QX9650 problem!
Status
Na so in dieser Form zB.
>CPU Feature:
Thermal Management Control.......... - Disabled
PPM(EIST) Mode...................... - Disabled
Limit CPUID MaxVal.................. - Disabled
CIE Function........................ - Disabled
Execute Disable Bit................. - Enabled
Virtualization Technology........... - Enabled
Core Multi-Processing............... - Enabled
>DRAM Timing:
Enhance Data transmitting........... - Fast
Enhance Addressing.................. - Fast
T2 Dispatch......................... - Disabled
>Clock Setting Fine Delay Press Enter:
DLL And RCOMP Settings.............. - Manual
Ch1 Dram Defaul Skew................ - Model 1
Ch2 Dram Defaul Skew................ - Model 1
RCOMP Settings...................... - Model 1
Fine Delay Step Degree.............. - 70ps
Ch1 Clock Crossing Setting.......... - Agressive
DIMM1 Clock Fine Delay.............. - Current[1346ps]
DIMM2 Clock Fine Delay.............. - Current[1346ps]
Ch1 Control0 Fine Delay............. - Current[166ps]
Ch1 Control1 Fine Delay............. - Current[166ps]
Ch1 Control2 Fine Delay............. - Current[124ps]
Ch1 Control3 Fine Delay............. - Current[110ps]
Ch1 Command Fine Delay.............. - Current[262ps]
Ch2 Clock Crossing Setting.......... - Agressive
DIMM3 Clock Fine Delay.............. - Current[1346s]
DIMM4 Clock Fine Delay.............. - Current[1346ps]
Ch2 Control0 Fine Delay............. - Current[14ps]
Ch2 Control1 Fine Delay............. - Current[56ps]
Ch2 Control2 Fine Delay............. - Current[0ps]
Ch2 Control3 Fine Delay............. - Current[0ps]
Ch2 Command Fine Delay.............. - Current[110ps]
Ch1 Ch2 Common Clock Setting........ - Auto
Ch1 RDCAS GNT-Chip Delay............ - Auto
Ch1 WRCAS GNT-Chip Delay............ - Auto
Ch1 Command To CS Delay............. - Auto
Ch2 RDCAS GNT-Chip Delay............ - Auto
Ch2 WRCAS GNT-Chip Delay............ - Auto
Ch2 Command To CS Delay............. - Auto
Flex Memory Mode..................... - Auto
Common CMD to CS Timing.............. - 2N
CAS Latency Time (tCL)............... - 7
RAS# to CAS# Delay (tRCD)............ - 8
RAS# Precharge (tRP)................. - 8
Precharge Delay (tRAS)............... - 22
All Precharge to Act................. - Auto
REF to ACT Delay (tRFC).............. - Auto
Performance Level.................... - 8
>Read delay phase adjust Press Enter:
Channel 1 Phase 0 Pull-In........... - Auto
Channel 1 Phase 1 Pull-In........... - Auto
Channel 1 Phase 2 Pull-In........... - Auto
Channel 1 Phase 3 Pull-In........... - Auto
Channel 1 Phase 4 Pull-In........... - Auto
Channel 2 Phase 0 Pull-In........... - Auto
Channel 2 Phase 1 Pull-In........... - Auto
Channel 2 Phase 2 Pull-In........... - Auto
Channel 2 Phase 3 Pull-In........... - Auto
Channel 2 Phase 4 Pull-In........... - Auto
Write to PRE Delay (tWR)............ - Auto
Rank Write to Read (tWTR)........... - Auto
ACT to ACT Delay (tRRD)............. -Auto
Read to Write Delay (tRDWR)......... - Auto
Ranks Write to Write (tWRWR)........ - Auto
Ranks Read to Read (tRDRD).......... - Auto
Ranks Write to Read (tWRRD)......... - Auto
ALL PRE to Refresh.................. - Auto
>Voltage Settings:
CPU VID Control..................... - 1.25V
CPU VID Special Add................. - Disabled
CPU VID Special Add................. - 113.22%
DRAM Voltage Control................ - 1.87v
SB Core/CPU PLL Voltage............. - 1.75v
NB Core Voltage..................... - 1.55v (1.47v actual)
CPU VTT Voltage..................... - 1.58v
Vcore Droop Control................. - Disabled
Clockgen Voltage Control............ - 3.45v
GTL+ Buffer Strength................ - Strong
CPU GTL 0 REF Volt.................. - 0.6725
CPU GTL 2 REF Volt.................. - 0.6725
CPU GTL 1 REF Volt.................. - 0.6725
CPU GTL 3 REF Volt.................. - 0.6725
North Bridge GTL 0 REF Volt......... - 0.6750
North Bridge GTL 1 REF Volt......... - 0.6750
FSB Vref............................ - Auto
Genie BIOS Settings:
Exist Setup Shutdown................ - Mode 2
Exist Shutdown After AC loss........ - Enabled
AC Shutdown Free.................... - Enabled
O.C Clock Fail Retry Counter........ - 1
O.C Clock Fail CMOS Reloaded........ - Disabled
CPU Clock Ratio..................... - 9
Target CPU Clock.................... - 3800 MHz
CPU Clock........................... - 482
Boot Up Clock....................... - Auto
CPU Clock Amplitude................. - 900mV
CPU Clock0 Skew..................... - 100ps
CPU Clock1 Skew..................... - 100ps
DRAM Speed.......................... - 400/1066
Target DRAM Speed................... - 1284MHz
PCIE Clock.......................... - 101mhz
Ich denke mal TrD ist bei dir das Performance Level, dass solltest du erstmal auf 10 stellen.
Prüfe das mit Everest und Mainboad und dort Chipsatz, schau was du da jetzt bei Performance Level stehen hast, dann schau ob es auch das übernimmt was du einstellst.
PS: ich denke Heute werde ich nichts mehr schreiben, ich ruhe mich wieder aus.
Ich habe auch kein ASUS, natürlich steht bei Chipsatz Performance Level.
In deinem Bild eins ;)
Ich habs dir rot markiert :rolleyes:
MFG
Ich habs vor 3 Seiten schon gewußt was das hier wird :freaky:
Ich glaub ich lass das hier mal sein, El_Mariachi999 sollte das mit dem OC auch lieber lassen.
Oder sich die ganzen FAQ durchlesen und den beginnerthread durchforsten.
In der Zeit hüte ich gern den QX.
tja halt ja wohl intels marktstrategie wider erfolg gehabt.
Dem kunden wird weis gemacht er bekommt eine super cpu der bestens zum Übertackten geeignet ist und nen freien Multi hat was aber in unsere FSB Region völlig schwanz ist.
Die meistens CPU kosten nur nen bruchteil und gehen deutlich beser.
Tut mir leid aber aber mit dem verkauf wirst du eien dickes minus einfahren.
mfg
Also ich würd ihn nicht verkaufen ;) er sollte doch erstmal @Stock gehen bzw. ausreichen .
In der Zeit liest du dich durch diverse Themen spezifisch des OC und versuchst es dann Schritt für Schritt ,
Wenn es dann wieder nix wird kannst du , mit vorhandenen Wissen, hier nochmal anfragen .
Ich bin mir sicher das dir dann geholfen werden kann da ja dann ein Grundwissen vorhanden ist ;)
MFG
Ich verstehe auch nicht, warum Du ihn verkaufen willst. Da würde ich noch eher mit Standard-FSB und Multi-Erhöhung auf meinetwegen 3,5Ghz gehen. Dann hast Du zwar den FSB-Flaschenhals, aber immer noch besser als nichts bzw. wahrscheinlich mind. 600€ in den Sand zu setzen :freak:.
Und wofür die 4GHz? Was machst Du v.a. mit der CPU?
Und für das Vorhaben 4GHz bei einem quadcore empfehle ich gleich eine WaKü.....
Der QX wird es schon machen @4Ghz allerdings solltest du dich vorher mit der Materie auseinandersetzen ;)
Es nützt dir herzlichst wenig wenn du davon eben nicht alzu viel verstehst , deswegen leg ich es dir ans Herz verkauf ihn nicht lies dich ein und versuch es erneut .
Ich hätte gerne solche eine CPU doch leider fehlt es mir am Geld , das sollte dir auch weh tun mal eben 500€ zu vernichten ;) nur weil du nicht gleich den Erfolg siehst , welcher nur am können scheitert .
MFG
Also selbst ein Q9550 erfordert die selber vorgehensweise.
Selbst ich bekomme meinen über 3,8Ghz nur gehe ich dann über 90°C in ein paar tagen habe ich vieleicht nen Q9550.
Im Januar werde ich dann einen Q9550S mir noch holen denke ich.
Und wenn du schon mit dem QX nicht klar kommst, wirst du mit einem Q9550 erst recht nicht weiter kommen, du brauchst FSB475 dazu braucht man ein spitzen Board und muss mit den GTLs umgehen können.
Öhm wenn du das mit dem QX nicht hinbekommst, dann erst recht nicht mit einem Q9550.
Der QX ist am leichtesten zu übertakten und ist pille palle den auf 4GHz zu bekommen.
ja aber dank dem E0 stepping ist das auch simple
ich hatte mein Q9550 C1 stepping schon auf 3,6 also sind die 4ghz kein thema
Status
