Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\110110-19765-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\symbols*
http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02c08000 PsLoadedModuleList = 0xfffff800`02e45e50
Debug session time: Mon Nov 1 14:22:38.278 2010 (GMT+1)
System Uptime: 0 days 0:38:05.041
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck A, {fffff680003bc9a8, 0, 0, fffff80002cab5dc}
Probably caused by : memory_corruption ( nt!MiDeletePageTableHierarchy+9c )
Followup: MachineOwner
3: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: fffff680003bc9a8, memory referenced
Arg2: 0000000000000000, IRQL
Arg3: 0000000000000000, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff80002cab5dc, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002eb00e0
fffff680003bc9a8
CURRENT_IRQL: 0
FAULTING_IP:
fffff800`02cab5dc 498b06 mov rax,qword ptr [r14]
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xA
PROCESS_NAME: svchost.exe
TRAP_FRAME: fffff88002bebdd0 -- (.trap 0xfffff88002bebdd0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=000000ef26a00000 rbx=0000000000000000 rcx=0000000fffffffff
rdx=0000058000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002cab5dc rsp=fffff88002bebf60 rbp=fffffa8007746b30
r8=0000007ffffffff8 r9=0000098000000000 r10=fffffa80069064c0
r11=fffff88002bec040 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na pe cy
nt!MiDeletePageTableHierarchy+0x9c:
fffff800`02cab5dc 498b06 mov rax,qword ptr [r14] ds:00000000`00000000=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002c77ca9 to fffff80002c78740
STACK_TEXT:
fffff880`02bebc88 fffff800`02c77ca9 : 00000000`0000000a fffff680`003bc9a8 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
fffff880`02bebc90 fffff800`02c76920 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`02bebdd0 fffff800`02cab5dc : fffffa80`0049ee40 00000000`00000001 fffffa80`003e4870 fffff680`00007000 : nt!KiPageFault+0x260
fffff880`02bebf60 fffff800`02c4cd16 : fffff700`010805d0 fffffa80`07746ec8 fffff700`01080000 fffff8a0`00d61c20 : nt!MiDeletePageTableHierarchy+0x9c
fffff880`02bec070 fffff800`02c4b68a : fffffa80`07746b30 fffffa80`00000000 fffff8a0`0000015c fffff880`00000000 : nt!MiDeleteAddressesInWorkingSet+0x3fb
fffff880`02bec920 fffff800`02f5ddcf : fffff8a0`08e4e5a0 fffff880`02becc20 00000000`00000000 fffffa80`0778bb60 : nt!MmCleanProcessAddressSpace+0x96
fffff880`02bec970 fffff800`02f36635 : 00000000`c0000005 00000000`00000001 000007ff`fffda000 00000000`00000000 : nt!PspExitThread+0x92f
fffff880`02beca30 fffff800`02c551db : 00000000`02becca0 fffffa80`076e9610 00000000`00000000 00000000`00000000 : nt!PsExitSpecialApc+0x1d
fffff880`02beca60 fffff800`02c55620 : 00000000`779f4298 fffff880`02becae0 fffff800`02f3674c 00000000`00000001 : nt!KiDeliverApc+0x2eb
fffff880`02becae0 fffff800`02c77a37 : fffffa80`0778bb60 00000000`779f4270 fffff880`000000c0 00000000`00000000 : nt!KiInitiateUserApc+0x70
fffff880`02becc20 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0x9c
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nt!MiDeletePageTableHierarchy+9c
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4c1c44a9
IMAGE_NAME: memory_corruption
FAILURE_BUCKET_ID: X64_0xA_nt!MiDeletePageTableHierarchy+9c
