Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Summary Dump File: Only kernel address space is available
Symbol search path is: SRV*C:\symbols*
http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (6 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02e0f000 PsLoadedModuleList = 0xfffff800`0304ce50
Debug session time: Sun Feb 6 21:16:29.412 2011 (UTC + 1:00)
System Uptime: 0 days 0:41:18.724
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 000007ff`fffdf018). Type ".hh dbgerr001" for details
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 3B, {c0000005, fffff88004b2c817, fffff8800869b900, 0}
*** ERROR: Module load completed but symbols could not be loaded for atikmdag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
Page 122262 not present in the dump file. Type ".hh dbgerr004" for details
Probably caused by : atikmdag.sys ( atikmdag+90817 )
Followup: MachineOwner
3: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff88004b2c817, Address of the instruction which caused the bugcheck
Arg3: fffff8800869b900, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in 0x%08lx verweist auf Speicher 0x%08lx. Der Vorgang %s konnte nicht im Speicher durchgef hrt werden.
FAULTING_IP:
atikmdag+90817
fffff880`04b2c817 8b4820 mov ecx,dword ptr [rax+20h]
CONTEXT: fffff8800869b900 -- (.cxr 0xfffff8800869b900)
rax=0000000000000000 rbx=fffffa800555f5e0 rcx=fffffa8007214630
rdx=0000000000000000 rsi=0000000000000015 rdi=fffffa8005677010
rip=fffff88004b2c817 rsp=fffff8800869c2d0 rbp=fffffa8007214630
r8=0000000000000015 r9=fffff88004eee970 r10=0000000000000000
r11=fffff8800869c420 r12=0000000000000000 r13=fffffa8007ba6d00
r14=0000000000000001 r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010246
atikmdag+0x90817:
fffff880`04b2c817 8b4820 mov ecx,dword ptr [rax+20h] ds:002b:00000000`00000020=????????
Resetting default scope
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x3B
PROCESS_NAME: dwm.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff88004e2521f to fffff88004b2c817
STACK_TEXT:
fffff880`0869c2d0 fffff880`04e2521f : fffffa80`0555f5e0 fffff880`0869c420 fffffa80`05377000 00000000`00000000 : atikmdag+0x90817
fffff880`0869c300 fffff880`04e254a0 : 00000000`00000001 0000000f`00870000 fffffa80`05377000 00000000`00000000 : atikmdag+0x38921f
fffff880`0869c390 fffff880`043b75b2 : fffff8a0`0e0a2d00 00000000`00000000 00000000`c0000001 fffff8a0`00e72070 : atikmdag+0x3894a0
fffff880`0869c3d0 fffff880`052ae3fd : fffffa80`072a0000 00000000`00000001 fffff880`0869c6e0 fffff8a0`0182c010 : atikmpag+0x75b2
fffff880`0869c670 fffff880`052d8b71 : fffffa80`072a0000 fffffa80`072a0000 00000000`00000001 fffff800`02e841fa : dxgkrnl!DXGADAPTER:
diSetVidPnSourceAddress+0x79
fffff880`0869c6b0 fffff880`05304da4 : 00000000`00000001 fffff8a0`01e7b000 00000000`00000000 fffff8a0`01e7b000 : dxgkrnl!DXGADAPTER::UpdateModeWithPrimary+0x12d
fffff880`0869c930 fffff880`053040d8 : fffff8a0`01e7b000 fffff8a0`01e7b000 fffff880`00000001 00000000`00000001 : dxgkrnl!DXGDEVICE::SetDisplayMode+0x4ec
fffff880`0869cad0 fffff960`0022bb74 : 00000000`023bf218 fffffa80`ffffeee6 00000000`00000000 00000000`00000001 : dxgkrnl!DxgkSetDisplayMode+0xad4
fffff880`0869cbf0 fffff800`02e7e993 : fffffa80`07b97060 fffff880`0869cca0 00000000`00000000 00000000`00000020 : win32k!NtGdiDdDDISetDisplayMode+0x14
fffff880`0869cc20 000007fe`ffd9849a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`023bf1e8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7fe`ffd9849a
FOLLOWUP_IP:
atikmdag+90817
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: atikmdag+90817
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: atikmdag
IMAGE_NAME: atikmdag.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4cef1f94
STACK_COMMAND: .cxr 0xfffff8800869b900 ; kb
FAILURE_BUCKET_ID: X64_0x3B_atikmdag+90817
