Lest mal was da steht :
http://www.tbreak.com/forums/showthread.php?s=&threadid=8275
Nvidia NV30 [ OMEN ] Specs
alright people, rumoured NV30 Specs from
http://www.guru3d.com/
eat this ATI :
Omen Card
AGP 4x and 8x
Copper Core Gpu Processor 0.13 m default clock 450 MHz
73 million transistors
8 pipes
Quad Vertex Shaders
85 bone capable
Lightspeed Memory Architecture II
Quad Cache memory caching subsystem
Dual Z-buffers for greater compression without losses
visibility subsystem
NvAuto pre-charge
Advanced Anisotropic Filtering:
A new 12nvx mode that delivers improved subpixel coverage ,texture placement and quality.
12nvx mode should deliver 80% better subpixel coverage and placement than previous modes
A separate second processor running at 450Mhz an 0.13m as well
Will handle all T&L now called TT&L (True Time and lighting) .
Plus new NVShaper a prechached and precacheable system.
That has precached shapes cirles,squares,triangles,and other shapes.
Programmers can also add shapes to be temporaly stored in it`s precache to speed things up. This should speed things up and make standard shapes more accurate!
128 MB DDR-SDRAM @ 375 MHz x2 = 750Mhz and 256 bit yes 256 bit!
370Mhz RAMDAC
Direct X 9.X compatable
Latest Open Gl
backward glide capable
Comes with New NvBlur (Yes a new version of Glide!)
NView Multi-display Technology
There maybe A new form of cooling the gpu`s . Where the Gpu`s have a hole in the middle and through the board.
So, the hottest area of the Gpu`s gets proper cooling.
4 Vertexshader, nett. 256bit anstatt wie bisher "nur" 128bit breiter Speicher (theoretisch doppelt so schnell), dazu die 450Mhz Coretakt und sage und schreibe 2 Gpus auf einem Board wobei eine davon die T&L-Aufgaben übernehmen soll
Die Karte wird sehr mächtig, mit einer Ti4600 gar nicht zu vergleichen (wäre wohl als würde man ein Fahrad mit nem Auto vergleichen...)
