Mobile Footer Layer
Script zum VHD-Mounten
Clocker 2800+
Apr. 2007
ich suche ein kleines Script (bat, vbs, etc..) mit dem ich einfach per Doppelklick eine vhd-Datei mounten kann.
Quasi wie wenn man es über die Computerverwaltung/Datenträgerverwaltung macht.
Nur dauert mir das jedesmal zu lange. :(
Vielleicht kennt irgendwer was?
Wie wäre es mit dem hier?
Code:
@ECHO OFF
REM - This will be the file that I use for scripting
SET temporaryFileName=%temp%\VHDBatchTempFile_%random%.txt
REM - Parse the first parameter and go to the right lication
IF %1==mount GOTO:mount
IF %1==readOnlyMount GOTO:readOnlyMount
IF %1==dismount GOTO:dismount
IF %1==compact GOTO:compact
IF %1==install GOTO:install
IF %1==uninstall GOTO:uninstall
REM - Give a helpful error message if no parameter is recognized
GOTO:error
REM - Mounting a virtual hard disk
:mount
ECHO select vdisk file=%2 > %temporaryFileName%
ECHO attach vdisk >> %temporaryFileName%
diskpart /s %temporaryFileName%
del %temporaryFileName%
GOTO:EOF
REM - Mounting a virtual hard disk (read only)
:readOnlyMount
ECHO attach vdisk readonly >> %temporaryFileName%
GOTO:EOF
REM - Dismounting a virtual hard disk
:dismount
ECHO detach vdisk >> %temporaryFileName%
GOTO:EOF
REM - Compacting a virtual hard disk
:compact
ECHO compact vdisk >> %temporaryFileName%
GOTO:EOF
REM - Put registry keys in place
:install
SET temporaryFileName=%temporaryFileName:txt=reg%
SET batchFileName=%~f0
SET batchFileName=%batchFileName:\=\\%
ECHO Windows Registry Editor Version 5.00 > %temporaryFileName%
ECHO. >> %temporaryFileName%
ECHO [HKEY_CLASSES_ROOT\.vhd] >> %temporaryFileName%
ECHO @="Windows.VirtualPC.HD" >> %temporaryFileName%
ECHO [HKEY_CLASSES_ROOT\.vhd\ShellEx] >> %temporaryFileName%
ECHO [HKEY_CLASSES_ROOT\.vhd\ShellEx\ContextMenuHandlers] >> %temporaryFileName%
ECHO [HKEY_CLASSES_ROOT\Windows.VirtualPC.HD] >> %temporaryFileName%
ECHO @="Virtual Machine Hard Drive Image" >> %temporaryFileName%
ECHO [HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\ShellEx] >> %temporaryFileName%
ECHO [HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\ShellEx\ContextMenuHandlers] >> %temporaryFileName%
ECHO [HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\Shell] >> %temporaryFileName%
ECHO [HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\Shell\Open2] >> %temporaryFileName%
ECHO @="M&ount VHD" >> %temporaryFileName%
ECHO [HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\Shell\Open2\Command] >> %temporaryFileName%
ECHO @="CMD /S /C  \"\"%batchFileName%\" mount \"%%1\"\"" >> %temporaryFileName%
ECHO [HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\Shell\Open3] >> %temporaryFileName%
ECHO @="D&ismount VHD" >> %temporaryFileName%
ECHO [HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\Shell\Open3\Command] >> %temporaryFileName%
ECHO @="CMD /S /C  \"\"%batchFileName%\" dismount \"%%1\"\"" >> %temporaryFileName%
ECHO [HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\Shell\Open] >> %temporaryFileName%
ECHO @="Mount &VHD (Read Only)" >> %temporaryFileName%
ECHO [HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\Shell\Open\Command] >> %temporaryFileName%
ECHO @="CMD /S /C  \"\"%batchFileName%\" readOnlyMount \"%%1\"\"" >> %temporaryFileName%
ECHO [HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\Shell\Open4] >> %temporaryFileName%
ECHO @="Com&pact VHD" >> %temporaryFileName%
ECHO [HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\Shell\Open4\Command] >> %temporaryFileName%
ECHO @="CMD /S /C  \"\"%batchFileName%\" compact \"%%1\"\"" >> %temporaryFileName%
regedit /s %temporaryFileName%
ECHO.
ECHO Windows VHD integration installed.
ECHO Run "%~f0 uninstall" to uninstall windows VHD integration if desired.
ECHO.
GOTO:EOF
REM - Remove registry keys
:uninstall
ECHO [-HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\Shell] >> %temporaryFileName%
ECHO [-HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\Shell\Open] >> %temporaryFileName%
ECHO [-HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\Shell\Open\Command] >> %temporaryFileName%
ECHO [-HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\Shell\Open2] >> %temporaryFileName%
ECHO [-HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\Shell\Open2\Command] >> %temporaryFileName%
ECHO [-HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\Shell\Open3] >> %temporaryFileName%
ECHO [-HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\Shell\Open3\Command] >> %temporaryFileName%
ECHO [-HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\Shell\Open4] >> %temporaryFileName%
ECHO [-HKEY_CLASSES_ROOT\Windows.VirtualPC.HD\Shell\Open4\Command] >> %temporaryFileName%
ECHO.
ECHO Windows VHD integration uninstalled.
ECHO Run "%~f0 install" to install windows VHD integration if desired.
ECHO.
GOTO:EOF
REM - Helpful error message
:error
ECHO.
ECHO VHD Batch file.
ECHO.
ECHO Usage:
ECHO.
ECHO %~n0 install
ECHO.
ECHO This command will allow you to right click on a virtual hard disk
ECHO and select and action to perform without manually running this
ECHO batch file.  Make sure you do not move or delete the batch file
ECHO after running this command without first running "uninstall".
ECHO.
ECHO %~n0 uninstall
ECHO.
ECHO Removes all information from the system about this batch file.
ECHO.
ECHO %~n0 mount "full path and name for a virtual hard disk"
ECHO.
ECHO will use DISKPART to mount the virtual hard disk specified. Note
ECHO that you need to provide the full path and name for the virtual
ECHO hard disk, and that you should not mount a virtual hard disk that
ECHO has differencing disks, undo disks or snapshot files associated
ECHO with it.
ECHO.
ECHO %~n0 readOnlyMount "full path and name for a virtual hard disk"
ECHO.
ECHO will use DISKPART to mount the virtual hard disk specified. In
ECHO read only mode.  This is always safe to do. Note that you need to
ECHO provide the full path and name for the virtual hard disk.
ECHO.
ECHO %~n0 dismount "full path and name for a virtual hard disk"
ECHO.
ECHO hard disk.
ECHO.
ECHO %~n0 compact "full path and name for a virtual hard disk"
ECHO.
ECHO will use DISKPART to compact the virtual hard disk specified. Note
ECHO hard disk, and that you should not compact a virtual hard disk that
ECHO with it.  You should also not compact a virtual hard disk that is
ECHO currently mounted.
oder das hier.
*Cheers
In welches BS soll die VHD gemountet werden ?
