Simplexnoise Fehlersuche (Erledigt)
Grüße ich brauche gerade ein zwei Rauschfunktionen und habe bei Wikipedia dieses PDF gefunden.
http://staffwww.itn.liu.se/~stegu/simplexnoise/simplexnoise.pdf
Jetzt habe ich die 2D und 3D version in C# implementiert nur leider habe ich in der 3D version irgendwo einen Fehler.
Nun bin seit etwa 20 Uhr auf Fehlersuche ohne Erfolg nun hoffe ich das hier einer erkennt was falsch läuft
2D Version (scheint zu funktionieren)
3D Version
Code:
using System.Collections;
using System;
public class Simplex2D
private readonly int[,] gradients = {{1,1},{-1,1},{1,-1},{-1,-1},{1,0},{-1,0},{1,0},{-1,0},{0,1},{0,-1},{0,1},{0,-1}};
private readonly int[,] offsets = {{1,0},{0,1}};
private readonly float G1 = 0.366025403784439f;
private readonly float G2 = 0.211324865405187f;
private readonly float G3 = 0.57735f;
private Random random;
private int[] permutationTable;
public Simplex2D()
int[] tmpPermutationTable = {151,160,137,91,90,15,131,13,201,95,96,53,194,233,7,225,140,36,103,30,69,142,8,99,37,240,21,10,23,190, 6,148,247,120,234,75,0,26,197,62,94,252,219,203,117,35,11,32,57,177,33,88,237,149,56,87,174,20,125,136,171,168, 68,175,74,165,71,134,139,48,27,166,77,146,158,231,83,111,229,122,60,211,133,230,220,105,92,41,55,46,245,40,244,102,143,54, 65,25,63,161, 1,216,80,73,209,76,132,187,208, 89,18,169,200,196,135,130,116,188,159,86,164,100,109,198,173,186, 3,64,52,217,226,250,124,123,5,202,38,147,118,126,255,82,85,212,207,206,59,227,47,16,58,17,182,189,28,42,223,183,170,213,119,248,152, 2,44,154,163, 70,221,153,101,155,167, 43,172,9,129,22,39,253, 19,98,108,110,79,113,224,232,178,185, 112,104,218,246,97,228,251,34,242,193,238,210,144,12,191,179,162,241, 81,51,145,235,249,14,239,107,49,192,214, 31,181,199,106,157,184, 84,204,176,115,121,50,45,127, 4,150,254,138,236,205,93,222,114,67,29,24,72,243,141,128,195,78,66,215,61,156,180};
permutationTable = new int[512];
for(int i = 0; i < 512; i++)
permutationTable[i] = tmpPermutationTable[i & 255];
public float GetValue(float _x, float _z)
int offsetIndex = 0;
float s = (_x+_z) * G1;
int i = Floor(_x+s);
int j = Floor(_z+s);
float t = (i+j)*G2;
float x0 = _x-(i-t);
float y0 = _z-(j-t);
if(x0>y0)
offsetIndex = 0;
else
offsetIndex = 1;
float x1 = x0 - offsets[offsetIndex,0] + G2;
float y1 = y0 - offsets[offsetIndex,1] + G2;
float x2 = x0 - G3;
float y2 = y0 - G3;
int ii = i & 255;
int jj = j & 255;
int gi0 = permutationTable[ii+permutationTable[jj]] % 12;
int gi1 = permutationTable[ii+offsets[offsetIndex,0]+permutationTable[jj+offsets[offsetIndex,1]]] % 12;
int gi2 = permutationTable[ii+1+permutationTable[jj+1]] % 12;
return 70.0f * (GetSampleValue (gi0, x0, y0) + GetSampleValue (gi1, x1, y1) + GetSampleValue (gi2, x2, y2));
public void SetSeed(int _value)
random = new Random (_value);
GeneratePermutationTable ();
private void GeneratePermutationTable()
int[] tmpPermutationTable = new int[256];
for (int i = 0; i < 255; i ++)
tmpPermutationTable[i] = random.Next(0,255);
private float GetSampleValue(int _index,float _x, float _z)
float value = 0.5f - _x * _x - _z * _z;
return (value < 0) ? 0.0f : value * value * dot(_index, _x, _z);
private int Floor(float _value)
if(_value > 0)
return (int) _value;
return (int)_value-1;
private float dot(int _index, float _x, float _z)
return gradients[_index,0]*_x + gradients[_index,1]*_z;
3D Version
Code:
using System;
public class Simplex3D
private readonly int[,] gradients = {{1,1,0},{-1,1,0},{1,-1,0},{-1,-1,0},{1,0,1},{-1,0,1},{1,0,-1},{-1,0,-1},{0,1,1},{0,-1,1},{0,1,-1},{0,-1,-1}};
private readonly int[,] offsets = {{1,0,0,1,1,0},{1,0,0,1,0,1},{1,0,0,1,0,1},{0,0,1,0,1,1},{0,1,0,0,1,1},{0,1,0,1,1,0}};
private readonly float G1 = 0.166666666666667f;
private readonly float G2 = 0.333333333333333f;
private readonly float G3 = 0.5f;
public Simplex3D()
public float GetValue(float _x, float _y, float _z)
float s = (_x+_y+_z) * G2;
int j = Floor(_y+s);
int k = Floor(_z+s);
float t = (i+j+k)*G1;
float y0 = _y-(j-t);
float z0 = _z-(k-t);
if(x0>=y0)
if(y0>=z0)
offsetIndex = 0;
else
if(x0>=z0)
offsetIndex = 1;
else
offsetIndex = 2;
else
if(y0<z0)
offsetIndex = 3;
else
if(x0<z0)
offsetIndex = 4;
else
offsetIndex = 5;
float x1 = x0 - offsets[offsetIndex,0] + G1;
float y1 = y0 - offsets[offsetIndex,1] + G1;
float z1 = z0 - offsets[offsetIndex,2] + G1;
float x2 = x0 - offsets[offsetIndex,3] + G2;
float y2 = y0 - offsets[offsetIndex,4] + G2;
float z2 = z0 - offsets[offsetIndex,5] + G2;
float x3 = x0 - G3;
float y3 = y0 - G3;
float z3 = z0 - G3;
int ii = i & 255;
int jj = j & 255;
int kk = k & 255;
int gi0 = permutationTable[ii + permutationTable[jj+permutationTable[kk]]] % 12;
int gi1 = permutationTable[ii + offsets[offsetIndex,0] + permutationTable[jj + offsets[offsetIndex,1] + permutationTable[kk + offsets[offsetIndex,2]]]] % 12;
int gi2 = permutationTable[ii + offsets[offsetIndex,3] + permutationTable[jj + offsets[offsetIndex,4] + permutationTable[kk + offsets[offsetIndex,5]]]] % 12;
int gi3 = permutationTable[ii + 1 + permutationTable[jj + 1 + permutationTable[kk + 1]]] % 12;
return 32.0f*(GetSampleValue (gi0, x0, y0, z0) + GetSampleValue (gi1, x1, y1, z1) + GetSampleValue (gi2, x2, y2, z2) + GetSampleValue (gi3, x3, y3, z3));
int[] tmpPermutationTable = new int[255];
private float GetSampleValue(int _index,float _x, float _y, float _z)
float value = 0.5f - _x * _x - _y * _y - _z * _z;
return (value < 0) ? 0.0f : value * value * dot(_index, _x, _y, _z);
return (_value > 0) ? (int) _value : (int)_value-1;
private float dot(int _index, float _x,float _y, float _z)
return gradients[_index,0]*_x + gradients[_index,1]*_y + gradients[_index,2]*_z;
