Z68 MoBo & i7 2600k aber LucidVirtu und Hydra nicht supported?
kleriker lv14
Banned
Sep. 2008
mein System besteht grob aufgezählt aus.
i7 2600k, MSI Z68GD80B3, 16GB G.Skill1866MHZ
Auszüge aus'm cpuz-Log habe ich hier. falls nötig komplett als Anhang!
Code:
Binaries
CPU-Z version			1.54
Processors
Number of processors		1
Number of threads		8
APICs
Processor 0
	-- Core 0
		-- Thread 0	0
		-- Thread 1	1
	-- Core 1
		-- Thread 0	2
		-- Thread 1	3
	-- Core 2
		-- Thread 0	4
		-- Thread 1	5
	-- Core 3
		-- Thread 0	6
		-- Thread 1	7
Processors Information
Processor 1			ID = 0
	Number of cores		4 (max 8)
	Number of threads	8 (max 16)
	Name			Intel Sandy Bridge
	Codename
	Specification		Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
	Package (platform ID)	 (0x1)
	CPUID			6.A.7
	Extended CPUID		6.2A
	Core Stepping
	Technology		32 nm
	Core Speed		3392.3 MHz
	Multiplier x FSB	34.0 x 99.8 MHz
	Stock frequency		-34 MHz
	Instructions sets	MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
	L1 Data cache		4 x 32 KBytes, 8-way set associative, 64-byte line size
	L1 Instruction cache	4 x 32 KBytes, 8-way set associative, 64-byte line size
	L2 cache		4 x 256 KBytes, 8-way set associative, 64-byte line size
	L3 cache		8 MBytes, 16-way set associative, 64-byte line size
	FID/VID Control		yes
	Turbo Mode		supported, enabled
	Max non-turbo ratio	34x
	Max turbo ratio		38x
	Max efficiency ratio	16x
Chipset
Northbridge			Intel ID0100 rev. 09
Southbridge			Intel ID1C44 rev. 05
Graphic Interface		PCI-Express
PCI-E Link Width		x16
PCI-E Max Link Width		x16
Memory Type
Memory Size			16352 MBytes
Memory SPD
Monitoring
Mainboard Model		Z68A-GD80 (MS-7672) (0x0000043D - 0x2D219469)
DMI Processor
	manufacturer		Intel
	model			Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
	clock speed		1600.0 MHz
	FSB speed		100.0 MHz
	multiplier		16.0x
Graphics
Number of adapters		1
Graphic APIs
API				NVIDIA NVAPI
API				NVIDIA I/O
Graphics I2C
Display Adapters
Display adapter 0
	Manuf. API index	0
	Display name		\\.\DISPLAY1
	Name			NVIDIA GeForce GTX 570
	Revision		A1
	Memory size		1280 MB
	PCI device		bus 1 (0x1), device 0 (0x0), function 0 (0x0)
	Vendor ID		0x10DE (0x10B0)
	Model ID		0x1081 (0x0801)
	Performance Level	Default
		Core clock	50.5 MHz
		Shader clock	101.0 MHz
		Memory clock	135.0 MHz
	Performance Level	2D Desktop
		Core clock	405.0 MHz
		Shader clock	810.0 MHz
		Memory clock	324.0 MHz
	Performance Level	3D Applications
		Core clock	800.0 MHz
		Shader clock	1600.0 MHz
		Memory clock	2000.0 MHz
Software
Windows Version			Microsoft Windows 7 (6.1) Home Premium Edition   (Build 7600)
DirectX Version			11.0
Ich habe gerade die MSI Instalations DVD des Motherboards eingelegt und erst mal den Total Installer angeclickt. Danach bin ich durchs DVD Verzeichnis gestöbert und habe einige Utilities, Tools und treiber einzeln installiert. Bei dem LucidHydra und LucidVirtu kam folgende Error Meldung:"No Intel HD sandy Bridge Graphics Family Device or Driver was found Setup will now exit"
Was ist denn da los. Der i7 2600k hat den inegrierten HD3000 GPU, so dacht ich jedenfalls und das Z68 Mainboard ubterstützt auch beides. habe auch einen DVI ausgang am MoBo.
Verstehe ich da etwas falsch? Bringe ich da etwas durcheinander?
inzwischen hat mir jemand gesagt man muss im bios bei igd multi monitor auf enabled stellen danach konnte ich zwar über die msi dvd immer noch nicht den trteiber starten, aber dafür im hardware manager dort war ein neuer eintrag. über aktualisieren kam dann ein neuer eintrag unter grafikkarte: intel(r) hd graphics family.
wars das? oder muß ich extra noch lucidhydra installierten?
  • PC.txt
    PC.txt
