Common Platform Error Record @ fffffa80062cb038
Record Id : 01cdf988d455e0b1
Severity : Fatal (1)
Length : 672
Creator : Microsoft
Notify Type : PCI Express Error
Timestamp : 1/23/2013 16:44:25 (UTC)
Flags : 0x00000000
Section 0 : PCI Express
Descriptor @ fffffa80062cb0b8
Section @ fffffa80062cb148
Offset : 272
Length : 208
Flags : 0x00000001 Primary
Severity : Recoverable
Port Type : Root Port
Version : 1.1
Command/Status: 0x4010/0x0507
Device Id :
VenId:DevId : 8086:340a
Class code : 030400
Function No : 0x00
Device No : 0x03
Segment : 0x0000
Primary Bus : 0x00
Second. Bus : 0x00
Slot : 0x0000
Dev. Serial # : 0000000000000000
Express Capability Information @ fffffa80062cb17c
Device Caps : 00008021 Role-Based Error Reporting: 1
Device Ctl : 0107 ur FE NF CE
Dev Status : 0003 ur fe NF CE
Root Ctl : 0008 fs nfs cs
AER Information @ fffffa80062cb1b8
Uncorrectable Error Status : 00004020 ur ecrc mtlp rof uc ca CTO fcp ptlp SD dlp und
Uncorrectable Error Mask : 00000000 ur ecrc mtlp rof uc ca cto fcp ptlp sd dlp und
Uncorrectable Error Severity : 00062010 ur ecrc MTLP ROF uc ca cto FCP ptlp sd DLP und
Correctable Error Status : 00000000 adv rtto rnro dllp tlp re
Correctable Error Mask : 00000000 adv rtto rnro dllp tlp re
Caps & Control : 00000005 ecrcchken ecrcchkcap ecrcgenen ecrcgencap FEP
Header Log : 00000000 00000000 00000000 00000000
Root Error Command : 00000000 fen nfen cen
Root Error Status : 00000000 MSG# 00 fer nfer fuf mur ur mcr cer
Correctable Error Source ID : 00,00,00
Section 1 : Processor Generic
Descriptor @ fffffa80062cb100
Section @ fffffa80062cb218
Offset : 480
Length : 192
Flags : 0x00000000
Severity : Informational
Proc. Type : x86/x64
Instr. Set : x64
CPU Version : 0x00000000000106a5
Processor ID : 0x0000000000000006
