Re: Kernel Updaten: Intaliren wie?
Michael schrieb:
Was für eine Netzwerkkarte ist denn in deinem System?
Zyxel GN650-T Gigabit Ethernet PCI-Adapter, 10/100/1000. Ich hab mir auch den Linux Treiberdowngeloadet und komme hier bei Punkt 4: nicht weiter:
Soll übrigens ab Kernel 2.4.1 für ALLLE Linux Systeme laufen hier wieder einaml die Treiber readme:
Bitte Beachten Punkt 4 und 5 danke euer FlippyDaShady
ZyXEL GN600 series 1000Base-T Adapter
** Linux Driver
** v1.11 Dec, 2003
Introduction:
The instructions listed below are for linux driver installation. You must
compile the source code to generate the module and use insmod command to
insert it.
Contents of the Subdirectory:
linux.txt This file.
velocity_main.h The linux core driver header file
velocity_main.c The linux core driver source code file
Makefile Makefile for generating driver object file
velocity_vmns.c The vmns driver support source file
velocity_vmns.h The vmns driver support header file
velocity_cfg.h The driver configuration header file
vmns_drv.h The vmns driver support header file
velocity_mac.h The definitions of MAC regiseters
velocity_wol.h The WOL magic packet hearder file
velocity_wol.c The WOL magic pacekt source file
velocity_mii.h The header file on definitions of MII registers
velocity_dbg.h The kenerl log header file
velocity_desc.h The definitions of MAC descriptors
velocity_proc.h The header to for proc entries
velocity_proc.c The source to create proc entries
velocity_stats.h The definitons of MAC Hardware counters
velocity.h The extended driver header file
Installation
Please enter the following commands at the UNIX prompt. Remember, UNIX is
case sensitive.
1) Create a temporary directory:
mkdir /temp
2) Change to the temporary directory:
cd /temp
2) Copy driver (.tgz file) from DOS disk, (mcopy below is one tool in
mtools, if you didn't install mtools, you can type
'mount -t msdos /dev/fd0 /mnt' and use 'cp /mnt/velocityget.tgz /temp'
command to copy the driver to the temporary directory):
mcopy a:velocityget.tgz .
3) untar the archive file:
tar xzvf velocityget.tgz
cd velocityget
4) Compile the driver source files and it will generate object file, and
copy it to correct driver installation path (The installation directory
is different in different kernel versions. In 2.4.x kernel, the path is
/lib/modules/KERNEL_VERSION/kernel/drivers/net/, and in 2.2.x kernel,
the path is /lib/modules/KERNEL_VERSION/net/, the KERNEL_VERSION (see
above) means the kernel version of your Linux distribution. If you don't
know your kernel version , please run 'uname -r' command in command
line. The kernel version will look like '2.2.16', '2.4.2-2smp' etc.) :
make install
5) Check configuration file (/etc/modules.conf or /etc/conf.modules,it
depend on your Linux distribution) for loading kernel modules. Make sure
there is the following content in the configuration file, where # is
interface number (eg: alias eth0 velocityget):
alias eth# velocityget
6) Reboot now:
shutdown -r now
7) Install your driver module (If the driver module is in the wrong place,
an error message will appear, and say that can't find the driver
module):
insmod velocityget
8) Use ifconfig command to assign the IP address, where # is network
interface number:
ifconfig eth# <IP>
9) Check the interface works:
ping <remote_host_IP>
