bugcheck code: 0xFC(0xFFFFF8069754554A, 0x80000007D3AC1929, 0xFFFFA604747877E0, 0x2)
Bugcheck name:ATTEMPTED_EXECUTE_OF_NOEXECUTE_MEMORY
Bug check description:This indicates that an attempt was made to execute non-executable memory.
Analysis:This particular bugcheck may be caused by malware or a security product that does not follow programming guidelines. This can also be caused by memory corruption. This is possibly a software problem. There is a possibility that this is caused by memory corruption. Memory corruption can be caused by a faulty driver, faulty RAM, overheating and more. Read this article on memory corruption. Read this article on thermal issues
Crash dump file: C:\Windows\MEMORY.DMP (Kernel memory dump)
Bugcheck code: 0xD1(0xFFFFF80300000000, 0xD, 0x8, 0xFFFFF80300000000)
Bugcheck name:DRIVER_IRQL_NOT_LESS_OR_EQUAL
Bug check description:This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
Analysis:This is a typical software problem. Most likely this is caused by a bug in a driver.
Crash dump file: C:\Windows\Minidump\060822-12796-01.dmp (Minidump)
Bugcheck code: 0x1E(0xFFFFFFFFC0000094, 0xFFFFF8038674AD5D, 0xFFFFFC8FE1BE1928, 0xFFFFFC8FE1BE1140)
Bugcheck name:KMODE_EXCEPTION_NOT_HANDLED
Driver or module in which error occurred: tcpip.sys (tcpip+0x6AD5D)
File path:C:\Windows\System32\drivers\tcpip.sys
Description: TCP/IP-Treiber
Product: Betriebssystem Microsoft® Windows®
Company: Microsoft Corporation
Bug check description:This indicates that a kernel-mode program generated an exception which the error handler did not catch.
Analysis:This could be caused by either a software or hardware problem.
Hardware failure is often caused by overheating. Read this article on thermal issues
The crash took place in a Microsoft module. Possibly this problem was caused by another driver on your system that cannot be identified at this time.
Ich lese hier sehr oft Memory und teilweise stürzen meine Spiele ab mit einer Fehlermeldung welche auf den temporären Speicher hinweist.
Folgende sind meine System-Infos:
Driver Easy TXT Report
Binaries
Driver Easy version v5.7.2
Overview
Machine Gigabyte Technology Co., Ltd. - X570 AORUS ELITE
Operating System Microsoft Windows 11 Pro (64-bit)
Memory 32 GB
Processor AMD Ryzen 7 3700X 8-Core Processor
Motherboard Gigabyte Technology Co., Ltd. - X570 AORUS ELITE
Video Cards NVIDIA GeForce RTX 3070
Monitors ASUS PB277
Hard Disk Micron_M600_MTFDDAY256MBF (256,0 GB)
Network Card Intel(R) I211 Gigabit Network Connection
CPU
Processor
Name AMD Ryzen 7
Code Name Matisse
TDP --
Package --
Technology 7 nm
Core Voltage 1,38 V
Specification AMD Ryzen 7 3700X 8-Core Processor
Family 15
Model --
Stepping --
Ext. Family --
Ext. Model --
Revision --
Instructions MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, NX, VMX, AES, AVX, AVX2, FMA3
Clocks
Core Speed 4216,5 MHz
Multiplier x 42,25
Bus Speed 99,8 MHz
QPILink --
Cache
L1 Data 8 x 32 KBytes
L1 Inst 8 x 32 KBytes
Level 2 8 x 512 KBytes
Level3 2 x 16384 KBytes
Motherboard
Motherboard
Manufacturer Gigabyte Technology Co., Ltd.
Model X570 AORUS ELITE Default string
Chipset AMD Ryzen SOC
Revision 00
Southbrige AMD Carrizo FCH
Revision 51
LPCIO --
BIOS
Core Speed American Megatrends International, LLC.
Version F36e
Date 10/14/2021
Graphic Interface
Version --
Transfer Rate --
Max. Supported --
Memory
General
Type DDR4
Size 32768 MBytes
Channel# --
DC Model --
NB Frequency --
Timings
DRAM Frequency 1796,4 MHz
FSB:DRAM --
CAS# Latency(CL) 16 clocks
RAS# to CAS# Delay(tRCD) 19 clocks
RAS# Precharge(tRP) 19 clocks
Cycle Time(rRAS) 39 clocks
Bank Cycle Time(tRC) --
Command Rate(CR) 1 clocks
Graphics
GPU
Name NVIDIA GeForce RTX 3070
Code Name --
Technology --
Revision --
Clocks
Core --
Shader --
Memory --
Memory
Size 8192 MBytes
Type 14
Bus Width --
Den Dump habe ich aus dem Programm "Driver - Easy" auf dem ich bereits sämtliche Treiber für meinen PC aktualisiert habe.
So langsam verzweifle ich wirklich an der Problemursache und glaube nur noch dass es etwa ein Problem in der BIOS Einstellung ist (für die MHZ Frequenz) oder letztendlich ein Hardwareproblem was ich nicht hoffe.
Ich würde mir sehr freuen, wenn mir jemand bei diesem Problem helfen könnte :-)
Vielen Dank vorab!
Viele Grüße
und die Hardware ist unbekannt ?
nutz bitte CPU-Z damit kannst dann wenigstens genau sagen was für ein RAM ... denn in das was du da schreibst steht nicht viel.
da steht nicht mal ob es 2 oder 4 riegel sind z.b.
Ich vermute der RAM steht nicht in der Memory QVL vom Mainboard und ist deswegen sozusagen inkompatibel.
:heilig:
:heilig:
Das ist Quatsch
Es werden außerdem niemals alle möglichen Arbeitsspeichermodelle getestet
Reaktionen: Bonanca, MehlstaubtheCat, schiz0 und eine weitere Person
Huch, ich habe nicht mit so schnellen und vor allem vielen Antworten gleich gerechnet :-)
Danke erstmal dafür!
Sorry, klar. :-)
Chipset
Northbridge AMD Ryzen SOC rev. 00
Southbridge AMD X570 rev. 51
Bus Specification PCI-Express 4.0 (16.0 GT/s)
Graphic Interface PCI-Express 4.0
PCI-E Link Width x16 (max 16x)
PCI-E Link Speed 16.0 GT/s (max 16.0 GT/s)
Memory Type DDR4
Memory Size 32 GBytes
Channels Dual
Memory Frequency 1796.4 MHz (3:54)
CAS# latency (CL) 16.0
RAS# to CAS# delay (tRCD) 19
RAS# Precharge (tRP) 19
Cycle Time (tRAS) 39
Bank Cycle Time (tRC) 85
Command Rate (CR) 1T
Uncore Frequency 1796.4 MHz
Memory SPD
DIMM # 1
SMBus address 0x52
Memory type DDR4
Module format UDIMM
Module Manufacturer(ID) G.Skill (7F7F7F7FCD000000000000000000)
SDRAM Manufacturer (ID) SK Hynix (AD00000000000000000000000000)
Size 16384 MBytes
Max bandwidth DDR4-2133 (1066 MHz)
Part number F4-3600C16-16GTZNC
Nominal Voltage 1.20 Volts
EPP no
XMP yes, rev. 2.0
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 10.0-11-11-25-35 @ 733 MHz
JEDEC #2 11.0-11-11-27-38 @ 800 MHz
JEDEC #3 12.0-12-12-29-41 @ 866 MHz
JEDEC #4 13.0-13-13-31-44 @ 933 MHz
JEDEC #5 14.0-15-15-35-49 @ 1033 MHz
JEDEC #6 15.0-15-15-36-50 @ 1066 MHz
JEDEC #7 16.0-15-15-36-50 @ 1066 MHz
XMP profile XMP-3602
Specification DDR4-3602
VDD Voltage 1.350 Volts
Min Cycle time 0.555 ns (1801 MHz)
Max CL 16.0
Min tRP 10.45 ns
Min tRCD 10.45 ns
Min tRAS 21.56 ns
Min tRC 32.06 ns
Min tRRD 2.03 ns
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 16.0-19-19-39-58-n.a @ 1801 MHz (1.350 Volts)
DIMM # 2
SMBus address 0x53
Memory type DDR4
Module format UDIMM
Size 16384 MBytes
EPP no
XMP yes, rev. 2.0
AMP no
Max CL 16.0
Min tRP 10.45 ns
Min tRCD 10.45 ns
Min tRAS 21.56 ns
Min tRC 32.06 ns
Min tRRD 2.03 ns
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 23 10 0C 02 85 21 00 08 00 40 00 03 09 03 00 00
10 00 00 08 0C F8 03 00 00 6E 6E 6E 11 08 76 F0 0A
20 20 08 00 05 00 A8 1E 2B 2E 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 15 2B 16 36
40 0B 2B 0C 36 00 00 36 15 2B 0C 2C 16 2B 0C 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 83 B5 CE 00 00 00 00 00 C2 AF 7E
80 11 11 21 01 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 74 DF
100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140 04 CD 00 00 00 00 00 00 00 46 34 2D 33 36 30 30
150 43 31 36 2D 31 36 47 54 5A 4E 43 00 00 00 80 AD
160 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8E CF
180 0C 4A 05 20 00 00 00 00 00 A3 00 00 05 00 02 00
190 00 47 54 54 10 AD 01 F0 0A 20 08 00 05 00 C0 11
1A0 27 00 00 00 00 00 00 00 00 E6 A0 BE D2 D2 FA BA
1B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0 01 02 01 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM # 2
SPD registers
Falls noch etwas fehlt, bitte bescheid geben!
Viele Grüße
Drewkev schrieb:
In welchen Slots steckt der RAM? Geh vielleicht mal auf 3200MHz runter bzw. erhöhe ganz leicht die DRAM Voltage.
Slot 2 + 4.
Passt leider auch nicht in 1 rein, da hier der Lüfter blockiert.
Ich hatte mich bei der MHz an die XMP (? Heißt das so) orientiert, wo er sich automatisch an die jeweilige RAM-Einstellung anpasst.
Oh je - komme ich doch nicht an BIOS Einstellungen vorbei, wobei ich da so ungern rumtüftel .. ^^
Warum gibt es hier wieder keine konkreten Hardware Angaben (Mainboard)?
Drewkev schrieb:
@Paperflyz
Hast du das XMP-Profil geladen oder nur die 3600MHz eingestellt?
Ja der ist aktiviert und geladen.
Sorry, ich habe mir einen Kompletten CPU-Z Dump gezogen, der ist so riesig, dass ich das Mainboard nicht gefunden bzw. inkludiert habe.
Mainboard Model X570 AORUS ELITE (0x00000431 - 0x1ECE59E8)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8688
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8688
LPCIO Revision ID 0x1
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
20 86 88 01 00 00 20 33 20 00 00 80 00 C8 58 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 0A 40 0A 30 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0A40
Hardware Monitors
Hardware monitor ITE IT8688
Voltage 0 1.38 Volts [0x73] (CPU VCORE)
Voltage 2 12.31 Volts [0xAB] (+12V)
Voltage 3 4.98 Volts [0xA6] (+5V)
Voltage 5 0.91 Volts [0x4C] (CPU V)
Voltage 6 1.37 Volts [0x72] (DRAM)
Voltage 7 3.34 Volts [0x8B] (+3.3V)
Voltage 8 3.14 Volts [0x83] (VBAT)
Temperature 0 34 degC (93 degF) [0x22] (System 1)
Temperature 1 36 degC (96 degF) [0x24] (PCH)
Temperature 2 55 degC (131 degF) [0x37] (CPU)
Temperature 3 37 degC (98 degF) [0x25] (PCIEX16_1)
Temperature 4 43 degC (109 degF) [0x2B] (VRM)
Fan 0 1083 RPM [0x26F] (CPU)
Fan 1 560 RPM [0x4B6] (FANIN1)
Fan 2 485 RPM [0x570] (FANIN2)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 13 10 00 80 DF FF 00 20 FF 98 48 00 30 64 B8 70
10 FF FF FF 77 C0 D0 C0 C0 02 04 05 FF FF FF 13 13
20 73 A9 AB A7 5C 4C 72 8B 83 22 24 37 25 2B 31 80
30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00
40 7F 7F 7F 7F 7F 7F 5F 40 AD 6A D4 00 00 00 00 00
50 FF 18 7F 7F 7F 40 00 00 90 00 1C 12 65 00 00 00
60 00 14 41 46 1C 01 00 00 00 14 3C 46 1C 01 00 FF
70 00 14 3C 46 1C 01 00 2E 31 32 5A 2A 0F 01 00 E8
80 FF FF FF FF FF FF FF FF 00 00 00 00 00 C7 00 E1
90 00 00 00 00 FF 10 10 10 42 99 00 00 01 4A F2 37
A0 00 14 41 46 1C 01 00 D0 7F 7F 96 80 00 00 0F 98
B0 FE 20 7E 79 7F 7F 7F 7F 5A F0 3C 3C 3C 3C 3C 3C
C0 00 C0 00 48 0C 01 10 FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 01
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor NVIDIA NVAPI
Clock Speed 0 1050.00 MHz [0x41A] (Graphics)
Clock Speed 1 7000.98 MHz [0x1B58] (Memory)
Clock Speed 2 n.a. (Processor)
Falls es das ist?
