AW: Bios Sammelthread für die M2N-Serie von ASUS (bitte Post 1 beachten)
  • Ersteller Ersteller Dilandau
  • Erstellt am Erstellt am
D
Dilandau
Informationen zu den M2A-VM HDMI Biosversionen:
Mainboard Manual: Deutsch
+CPU-Kompatibilitätsliste+
1404
-> THIS VERSION OF BIOS CAN ONLY BE UPDATED IN WINDOWS OPERATING SYSTEM ENVIRONMENT.
-> Support new CPUs.
1301
1101
-> Beta Bios!
1001
-> Fixed video output flicker or black screen
-> Fixed that AM2 Athlon(tm) 61 X2 Dual Core Processor 6000+ CPU show "AMD Processor Model Unknown" message
-> Fixed Red Hat Enterprise Linux 4 installation failed
-> Fixed sometimes can’t resume from S3
-> Modify MB temperature range of PC Probe II
-> Do not use EZ-Flash to flash BIOS if your BIOS version is prior to 0701!
0801
-> Fixed Q-FAN fail if disable Q-FAN in BIOS and then enable Q-FAN in OS.
-> Fixed Music Alarm Utility fail
-> Fixed usb keyboard can't work after the system resume from DOS
0502
-> Enhance onboard VGA and Vista compatibility
-> Fixed POST hang when 4G memory is installed and surroundview is enabled.
-> Enhance NVIDIA PCI E VGA card compatibility under Vista
-> support SB600 A21
0302
-> Fixed Vista DTM resstomp test fail
0204
0201
-> First Release
Informationen zu den M2R32-MVP Biosversionen:
1003
-> Beta Bios!
0906
-> Beta Bios!
0804
-> Fix Cool&Quiet cannot work under Windows 2000.
0712
0711
0607
-> Patch system will fail to boot with some DDR2 memory.
-> Patch system unable to restore from S3 state.
0501
-> Fixed system will hang with PCProbe II ver 1.04 hangs.
-> Fixed system cannot boot with some AMD Sempron CPU.
Informationen zu den M2S-X Biosversionen:
Mainboard Manual: Englisch
0601
0501
-> Fix the problem that sometimes system will be unstable in Windows Vista when you enable CnQ.
0302
-> Fix it shows "Overclocking failed" after 5% overclocking.
-> Rename the option" ACPI Version Features" as "ACPI 2.0 Support".
0208
-> First Release
Informationen zu den M2V Biosversionen:
1903
1803
-> Beta Bios
1802
1706
-> Enhance compatibility with certain memory modules
-> Enhance compatibility with certain SATA HDD
-> Update VIA SB RAID optionROM to V1.2
1704
-> Beta Bios
1701
-> Beta Bios
1603
-> Update onboard LAN PXE bootrom
1501
1304
-> Support SLP 2.0 Function
-> Add new CPU multiplier item in the BIOS
1102
-> Enhance compatibility with some CPUs and memory modules
1003
-> Enhance compatibility with some memory modules
-> Enhance compatibility with Windows Vista
-> Fix that audio device will disappear while installing 4G memory and EAX 300 SE VGA card.
0901
-> Beta Bios
0702
-> Enhance compatibility with some CPU.
-> Enhance compatibility with some SATA HDDs
0604
0504
-> Support AMD Live!
-> Update Attansic Option ROM
0407
-> Update Marvell Option to version A26.
0302
-> First Release
Informationen zu den M2V-MX Biosversionen:
1005
-> Fix "Processor Frequency Multiplier" shown incorrectly.
-> Fix PCProbe II shows warning message after resuming from
1005
-> Beta Bios
0904
0807
0804
-> Beta Bios
0801
-> Beta Bios
0703
-> Fix system fails to boot with some Semprom 2800+ CPU.
0701
-> Fix USB might fail during system bootup.
0601
0503
0411
0201
-> First Release
Informationen zu den M2V-MX SE Biosversionen:
0303
-> Keine Change-Log!
0202
-> First Release
Informationen zu den M2V-TVM Biosversionen:
0802
-> Beta Bios
0801
-> Beta Bios
0701
-> Fixed cpu fan speed is zero after resuming from S3 in PC probleII.
-> Fixed Intel 82573E PCIE Network card can not resume from S1 issue.
0612
-> Beta Bios
0611
-> Beta Bios
0604
-> Fix the failure to resume from S3 with 7100GS VGA card.
0406
-> Add VIA patch for onboard VGA driver loss issue.
-> Fix ATI X1600/X1300 blue screen during system shutting down.
-> Fix the issue that PCIE X1 lan does not get correct IP address when installed in X1 slot.
-> Fix PRI_IDE Slot CD-ROM does not get detected during EZ-FLASH.
0406
-> Beta Bios
0301
-> Fix the issue that USB HDD boot prority is always higher than RAID HDD.
-> Fix the issue that the system is unable to enter OS when system connects 4 PATA + 1/2 SATA.
-> Fix the issue that system may reboot when resume from S1.
0201
-> Add help message for Item "OnChip VGA Frame Buffer Size".
-> Fix the issue that PCIE X1 Card cannot be detected on X16 slot.
0110
-> First Release
Informationen zu den M2V-X Biosversionen:
0504
-> Beta Bios
0503
0404
-> Beta Bios
0306
0111
-> First Release
ASUS TOOLS:
ASUSUpdate Programm v.7.11.03
Afudos BIOS update tool V2.29
Awdflash BIOS update tool V1.20
aflash Bios Update Tool v.2.21
ASUS PC-Probe 32bit Vers. 2.25.02
ASUS PC-Probe 64bit Vers. 2.64.14
ASUS PC-Probe 2 v.1.04.23
ASUS AI-Booster v.2.03.12
AI-Selector v.1.00.08
AI-Gear v.1.00.18
AI-Nap v.1.00.16
AI-Suite v.1.03.15
ASUS Spezifische Treiber:
ACPI 32bit inf vom 11.10.2006
ACPI 64bit inf vom 19.10.2006
ACPI Treiber komplett mit Installer
Wichtige Sites:
Internationaler ASUS Download FTP-Server 01 (Global)
Internationaler ASUS Download FTP-Server 02 (EU)
Internationaler ASUS Download FTP-Server TW
Allgemeine ASUS Download Site
Nvidia Download FTP-Server
Allgemeine Nvidia Download Site
VIA-Drivers Site
ATI-AMD Treiber Seite
Marvell Netzwerktreiber
Bios-Kompendium
Tests & Previews & News:
AMD stellt Chipsätze 690G und 690V vor
FORUM:
Sockel AM2 Motherboards, alle Top-Modelle (by Sleepy Hollow@forumbase)
Alphabetische Übersicht aller (Mainboard) Sammelthreads (by Kabelsalat@forumdeluxx)
TIPPs:
Mit ASUS-Update neues Bios mit Älterem überspielen:
Falls Ihr mal ein altes Bios mit ASUS-Update über ein neues Bios flashen wollt müsst Ihr nur im ASUS-Update unter Optionen bei Bios Downgradable einen Haken setzen und Ihr könnt diese dann aufspielen!
BIOS flashen Unter DOS mit AFUDOS (AMI-BIOS):
Man erstellt eine DOS Start-Diskette (im Explorer rechter Mausklick auf das Diskettensymbol, dann Formatieren auswählen und das Häkchen bei "DOS Startdiskette erstellen" setzen) und kopiert das BIOS File und die AFUDOS.exe auf die Diskette. Nun begibt man sich ins BIOS Setup und läd die "Setup defaults" (Die Diskette befindet sich im Laufwerk!) Änderungen speichern!Nun Startet der PC und läd automatisch das Setup Programm von Diskette.Der Befehl zum Flashen lautet: afudos /i"filename" Das war es. (written by Jensematz)
BIOS flashen unter DOS mit AWDFLASH (Phoenix-BIOS):
Man erstellt eine DOS Start-Diskette (im Explorer rechter Mausklick auf das Diskettensymbol, dann Formatieren auswählen und das Häkchen bei "DOS Startdiskette erstellen" setzen) und kopiert das BIOS File und die AWDFLASH.exe auf die Diskette. Nun begibt man sich ins BIOS Setup und läd die "Setup defaults" (Die Diskette befindet sich im Laufwerk!) Änderungen speichern! Nun Startet der PC und läd automatisch das Setup Programm von Diskette. Der Befehl zum Flashen lautet: awdflash /qi "filename"
Eine DOS Maske erscheint, in dieser wird der Name des BIOS File eingegeben, z.B. "1009.bin". Mit Enter Bestätigen! Nach einigen Sekunden wird man gefragt ob das BIOS gespeichert werden soll (Press:Y/N) dies wird mit "N" für NEIN bestätigt, damit der Flashvorgang startet. Wird die Meldung angezeigt, dass das Update erfolgreich war, drückt man F1 um den Rechner neu zu starten. Das war es"(written by Jensematz)
:cheerlead: HALL OF FAME :cheerlead:
Ein dickes Danke an unseren Mod Green Mamba der mir mit Rat und Tat zur Seite steht und mir immer alles sehr geduldig editiert (z.B. Umfrage, usw.).
Und nun auch ein fettes Danke an unseren Mod Tommy, der uns immer wieder mit exklusiven Biosversionen versorgt!
Ein Dickes Lob an MR-Y für das tägliche durchforsten der ASUS-Server und für seine rege Mitarbeit im Thread.
Ein dickes Danke auch an Jensematz der mir seine Texte "Bios flashen unter DOS" zur Verfügung gestellt hat.
:daumen: DANKE! :daumen:
