Fehleranalyse (Bluescreens)
ampash
Apr. 2005
Hi all,
ich würde gerne meine Bluescreens analysieren und bitte hier im Forum mal um Hilfe dazu.
Mein System:
Betriebssystem - MS Windows 7 Home Premium 64-bit
CPU - AMD Athlon II X2 245 20° C Regor 45nm Technologie
RAM - 4.0GB Dual-Kanal DDR3 @ 669MHz (7-7-7-24)
Motherboard - ASUSTeK Computer INC. M4A785TD-M EVO (AM3)
Grafik - ATI Radeon HD 5700 Series @ SyncMaster (1920x1080@60Hz)
Festplatten - 244GB Western Digital WDC WD2500AAKS-00F0A0 ATA Device
Optische Laufwerke - HL-DT-ST DVD-ROM GDR-H30N ATA Device
Audio - VIA High Definition Audio
Netzwerk - Realtek RTL8168D/8111D-Familie-PCI-E-Gigabit-Ethernet-NIC (NDIS 6.20)
Hier meine Dumps: (es geht mit dem letzten los, bis runter zum ältesten)
On Sun 06.03.2011 22:21:02 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030611-12370-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x70740)
Bugcheck code: 0xA (0xFFFFF88000DEA840, 0x2, 0x0, 0xFFFFF80002ADA14B)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
On Sun 06.03.2011 22:07:56 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030611-16957-01.dmp
This was probably caused by the following module: watchdog.sys (watchdog+0x122F)
Bugcheck code: 0x119 (0x7000000, 0xFFFFFA80053BC410, 0xFFFFFA80067B9010, 0xFFFFFA8004064780)
Error: VIDEO_SCHEDULER_INTERNAL_ERROR
file path: C:\Windows\system32\drivers\watchdog.sys
description: Watchdog Driver
On Sat 05.03.2011 22:22:06 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030511-16614-01.dmp
This was probably caused by the following module: atikmdag.sys (atikmdag+0x3B684E)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF88004A0584E, 0xFFFFF880095097A0, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
file path: C:\Windows\system32\drivers\atikmdag.sys
product: ATI Radeon Family
company: ATI Technologies Inc.
description: ATI Radeon Kernel Mode Driver
On Sat 05.03.2011 19:56:40 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030511-16879-01.dmp
Bugcheck code: 0x119 (0x7000000, 0xFFFFFA8005540410, 0xFFFFFA8003F3CAF0, 0xFFFFFA8003BB7AC0)
On Sat 05.03.2011 18:27:29 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030511-15896-01.dmp
Bugcheck code: 0x119 (0x7000000, 0xFFFFFA80055D8410, 0xFFFFFA8004404400, 0xFFFFFA8003C93910)
On Sat 05.03.2011 14:14:45 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030511-14757-01.dmp
This was probably caused by the following module: atikmdag.sys (atikmdag+0x3F058B)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF880049FC58B, 0xFFFFF88001FED7B0, 0x0)
On Fri 04.03.2011 22:09:02 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030411-14695-01.dmp
Bugcheck code: 0x119 (0x7000000, 0xFFFFFA80058A5410, 0xFFFFFA8005B4D090, 0xFFFFFA8004565EC0)
Folgendes wurde schon zur Fehlerbehebung durchgeführt:
1. den aktuellen Grafikkartentreiber gegen einen älteren austauschen
2. Memorycheck mit Memtest via USB-Boot (Speicher nach 3 durchläufen "4 Stunden" OK!)
bis hier hin bin ich gekommen ... leider ohne Erfolg. Wenn mir hier evtl. jemand weiterhelfen kann, wäre das echt nice :)
Grüße
Micha
1.) Es hat hier sehr wahrscheinlich etwas mit dem Grafiktreiber. ATI und Nvidia sind beide berühmt dafür zwar schnelle, aber nicht unbedingt sehr stabile Treiber zu liefern.
Die atikmdag.sys ist vom ATI Treiber und die watchdog.sys ist der Bluescreen Treiber selbst, wobei die auch auf den Grafiktreiber verweisen.
2.) Natürlich kann die Karte selbst auch hardwaremäßig hin sein. Hier wäre es einmal gut die Karte gegen eine andere zu tauschen.
3.) Falls es die Grafikkarte nicht, ist, wäre der nächste Kandidat der RAM, wobei ich zu 90% auf die Grafikkarte tippen würde.
Watchdog.sys ist der Realtime-Scanner von Trendmicro, manche Boards haben im Bios eine Virenscanfunktion (PC-Cillin, ist von Trendmicro), kannst es ja mal deaktivieren wenn Du es im Bios einstellen kannst. Sonst mal den Dienst deinstallieren.
atikmdag.sys, ist der Grakatreiber, evtl solltest Du im Bios andere Einstellungen benutzen, kannst ja mal lesen was andere gemacht haben, angeblich die Lösung:
http://www.computerhilfen.de/hilfen-4-228965-0.html
Sieht auf dem 1.Blick nach einem IRQ Konflikt im Bios aus,nach der Beschreibung des 1. Bluescreens.
Die Grafikkarte scheint sich den gleichen IRQ mit einem anderen Gerät im PC zu teilen, welches diesen Watchdog Driver nutzt.
Leider kann man soweit ich weis,die IRQ's in Windows 7 nicht mehr manuell vergeben.
Da hilft dir wohl nur,die Grafikkarte zu deinstallieren,die Grafikkarte in einen anderen Slott im Mainboard zu stecken,die Treiber nochmal neu zu installieren und zu hoffen,dass Windows 7 den beiden Geräten eine neue IRQ zugewiesen hat.
Ein ähnliches Problem hatte ich mal bei der Windows 7 Beta: Da hat sich die Grafikkarte den selben IRQ mit meiner Soundblaster X-Fi Titanium Soundkarte geteilt und sobald ich ein Videoprogram/Spiel geöffnet habe,hat sich Windows mit einem Bluescreen aufgehängt,mit Verweis auf IRQ Konflikt.
Wenn nicht,scheint es wie schon beschrieben ein Software Problem mit diesem Watchdog Driver Programm zu sein,welches du testweise mal deinstallieren könntest.
IRQL_NOT_LESS_OR_EQUAL =/= IRQ Konflikt. Sagt nur aus, das ein erhaltener IRQ nicht dem entspricht, was erwartet wird. Kann an nicht stabilen Spannungen, Speicherfehler oder CPU Fehler liegen. Ist der beste BS von allen. Ich tippe auf das Netzteil, hast du übertaktet? Welches Netzteil hast du? Es kann auch an zu hohen Temperaturen von NB oder SB liegen. Wenn du übertaktet hast, alles auf stock-settings zurück. Wenn nicht, alle nicht benötigten Geräte entfernen und testen, testen, testen. Wenn der Fehler dann noch auftritt, tja, ka. Ach ja, probier bei den nicht benötigtn Geräten auch weniger Speicher.
Watchdog.sys kann aber auch mit dem Treiber der Graka zu tun haben und nicht mit dem Viren Scanner, vor allen dann wenn nicht mal Trendmicro Installiert ist...........
Wann bekommst du denn den BSOD?
Sporadisch oder wenn du eine bestimmte Anwendung laufen hast oder laufen lassen willst?
Hier mal ein Link mit einem wo das Problem mit der Watchdog.sys gelöst wurde:
http://www.wintotal-forum.de/index.php?action=printpage;topic=163382.0
Sofern das auf dich zutrifft kann man das ja mal Probieren.
Der Rest der MiniDumps weißt auf alle fälle auf ein Treiber oder gegebenenfalls HW Problem im Grafikbereich auf.
Hallo, erstmal vielen Dank für eure schnelle und zahlreiche Untestützung.
folgendes habe ich seit dem noch geändert:
1. Im Bios die CPU-Clock und die PCIE-Clock auf 200 und 100 fixiert (Manual statt Auto)
da die Einstellung "Auto" die Clock nicht 100% auf einem konstanten Wert hält.
siehe Beitrag von "werkam"
2. Alle ATi-Treiber sauber entfernt und anschließend die neusten von AMD installiert.
(auch für die SB)
Also bist jetzt habe ich noch keinen weiteren Bluescreen. Aber was nicht ist, kann ja noch ... :evillol:
Sollte es noch einen Absturz geben, werde ich eine andere Grafikkarte einlochen um zu sehn ob evtl. die hardware einen Schuß hat.
Grüße
Micha
..... hier noch die CPU-Z Screenies .....
hier mal der aktuelle Stand der Dinge:
da ich in meinem letzten Post den Teufel ja schon "an die Wand gemalt" habe, waren die Bluescreens auch nicht mehr weit. Habe also wie schon geschrieben, die Grafikkarte getauscht und auch das war nix ... wieder alles in schönem MS-Blau.
0x119 und 0x3B Screens tauchten wieder auf.
Ich fasse nochmal zusammen:
0. Memtest (4Std.) laufenlassen ... alles OK!
1. im Bios die "Clock" Einstellungen von "Auto" auf einen festen Wert gestellt.
2. verschiedene Treiberversionen getestet.
3. IRQ Belegung ... Checked!
4. Grafikkarte getauscht
hatte noch vergessen zu erwähnen, das die Screens ganz willkürlich kommen, also auch ohne das wer was am Rechner macht. Da ich jetzt doch recht Ratlos bin, kann ich mir fast nur noch vorstellen, das evtl. meine Windows installation nicht ganz so sauber arbeitet.
Evtl. sollte ich mal eine Neuinstallation in erwägung ziehen.
Aber vorher mach ich dann noch ein Bios-Update.
So long
Grüße Micha
nach dem Biosupdate kamen wieder Bluescreens ...
Ist schon merkwürdig, naja, ich hab dann das System neu aufgesetzt und bis jetzt (2 Tage) ging alles gut. Wollen mal hoffen das es dabei bleibt.
Am meisten ärgert mich, auch wenns jetzt gehen sollte, das ich nicht sagen kann was genau das Problem war.
Ich schließe diesen Thread dann ma mit der Annahme ab, das es an einem, aus welchem Grund auch immer "zerschossenem" System gelegen hat.
Danke nochmal für eure Hilfe
bb
