ati3duag Reboot
elan-eo-akin
Feb. 2008
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except,
it must be protected by a Probe. Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: c2b51e20, memory referenced.
Arg2: 00000000, value 0 = read operation, 1 = write operation.
Arg3: bf268200, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 00000000, (reserved)
Debugging Details:
Could not read faulting driver name
READ_ADDRESS: c2b51e20
FAULTING_IP:
ati3duag!Block::InsertAfter+10
bf268200 8b00 mov eax,dword ptr [eax]
MM_INTERNAL_CODE: 0
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0x50
PROCESS_NAME: firefox.exe
LAST_CONTROL_TRANSFER: from e2c2f010 to bf268200
STACK_TEXT:
a9813a28 e2c2f010 e1239404 e2c2f4f8 e2ebc4b8 ati3duag!Block::InsertAfter+0x10
WARNING: Frame IP not in any known module. Following frames may be wrong.
00000000 00000000 00000000 00000000 00000000 0xe2c2f010
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: ati3duag!Block::InsertAfter+10
FOLLOWUP_NAME: MachineOwner
MODULE_NAME:
IMAGE_NAME: ati3duag.dll
DEBUG_FLR_IMAGE_TIMESTAMP: 4907c324
FAILURE_BUCKET_ID: 0x50_ati3duag!Block::InsertAfter+10
Followup: MachineOwner
was bedeutet das?
