2017-10-25 01:05:58, Info DISM API: PID=2300 TID=9752 DismApi.dll: - DismInitializeInternal
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=9752 DismApi.dll: <----- Starting DismApi.dll session -----> - DismInitializeInternal
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=9752 DismApi.dll: Version 10.0.14393.0 - DismInitializeInternal
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=9752 DismApi.dll: Parent process command line: C:\Windows\system32\cleanmgr.exe /autoclean /d C: - DismInitializeInternal
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=9752 Enter DismInitializeInternal - DismInitializeInternal
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=9752 Input parameters: LogLevel: 2, LogFilePath: (null), ScratchDirectory: (null) - DismInitializeInternal
2017-10-25 01:05:58, Info DISM Try to initialize Panther logging 1 times, last error: 0x0
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=9752 Initialized GlobalConfig - DismInitializeInternal
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=9752 Initialized SessionTable - DismInitializeInternal
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=9752 Lookup in table by path failed for: DummyPath-2BA51B78-C7F7-4910-B99D-BB7345357CDC - CTransactionalImageTable::LookupImagePath
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=9752 Waiting for m_pInternalThread to start - CCommandThread::Start
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=7472 Enter CCommandThread::CommandThreadProcedureStub - CCommandThread::CommandThreadProcedureStub
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=9752 CommandThread StartupEvent signaled - CCommandThread::WaitForStartup
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=9752 m_pInternalThread started - CCommandThread::Start
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=9752 Created g_internalDismSession - DismInitializeInternal
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=9752 Leave DismInitializeInternal - DismInitializeInternal
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=9752 Enter DismOpenSessionInternal - DismOpenSessionInternal
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=9752 Input parameters: ImagePath: DISM_{53BFAE52-B167-4E2F-A258-0A37B57FF845}, WindowsDirectory: (null), SystemDrive: (null) - DismOpenSessionInternal
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=9752 Lookup in table by path failed for: DRIVE_C - CTransactionalImageTable::LookupImagePath
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=7472 Enter CCommandThread::ExecuteLoop - CCommandThread::ExecuteLoop
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=8508 Enter CCommandThread::CommandThreadProcedureStub - CCommandThread::CommandThreadProcedureStub
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=9752 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=8508 Enter CCommandThread::ExecuteLoop - CCommandThread::ExecuteLoop
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=8508 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-10-25 01:05:58, Info DISM API: PID=2300 TID=8508 Successfully dequeued command object - CCommandThread:
equeueCommandObject
2017-10-25 01:05:58, Info DISM PID=2300 TID=8508 Scratch directory set to 'C:\Users\USERNAME\AppData\Local\Temp\'. - CDISMManager:
ut_ScratchDir
2017-10-25 01:05:58, Info DISM PID=2300 TID=8508 DismCore.dll version: 10.0.14393.0 - CDISMManager::FinalConstruct
2017-10-25 01:05:58, Info DISM PID=2300 TID=8508 Successfully loaded the ImageSession at "C:\Windows\system32\Dism" - CDISMManager::LoadLocalImageSession
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Failed to get and initialize the PE Provider. Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Getting Provider DISMLogger - CDISMProviderStore::GetProvider
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Provider has previously been initialized. Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-10-25 01:05:58, Info DISM DISM Manager: PID=2300 TID=8508 Successfully created the local image session and provider store. - CDISMManager::CreateLocalImageSession
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Getting the collection of providers from a local provider store type. - CDISMProviderStore::GetProviderCollection
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Loading Provider from location C:\Windows\system32\Dism\FolderProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Connecting to the provider located at C:\Windows\system32\Dism\FolderProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Loading Provider from location C:\Windows\system32\Dism\WimProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Connecting to the provider located at C:\Windows\system32\Dism\WimProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Loading Provider from location C:\Windows\system32\Dism\VHDProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Connecting to the provider located at C:\Windows\system32\Dism\VHDProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Loading Provider from location C:\Windows\system32\Dism\ImagingProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Connecting to the provider located at C:\Windows\system32\Dism\ImagingProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Loading Provider from location C:\Windows\system32\Dism\CompatProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Connecting to the provider located at C:\Windows\system32\Dism\CompatProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Loading Provider from location C:\Windows\system32\Dism\FfuProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Connecting to the provider located at C:\Windows\system32\Dism\FfuProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Loading Provider from location C:\Windows\system32\Dism\SiloedPackageProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-10-25 01:05:58, Warning DISM DISM Provider Store: PID=2300 TID=8508 Failed to Load the provider: C:\Windows\system32\Dism\SiloedPackageProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
[2300] [0x8007007b] FIOReadFileIntoBuffer
1250): Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
[2300] [0xc142011c] UnmarshallImageHandleFromDirectory
793)
[2300] [0xc142011c] WIMGetMountedImageHandle
3047)
2017-10-25 01:05:58, Info DISM DISM WIM Provider: PID=2300 TID=8508 [C:\] is not a WIM mount point. - CWimMountedImageInfo::Initialize
2017-10-25 01:05:58, Info DISM DISM VHD Provider: PID=2300 TID=8508 [C:\] is not recognized by the DISM VHD provider. - CVhdImage::Initialize
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Getting Provider VHDManager - CDISMProviderStore::GetProvider
2017-10-25 01:05:58, Info DISM DISM Imaging Provider: PID=2300 TID=8508 The provider VHDManager does not support CreateDismImage on C:\ - CGenericImagingManager::CreateDismImage
2017-10-25 01:05:58, Info DISM DISM Provider Store: PID=2300 TID=8508 Getting Provider WimManager - CDISMProviderStore::GetProvider
793)
3047)
