Is das so alles richtig??
CPU Info
CPU 1/1
AMD Athlon(tm) 64 Processor 3000+
Manufacturer AMD
Family AMD Athlon(tm) 64 Processor 3000+
Architecture 64-bit
Internal Clock 1.9 GHz Is das richtig??
Internal Clock Maximum 3.0 GHz
External Clock 200.0 MHz
Socket Designation Socket 939
HyperThreadingTechnology N/A
Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE, SSE2, PAE, NX
Version AMD Athlon(tm) 64 Processor 3000+
Caches
Level 1 128 KB
Level 2 512 KB
DirectX Info
Version 9.0c
Long Version 4.09.00.0904
DirectDraw
Version 5.03.2600.5512
Primary Device ATI Radeon HD 3800 Series
Display Device 1/1
ATI Radeon HD 3800 Series Driver 6.14.10.6925
Description ATI Radeon HD 3800 Series
Manufacturer ATI Technologies Inc.
Total Local Video Memory 512 MB
Total Local Texture Memory 512 MB
Total AGP Memory 0 B
Driver File ati2dvag.dll
Driver Version 6.14.10.6925
Driver Details 8.591-090225a-076825C-ATI
Driver Date 2-25-2009
Driver WHQL Certified true
Max Texture Width 8192 px
Max Texture Height 8192 px
Max User Clipping Planes 6
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Fixed Function Textures In Single Pass 8
Vertex Shader Version 3.0
Pixel Shader Version 3.0
Max Vertex Blend Matrices 0
Max Texture Coordinates 8
VGA Memory Clock 832.5 MHz
VGA Core Clock 675.0 MHz
PCI
Name ATI Radeon HD 3800 Series
Vendor ID 0x1002
Device ID 0x9505
SubSystem ID 0x95051002
Revision ID 0x0000
Texture Formats
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
8-bit A [8]
8-bit YUV [800]
16-bit AYUV [8800]
8-bit AYUV [4400]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
Capabilities
Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures, Two Sided Stencil Test, Mipmapped Volume Textures, Mipmapped Cube Textures, Texture Border Color, Spherical Mapping, Automatic Mipmap Generation, Hardware Rasterization, Shading, Transform and Lighting, Scissor Test, Legacy Depth Bias
DirectShow
Version 9.0c
Registered DirectShow Filters
.RAM file Parser
AC3 Parser Filter
ACELP.net Sipro Lab Audio Decoder
ACM Wrapper
ASF ACM Handler
ASF DIB Handler
ASF DJPEG Handler
ASF ICM Handler
ASF JPEG Handler
ASF URL Handler
ASF embedded stuff Handler
ASX file Parser
ASX v.2 file Parser
ATI MPEG Video Decoder
ATI Media Center Audio Encoder
ATI Media Center Multiplexer
ATI Media Center Video Encoder
ATI Time Shift Reader
ATI Time Shift Splitter
ATI VCR Stream Source
AVI Decompressor
AVI Draw
AVI Splitter
AVI/WAV File Source
Color Space Converter
DV Muxer
DV Splitter
DV Video Decoder
Decrypt/Tag
Default DirectSound Device
Default MidiOut Device
DivX for Blizzard Decoder Filter
File Source (Async.)
File Source (Netshow URL)
File Source (URL)
File stream renderer
Internal Script Command Renderer
Line 21 Decoder
Line 21 Decoder 2
Lyric Parser
MIDI Parser
MJPEG Decompressor
MPEG Audio Decoder
MPEG Layer-3 Decoder
MPEG Video Decoder
MPEG-2 Demultiplexer
MPEG-2 Sections and Tables
MPEG-2 Splitter
MPEG-I Stream Splitter
Microsoft MPEG-4 Video Decompressor
Microsoft Screen Video Decompressor
Multi-file Parser
NSC file Parser
Nero DVD Decoder
Nero Digital Audio Decoder
Nero Video Decoder
NeroDigital Parser
Overlay Mixer2
QT Decompressor
QuickTime Movie Parser
SAMI (CC) Parser
VBI Surface Allocator
VGA 16 Color Ditherer
Video Port Manager
Video Renderer
WM ASF Reader
WM ASF Writer
WST Decoder
Wave Parser
Windows Media Audio Decoder
Windows Media Multiplexer
Windows Media Pad VU Data Grabber
Windows Media Update Filter
Windows Media Video Decoder
Windows Media source filter
XML Playlist
DirectSound
Version 5.3.2600.5512
Speaker Configuration Quadraphonic
Primary Device Realtek AC97 Audio
Sound Device 1/1
Realtek AC'97 Audio Driver 5.10.0.5870
Description Realtek AC97 Audio
Manufacturer Realtek
Driver File ALCXWDM.SYS
Driver Version 5.10.0.5870
Driver Date 6-20-2005
Max Supported 3D Hardware Sounds 26
HD Audio Support false
EAX Support Supported
PCI
Name Realtek AC'97 Audio
Vendor ID 0x10de
Device ID 0x00ea
SubSystem ID 0x75851462
Revision ID 0x00a1
Capabilities
Continuous Rate, Primary Buffer with 16-bit Samples, Primary Buffers with 8-bit Samples, Monophonic Primary Buffers, Stereo Primary Buffers, Hardware-mixed Secondary Buffers with 16-bit Samples, Hardware-mixed Secondary Buffers with 8-bit Samples, Hardware-mixed Monophonic Secondary Buffers, Hardware-mixed Stereo Secondary Buffers
Memory Info
Total Physical Memory 2.00 GB
Free Physical Memory 1.61 GB
Total Pagefile Memory 3.85 GB
Free Pagefile Memory 3.52 GB
Warum zeigt er hier die Ram nich an??
Memory Array 1/1
Max Module Capacity 16 MB
Location System Board
Use System
Supported Speeds
Supported Types
Supported Voltages
Memory Slot 1/4
Installed Enabled Size 0 B
Form Factor DIMM
Frequency 0.0 Hz
Slot A0 [Bank0/1]
Type Details
Enabled Size 0 B
Total Bit Width 64 b
Data Bit Width 64 b
Memory Slot 2/4
Form Factor DIMM
Frequency 0.0 Hz
Slot A1 [Bank2/3]
Type Details
Enabled Size 0 B
Data Bit Width 64 b
Memory Slot 3/4
Form Factor DIMM
Frequency 0.0 Hz
Slot A2 [Bank4/5]
Type Details
Enabled Size 0 B
Data Bit Width 64 b
Memory Slot 4/4
Form Factor DIMM
Frequency 0.0 Hz
Slot A3 [Bank6/7]
Type Details
Enabled Size 0 B
Data Bit Width 64 b
Motherboard Info
Supported Slot Types ISA, PCI, AGP
Model MS-7025
BIOS Vendor Phoenix Technologies, LTD
BIOS Version 6.00 PG
BIOS Release Date 02/17/2005
BIOS Properties Plug and Play, Flash, AGP
AGP
Available Rate 0x00000000
Selected Rate 0x00000000
Aperture Size 0 B
Sideband Addressing
Fast Write
Card Slots
Slot 1/6 (PCI)
Order 1
Designation PCI0
Type PCI
Characteristics 5.0V, PME Signal
Data Bus Width 32 b
Details Available, Long
IRQ 0
Slot 2/6 (PCI)
Order 2
Designation PCI1
Type PCI
Data Bus Width 32 b
IRQ 0
Slot 3/6 (PCI)
Order 3
Designation PCI2
Type PCI
Data Bus Width 32 b
IRQ 0
Slot 4/6 (PCI)
Order 4
Designation PCI3
Type PCI
Data Bus Width 32 b
IRQ 0
Slot 5/6 (PCI)
Order 5
Designation PCI4
Type PCI
Data Bus Width 32 b
IRQ 0
Slot 6/6 (AGP)
Order 0
Designation AGP
Type AGP
Data Bus Width 32 b
IRQ 0
System Devices
Name PCI Standard-Host-CPU-Brcke
Manufacturer (Standardsystemgerte)
Name PCI Standard-ISA-Brcke
Name PCI Standard-PCI-zu-PCI-Brcke
USB Devices
Description USB-Root-Hub
Driver Date 7-1-2001
Driver Version 5.1.2600.1106
Device Class Universal Serial Bus Controller
Description USB-Verbundgert
Driver Version 5.1.2600.0
Description USB-HID (Human Interface Device)
Driver Version 5.1.2600.5512
Device Class Human Interface Device
Description Standard-USB-Hub
Description USB-Massenspeichergert
Description NETGEAR RangeMax(TM) Wireless USB 2.0 Adapter WPN111
Driver Date 9-26-2005
Driver Version 1.5.0.2102
Device Class Network Adapter
FireWire Devices
Description 1394-Netzwerkadapter
Driver Version 5.1.2535.0
Monitor Info
Monitor 1/1
Name Medion MD30699PU L10
Manufacturer Medion AG
Max Width 1280 px
Max Height 1024 px
Operating System Info
Operating System Microsoft Windows XP
Version 5.1.2600
Service Pack Service Pack 3
Windows Environment 32-bit
Locale DE
Desktop Width 1152 px
Desktop Height 864 px
Desktop BPP 32 b
DEP
Hardware Support true
Applications Protected true
Drivers Protected true
User Option On for essential Windows programs and services only
Und meine Catalyst center ( Ati Readion Hd 3850 512MB AGP)
sagt das meine aktuelle agp geschwindigkeit = 0 ist?? Woran liegt das??
CPU Info
CPU 1/1
Manufacturer AMD
Architecture 64-bit
Caches
Level 1 128 KB
Level 2 512 KB
DirectX Info
Version 9.0c
DirectDraw
Display Device 1/1
PCI
Vendor ID 0x1002
Device ID 0x9505
Revision ID 0x0000
Texture Formats
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
8-bit A [8]
8-bit YUV [800]
16-bit AYUV [8800]
8-bit AYUV [4400]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
Capabilities
DirectShow
Version 9.0c
.RAM file Parser
AC3 Parser Filter
ACM Wrapper
ASF ACM Handler
ASF DIB Handler
ASF DJPEG Handler
ASF ICM Handler
ASF JPEG Handler
ASF URL Handler
ASX file Parser
ASX v.2 file Parser
AVI Decompressor
AVI Draw
AVI Splitter
AVI/WAV File Source
DV Muxer
DV Splitter
DV Video Decoder
Decrypt/Tag
File Source (URL)
Line 21 Decoder
Line 21 Decoder 2
Lyric Parser
MIDI Parser
MJPEG Decompressor
MPEG Audio Decoder
MPEG Video Decoder
MPEG-2 Splitter
Multi-file Parser
NSC file Parser
Nero DVD Decoder
Nero Video Decoder
NeroDigital Parser
Overlay Mixer2
QT Decompressor
SAMI (CC) Parser
Video Port Manager
Video Renderer
WM ASF Reader
WM ASF Writer
WST Decoder
Wave Parser
XML Playlist
DirectSound
Sound Device 1/1
PCI
Vendor ID 0x10de
Device ID 0x00ea
Revision ID 0x00a1
Capabilities
Memory Info
Memory Array 1/1
Use System
Supported Speeds
Supported Types
Supported Voltages
Memory Slot 1/4
Form Factor DIMM
Frequency 0.0 Hz
Slot A0 [Bank0/1]
Type Details
Enabled Size 0 B
Data Bit Width 64 b
Memory Slot 2/4
Form Factor DIMM
Frequency 0.0 Hz
Slot A1 [Bank2/3]
Type Details
Enabled Size 0 B
Data Bit Width 64 b
Memory Slot 3/4
Form Factor DIMM
Frequency 0.0 Hz
Slot A2 [Bank4/5]
Type Details
Enabled Size 0 B
Data Bit Width 64 b
Memory Slot 4/4
Form Factor DIMM
Frequency 0.0 Hz
Slot A3 [Bank6/7]
Type Details
Enabled Size 0 B
Data Bit Width 64 b
Motherboard Info
Model MS-7025
AGP
Aperture Size 0 B
Sideband Addressing
Fast Write
Card Slots
Slot 1/6 (PCI)
Order 1
Designation PCI0
Type PCI
Data Bus Width 32 b
IRQ 0
Slot 2/6 (PCI)
Order 2
Designation PCI1
Type PCI
Data Bus Width 32 b
IRQ 0
Slot 3/6 (PCI)
Order 3
Designation PCI2
Type PCI
Data Bus Width 32 b
IRQ 0
Slot 4/6 (PCI)
Order 4
Designation PCI3
Type PCI
Data Bus Width 32 b
IRQ 0
Slot 5/6 (PCI)
Order 5
Designation PCI4
Type PCI
Data Bus Width 32 b
IRQ 0
Slot 6/6 (AGP)
Order 0
Designation AGP
Type AGP
Data Bus Width 32 b
IRQ 0
System Devices
USB Devices
FireWire Devices
Monitor Info
Monitor 1/1
Max Width 1280 px
Max Height 1024 px
Version 5.1.2600
Locale DE
Desktop BPP 32 b
DEP
