Sensors - CPU Temperatur
heinzler
Sep. 2005
ich habe ein K9N4 Ultra-F (MSI) Mainboard und einem AMD Athlon 64 X2 4400+ (65Watt TDP).
Ich habe sensors installiert und dieses Zeigt mir sehr merkwürdige Werte an:
user@linux:~$ sensors
k8temp-pci-00c3
Adapter: PCI adapter
Core0 Temp:
+26°C
Core0 Temp:
+8°C
Core1 Temp:
+22°C
Core1 Temp:
+8°C
w83627ehf-isa-0a10
Adapter: ISA adapter
VCore: +1.14 V (min = +0.00 V, max = +1.74 V)
in1: +12.25 V (min = +13.46 V, max = +13.46 V) ALARM
AVCC: +3.22 V (min = +4.08 V, max = +2.67 V) ALARM
3VCC: +3.22 V (min = +1.78 V, max = +2.51 V) ALARM
in4: +2.04 V (min = +1.98 V, max = +1.88 V) ALARM
in5: +1.46 V (min = +1.02 V, max = +1.00 V) ALARM
in6: +4.71 V (min = +4.33 V, max = +5.71 V)
VSB: +3.20 V (min = +1.86 V, max = +3.95 V)
VBAT: +2.98 V (min = +1.90 V, max = +4.08 V)
in9: +1.50 V (min = +1.82 V, max = +2.04 V) ALARM
Case Fan: 0 RPM (min = 753 RPM, div = 128) ALARM
CPU Fan: 1035 RPM (min = 883 RPM, div = 8)
Aux Fan: 0 RPM (min = 811 RPM, div = 128) ALARM
fan5: 0 RPM (min = 0 RPM, div = 8)
Sys Temp: +46°C (high = +46°C, hyst = -67°C) ALARM
CPU Temp: +59.0°C (high = +80.0°C, hyst = +75.0°C)
AUX Temp: +48.0°C (high = +80.0°C, hyst = +75.0°C)
Was bedeuten diese CPU Werte ganz oben? Warum gibt es für Core0/1 jeweils 2 Werte und warum ist der 2. Werte unter 10 Grad?
Welcher CPU-Wert gilt nun? Ganz unten (über AUX) steht nämlich +59.0°C ....
Noch was ganz merkwürdiges:
Unter Burn sieht dieses Bild so aus:
@linux:~$ sensors
k8temp-pci-00c3
Core0 Temp:
+41°C
Core0 Temp:
+33°C
Core1 Temp:
+38°C
Core1 Temp:
+36°C
w83627ehf-isa-0a10
VCore: +1.28 V (min = +0.00 V, max = +1.74 V)
in1: +12.14 V (min = +13.46 V, max = +13.46 V) ALARM
in5: +1.45 V (min = +1.02 V, max = +1.00 V) ALARM
in6: +4.68 V (min = +4.33 V, max = +5.71 V)
VBAT: +2.96 V (min = +1.90 V, max = +4.08 V)
in9: +1.49 V (min = +1.82 V, max = +2.04 V) ALARM
CPU Fan: 2445 RPM (min = 883 RPM, div = 8)
CPU Temp: +78.0°C (high = +80.0°C, hyst = +75.0°C)
AUX Temp: +51.0°C (high = +80.0°C, hyst = +75.0°C)
Was hier besonders auffällt:
Die Werte oben liegen viel weiter beinander, sind aber immer noch realtiv niedrig. Ganz unten habe ich +78.0°C
Was stimmt denn da nun?
vielen dank für die hilfe,
gruß,
heinzler
PS: Ich frage das hauptsächlich, da wir noch einen identischen PC haben. Dieser springt bei last auf über 100 Grad und das macht Probleme. Seltsamderweise springt die Temperatur auch in sekundenschnelle herum (Beispiel: Vollast: 90 Grad, eine Sekunde später ohne Last schon 60 Grad)????
Das ist bei manchen Cpu´s normal !!!
Bei meinem Amd zeigt der auch manchmal 90 grad an.
Bei manchen Cpus spinnen die sensoren.
Solange dein pc nicht einfriert bzw. abstürzt ist alles noch ok.
Ich würde aber trotzdem mal die temp. im auge behalten.
Das ist eben das Problem, dieser Problem schaltet sich bei last dann selber aus???
Kühler ist ordentlich montiert und läuft auch auf vollgas ...
hast du das Problem gelöst? Hab das gleiche Phänomen mit meinem X2 5200+, der ist plötzlich auch übel heiss, ca. 80°C und dann schaltet sich der Pc einfach komplett aus.
Benutz doch mal ein anderes Programm zum auslesen der Temperaturen!!!
CoreTemp oder Everest
