Ohne jetzt auf einen einzelnen Post einzugehen, eine Kurzzusammenfassung aus diversen Foren:
Intel Pentium Dual-Core Desktop Processor E4500
CPU Speed: 2.20 GHz
Bus Speed: 800 MHz
Bus/Core Ratio: 11
Thermal Specification: 73.3°C
VID Voltage Range: 0.85V – 1.5V
4500er overclocking mit 8*400MHz, 9*333MHz, RAM-Spannung auf 2,1V und 1,40 bis 1,45V Vcore, auch 11*300MHZ auf 1,35V Vcore kann funktionieren
Here are some settings to get you started at 3.2GHz:
Make sure to set PCI-E to 100 in bios, this will lock it and not let it increase with the FSB. If not, the higher you overclock, the more unstable the board will become.
Für ein Gigabyte P35-Board(?):
The OCing features are in MB Intelligent Tweaker(M.I.T.)
CPU Host Clock Control - enable
CPU Host Frequency (Mhz) - set to 290
PCI Express Frequency (Mhz) - Set to 100 (this is the deafult for the video card)
System Memory Multiplier (SPD) - change the multi until it says 667 (what ram is rated to)
Then move down to System Voltage Control:
DDR2 OverVoltage Control - +0.3v (stock 1.8v, so add 0.3v for 2.1v)
FSB OverVoltage Control - +0.1v (you will need to increase this when you go above 333 FSB, it will ensure stability)
(G)MCH OverVoltage Control - +0.1 (you will need to increase this when you go above 333 FSB, it will ensure stability)
CPU Voltage Control - 1.35v (if it is stable, try lowering it until it becomes unstable, then bring it back up 2 notches.
To change memory timings to match manufacturer's specs, you hit the [Ctrl + F1] in the main bios menu. This will unlock the advanced memory timings options so you can set the timing to 4-4-4-12.
