rumpel01
Fleet Admiral
- März 2006
Hallo zusammen!
Mit dem aktuellsten Beta-Treiber für die Creative X-fi (mit Ausnahme der Audio) und die Audigy-Familie (2.18.0000) sind nun in der Creative Audio-Konsole die Optionen für den integrierten Dolby Digital/DTS-Decoder unter Microsoft Vista wieder offiziell verfügbar.
Auch das Abspielen von DVD-Audio-Medien ist nun ebenfalls wieder möglich.
Einziger Wermuts-Tropfen: X-Fi CMSS®-3D funktioniert nicht unter Vista 64 Bit, aber evtl. wird das ja noch behoben.
*Quelle*
This download is a beta driver providing Microsoft® Windows Vista® and Windows® XP support for Creative Sound Blaster® X-Fi™ series of audio devices. For more details, read the rest of this web release note.
Take note of the following:
* THIS IS AN UNSUPPORTED BETA DRIVER. There is no technical support for this driver.
* We recommend that only experienced users install this driver. Do not install this driver on a system used to perform critical tasks.
* Users who are looking for stable drivers should wait for the final release. When this happens, user should install the latest Sound Blaster X-Fi series driver available.
This download supports the following audio devices only:
* Creative Sound Blaster X-Fi XtremeGamer Fatal1ty® Professional Series
* Creative Sound Blaster X-Fi Platinum Fatal1ty Champion Series
* Creative Sound Blaster X-Fi XtremeMusic
* Creative Sound Blaster X-Fi Fatal1ty
* Creative Sound Blaster X-Fi Elite Pro
Added Features:
To find out if your audio device supports the following features in Windows XP, click here.
For systems using Windows Vista
* Dolby® Digital and DTS® driver decode re-established for sound cards that included decoding in their Windows XP drivers (Not applicable for products that included a 3rd party software DVD player license in the package).
* DVD-Audio playback re-established for sound cards that included the application in their Windows XP software suite (For Windows Vista 32-bit only).
Requires the latest Creative MediaSource DVD-Audio Player Beta software. Click here to download.
Fixes:
* Resolves issues of intermittent and random application/system crash when playing games or running applications that use EAX®, DirectSound®, OpenAL and/or ASIO features.
* Resolves issue of volume mapping leading to very soft volume level in systems using Windows Vista with Service Pack 1.
* Resolves issue with distortion and noise occuring in systems with 4 GB of RAM or greater.
Known Issues:
* X-Fi CMSS®-3D feature is not available in Windows Vista 64-bit.
Requirements:
* Windows Vista 64-bit, Windows Vista 32-bit, Windows XP Professional x64 Edition, Windows XP Service Pack 2 (SP2), Windows XP Media Center Edition (MCE) 2005 or Window XP MCE 2004
* Creative Sound Blaster X-Fi audio devices listed above
Notes:
* Do not install this driver for Sound Blaster X-Fi Xtreme Audio.
* To install this driver
1. Download the file onto your local hard disk.
2. Double-click the downloaded file.
3. Follow the instructions on the screen.
*Quelle*
