TeamViewer Motive 3
Bluescreen bei Counter Strike GO Start. Mit Minidump.
SimonK91
März 2012
Hallo Forum,
beim Starten von CS:GO stürzt mein PC ab, hatte bisher einen Bluescreen und einen Freeze mit Neustart. Die Minidumps sagen zwei verschiedene Dinge:
Code:
On Wed 29.01.2014 13:51:11 GMT your computer crashed
crash dump file: C:\Windows\Minidump\012914-9172-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x4ADB3C)
Bugcheck code: 0x124 (0x0, 0xFFFFFA8003F2F8F8, 0x0, 0x0)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Wed 29.01.2014 13:46:03 GMT your computer crashed
crash dump file: C:\Windows\Minidump\012914-9157-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x75BC0)
Bugcheck code: 0x101 (0x19, 0x0, 0xFFFFF88002F64180, 0x2)
Error: CLOCK_WATCHDOG_TIMEOUT
Bug check description: This indicates that an expected clock interrupt on a secondary processor, in a multi-processor system, was not received within the allocated interval.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might be caused by a thermal issue.
Alle Treiber sind auf dem neusten Stand, PC ist nicht übertaktet, Prime95 ist stabil, Temps sind ok, andere Games keine Probleme. AMD FX-8150, Windows 7 x64, HD 6870.
Irgendeine Idee? Danke!
Sieht nachm Speicherfehler aus. Mal die Module einzeln testen oder mal eine andere Bank verwenden.
Folgende Schritte kannst du machen:
1. RAM mit MemTest86+ Testen
2. Alle Treiber (inkl. Grafik, BIOS, etc....) auf neuste Version aktualisieren
3. Festplatte testen mittels CristalDiskInfo
Hast du irgendetwas verändert seitdem du den BlueScreen bekommst?
Viele Grüße
Dennis
