Benutzer Name
- Aug. 2019
I've installed a couple mods for the first time and saw on two of them the note "DO NOT extract the contents of the BSA file into your Data folder as loose files, or let your mod manager perform an equivalent function on the contents of the file. Doing so will cause things to load in the wrong order and break the game. Skyrim is intended to load a BSA alongside it's ESM/ESP file. Circumventing this causes issues which I will not provide support for. If you insist on going against this advice, you will receive no support for the problems you generate as a result of this. " and am a bit confused.
Should I move the .zip folders to the Skyrim SE Mods folder without unzipping?
Ups, kurz vergessen dass das hier ein deutsches Forum ist 🙈
