sarge05
- Feb. 2005
hi, endlich ist es soweit
SBXF_PCDVT_LB_2_15_0003
Filename: SBXF_PCDVT_LB_2_15_0003.exe
This download is a driver providing Microsoft® Windows Vista™ 64-bit and Windows Vista 32-bit support for Creative Sound Blaster® X-Fi™ series of audio devices. For more details, read the rest of this web release note.
This download supports the following audio devices only:
Creative Sound Blaster X-Fi XtremeMusic
Creative Sound Blaster X-Fi XtremeGamer
Creative Sound Blaster X-Fi Platinum
Creative Sound Blaster X-Fi Fatal1ty®
Creative Sound Blaster X-Fi Elite Pro
Current release features:
X-Fi Crystalizer™
X-Fi CMSS®-3D
MIDI Playback
EAX® Effects
PCM stereo output through Optical Out
Line-in connectivity
SPDIF passthrough is supported on both Vista 32-bit and Vista 64-bit
Recording capabilities.
Known issues:
This driver does not support the following:
Decoding of Dolby® Digital and DTS™ signals
DVD-Audio
DirectSound®-based EAX games
6.1 speaker mode
Applications from the original Sound Blaster X-Fi CD (for Windows XP) will not work with this download.
Requirements:
Windows Vista 64-bit or Windows Vista 32-bit
Creative Sound Blaster X-Fi audio devices listed above.
Notes:
Do not install this driver for Sound Blaster X-Fi Xtreme Audio.
To install the driver, do the following:
Download the SBXF_PCDVT_LB_2_15_0003.exe file onto your local hard disk.
Double-click the downloaded file.
Follow the instructions on the screen.
To uninstall the driver, do the following:
Click Start -> All Programs -> Control Panel.
Double-click the Device Manager icon.
Double-click the Sound, video and game controllers option.
Right-click the Creative SB X-Fi option, and select Uninstall.
The Confirm Device Uninstall dialog box appears.
Select the Delete the driver software for this device option.
Note: This check box must be selected to avoid reinstallation issues.
Click the OK button.
Restart your computer.
To reinstall the driver, do the following:
When the message You must restart your computer to apply these changes appears, click the Restart Later button.
