Ram voltage
Miki2303
Nov. 2022
set dram voltage to normal and i cant now turn on pc , nothing happened i cant bios open
Help
clear cmos than try again. check wiring of your computer and all connectors. check if powersupply is correctly attached
What is cmos i dont know
I must cmos clear and then turn on pc without cmos?
CMOS= clear BIOS ... Setting to Default
I clear this and pc turn on now
dount change ram voltages until you know what ya do ..
now you know how to reset it ... than you can change RAM settings and retest it.
but you should normaly load XMP and it runs at desinged Speed and Voltage.
