Es gibt seit heute neue Beta Treiber (2.08.0002) von Creative mit OpenAL-Unterstützung.
Diesmal werden zusätzlich auch noch die alten Audigy 1-Karten unterstützt (mit Ausnahme von Audigy LS, Audigy SE und Audigy Value).
http://files.europe.creative.com/ma...88/0x9B1818DE/SBA2_PCDrvBeta_LB_2_08_0002.exe
"Creative Sound Blaster Audigy unified series Beta driver with OpenAL support 2.08.0002 SBA2-BETAD-W1-LB
This beta driver is recommended for gamers who want full OpenAL™ support for their audio devices. Only the following audio devices are supported:
* Creative Sound Blaster Audigy® series, Sound Blaster Audigy Platinum series, Sound Blaster Audigy Platinum eX series
* Creative Sound Blaster® Audigy 2 series including Sound Blaster Platinum, Sound Blaster Platinum eX and Sound Blaster Value
* Creative Sound Blaster Audigy 2 ZS series including Sound Blaster Platinum and Sound Blaster Platinum Pro
* Creative Sound Blaster Audigy 4 series
* Creative Sound Blaster Audigy 2 ZS Notebook series
Added Features or Enhancements:
* Provides full OpenAL / EAX® ADVANCED HD support
* Improves performance of all OpenAL game titles
Requirements:
* Microsoft® Windows® XP Service Pack 2 or Windows 2000 Service Pack 4
* Audio devices listed above only
Notes:
* THIS IS AN UNSUPPORTED BETA DRIVER. We recommend that only experienced users install this driver.
* Make sure you uninstall the existing drivers for the audio devices listed above.
* To uninstall the existing drivers:
1. Click Start -> Settings -> Control Panel.
2. Double-click the Add/Remove Programs icon. The Add/Remove Programs Properties dialog box appears.
3. Click the Install/Uninstall tab.
4. Select the driver for your audio device and then click the Add/Remove button.
* Do not install this driver for the Creative Sound Blaster Audigy LS, Sound Blaster Audigy SE or Sound Blaster Audigy Value audio device.
* Some Creative applications such as Surround Mixer, THX Console, and Creative MediaSource™ may not work properly with this beta driver."
Requirements:
Notes:
