Crysis Crysis sehr dunkel
Whitecker007
Okt. 2007
Ja,warum ist das bei mir so extrem dunkel?
Bei anderen ist es viel heller.
So sieht meine autoexec.cfg aus.
con_restricted = 0
r_displayinfo = 1
;[~]Game Config[~]
sys_spec_ObjectDetail=4
sys_spec_VolumetricEffects=4
sys_spec_Shadows=4
sys_spec_Texture=4
sys_spec_Physics=4
sys_spec_PostProcessing=4
sys_spec_Particles=4
sys_spec_Sound=4
sys_spec_Water=4
sys_spec_GameEffects=4
;[~]Another Config[~]
r_sunshafts=1
e_water_ocean_fft=1
r_UseEdgeAA=2
r_motionblur=1
r_contrast=0.55
r_gamma=0.97
r_brightness=0.48
;[~]HDR Config[~]
r_SSAO_quality = 2
r_SSAO_radius = 2
r_SSAO_darkening = 2.7
r_ssao_amount = 0.3
r_SSAO_blur = 2
r_SSAO_blurriness = 1
r_Glow = 1
r_EyeAdaptionClamp = 1.7
r_HDRlevel = 1
r_HDRBrightOffset = 7
r_HDRBrightThreshold = .7
r_HDRRendering=2
r_hdrlevel=0.7
;[~]Texture Config[~
r_usepom=1
r_TexturesStreaming=0
;[~]Shader Config[~]
q_ShaderGeneral = 4
q_ShaderMetal = 4
q_ShaderGlass = 4
q_ShaderVegetation = 4
q_ShaderIce = 4
q_ShaderTerrain = 4
q_ShaderShadow = 4
q_ShaderFX = 4
q_ShaderPostProcess = 4
q_ShaderHDR = 4
q_ShaderSky = 4
q_Renderer = 4
r_LightsSinglePass = 0
r_colorgrading=1
r_Beams=3
r_BeamsMaxSlices=250
;[~]Shadow Config[~]
r_SSAO_amount=0.5
r_ssao_darkening=0.8
;[~]Lods[~]
e_vegetation_sprites_distance_custom_ratio_min = 1
e_vegetation_sprites_distance_ratio=1.5
e_cull_veg_activation = 60
e_particles_lod=0.6
es_MaxPhysDist=60
e_terrain_lod_ratio=0.8
e_lod_ratio=6
e_lod_min=0
e_lods=1
r_DetailDistance=12
r_CloudsUpdateAlways=1
e_particles_thread=1
g_dof_ironsight=1
;[~]Misc[~]
e_max_entity_lights = 16
g_battleDust_enable = 1
g_ragdollDistance = 35
g_ragdollMinTime = 15
e_terrain_ao=1
e_terrain_normal_map=1
;[~]Water[~]
r_WaterReflectionsQuality = 4
r_WaterUpdateDistance = 0.2
r_WaterCaustics=1
r_WaterRefractions=1
r_WaterReflections=1
r_WaterGodRays = 1
e_water_ocean_fft=1
e_water_tesselation_amount = 10
e_water_tesselation_swath_width=10
q_ShaderWater=4
e_phys_ocean_cell = 0.3
;[~]Performance Selections[~]
;d3d9_rb_Verts=4096
;d3d9_pip_buff_size=0
;d3d9_rb_Tris=4096
sys_physics_CPU=1
e_precache_level=0
r_ShadersPrecacheAllLights=0
r_ShadersAsyncCompiling=0
e_level_auto_precache_textures_and_shaders=1
r_GeomInstancing =1
r_TextureCompressor=0
r_CullGeometryForLights=1
e_terrain_occlusion_culling_max_dist=200
e_scene_merging_max_tris_in_chunk=128
e_scene_merging_max_time_ms=1
;d3d9_VBPoolSize=524288
e_scene_merging_compact_vertices=0
ac_templateMCMs=0
r_ShadersIntCompiler=0
e_max_entity_lights=2
e_terrain_normal_map = 0
e_vegetation_static_instancing=0
e_gsm_range = 3
e_gsm_cache = 0
e_ram_maps = 1
e_dissolve = 1
r_TerrainAO_FadeDist=1
r_MotionBlur = 3
r_ColorGradingDOF = 1
e_hw_occlusion_culling_objects=1
e_dynamic_light=1
g_dofset_maxscale=3
Loaded!
Auch mit der standard autoexec.cfg siehts so brutal dunkel aus.
Achja hab jetzt ne Club3D ATI 5850er drinne,mit der GTX 260 wars vorher nich so extrem...
mh?!
r_contrast=0.55
r_gamma=0.97
r_brightness=0.48
Setz die mal hoch
Gamescom
