Bullet Tooth
- Mai 2008
Der Catalyst in der Version 9.2 ist da!
Catalyst Downloads XP/Vista 32 und 64 bit
Changelog:
Performance Improvements
Catalyst™ 9.2 brings performance benefits in several cases where framerates are
CPU-limited. Some measured examples are:
• Crysis DX10 gains up to 20%
• Crysis Warhead DX10 gains up to 20%
• World in Conflict gains up to 5%
Resolved Issues for the Windows Vista Operating System
This section provides information on resolved issues in this release of the ATI
Catalyst™ Software Suite for Windows Vista. These include:
• Catalyst Control Center now enables Anisotropic Filtering for DirectX 10
applications.
AMD Chipset Product Support
ATI Radeon™ HD 3300 Series ATI Radeon™ Xpress 3200 CrossFire
ATI Radeon™ HD 3200 Series AMD 690 Series Chipset
ATI Radeon™ 3100 Series AMD 580X Series Chipset
ATI Radeon™ 3000 Series ATI Radeon™ Xpress 1150 Series
ATI Radeon™ 2100 Series ATI Radeon™ Xpress 1100 Series
ATI Radeon™ X1250 Series ATI Radeon™ Xpress 200 Series
ATI Radeon™ X1200 Series ATI Radeon™ Xpress 1250 Series
Note: When installing the Catalyst™ Vista driver for Windows Vista,
the user must be logged on as Administrator or have Administrator
rights in order to successfully complete the installation of the Catalyst™
Vista driver.
ATI Catalyst™ Release Note 5
• Resolved Catalyst Control Center displaying the following warning message
“The Catalyst Control Center is not supported by the driver version.”
• Catalyst Control Center, Display Manager correctly shows connected monitor
maximum refresh rates
• Catalysts Control Center, component video pixel format settings are retained
on system restart
• Minor screen corruption no longer occurs at the top left of some Samsung
panels when connected to ATI Radeon HD 3200 Graphics
• In Call of Duty 4, some intermittent game corruption no longer occurs when
soften smoke edges is enabled
• Resinstalling the display driver using the INF method on a multi-display (ATI
Radeon HD 3870 X2, Radeon HD 3870) system does not cause the operating
system to fail
• Resolved minor flickering in the playback of a Blu-ray title that may be
noticed when moving to the extended desktop
• Catalyst Control Center, Crossfire Overdrive, changing the GPU Clock and
Memory Clock from the default settings no longer causes a failure in the Test
Custom Clocks test
• With Anti-Alias enabled Doom3 no longer intermittently fails to start on some
Crossfire systems
• Enemy Territory: Quake Wars corruption observed in the globe in the main
menu no longer occurs
• The display driver no longer fails to load on some systems with more than 8
GB of system RAM
• Catalyst Control Center, some HDMI monitor are not longer incorrectly
reported back as DVI
• Resolved video displaying in black and white when playing back high bitrate
AVCHD files
• Playing back some Blu-ray content with video acceleration disabled on
Cyberlink Power DVD_Cinema no longer results in no video rendering
• Fixed H.264 videos not rendering (black video) when Closed Captioning was
enabled
• Overlay Theater Mode now enables with a component video or composite
video in extended modes
• Playing some Blu-ray DVD titles on PowerDVD no longer shows the lower
portion of the player window intermittently appear shaky when playing Special
Features
• Some video shake is no longer observed when fast forwarding with certain
Blue-ray titles
• Resolved intermittent system instability with catalyst 8.12 and some ATI
Radeon HD 4800 CrossFire configurations
• Video tearing no longer noticed when playing back some DVD titles on
WinDVD with all hardware acceleration options enabled
ATI Catalyst™ Release Note 6
• Creating any type of an OpenGL 3.0 context (normal or forward compatible)
and then requesting the version string no longer causes the driver to stop
responding
• The OS is no longer unstable while running auto-tune when Crossfire is
enabled
Resolved Issues for the Windows XP Operating System
Catalyst™ Software Suite for Windows XP. These include:
• System instabilities no longer happens after mode switching in extended
mode while playing some copy protected DVDs
• Catalyst Control Center, CrossFire option can no longer be toggled on/off during
playback of video on a CrossFire enabled system
responding
• With Overlay Theater Mode and stretched desktop enabled, dragging media
player to extended desktop no longer shows corruption or causes system
instability
• High CPU usage and choppy playback issues have been resolved during
Blu-ray playback on WinDVD 9
• Catalysts Control Center, component video pixel format settings are now
retained on system restart
Known Issues Under the Windows Vista Operating System
This section provides information on known issues that may be experienced
under the Windows Vista operating system with the latest version of Catalyst™.
These include:
• AVIVO converter may fail to convert h.264 avi video to another format
• “Unsupported file formats” error message dialog may occur when selecting
H.264,.mp4 and VC1 file formats
• “CCC Host application...” error message dialog may occur when cancelling a
transcoding process
• Output media file size differs after transcoding multiple times to the same format
• Catalyst Control Center, advanced color page is grayed out and preview is
blank on some Radeon ASICS
• Drop frames may be noticed when playing interlaced DVD content
• The ATI AVIVO video transcoder does not currently use GPU acceleration
under Windows Vista 64-bit edition
• Catalyst Control Center: error message dialog 'CCC Host Application' may be
displayed when cancelling a transcoding process
ATI Catalyst™ Release Note 7
Known Issues Under the Windows XP Operating System
The following section provides a summary of open issues that may be experienced
under the Windows XP operating system in the latest version of Catalyst™.
These include:
• Transcoding a VOB DVD file (18min source file) results in 2.27min output
file
• Transcoding falls back to CPU after transcoding to DVD/ MPEG2 multiple
times in XP
• Media files transcoded using CPU instead of GPU in XP MCE OS
• AVIVO Video color settings may fail to be applied in the video when played
using PowerDVD
• Mode switching while playing videos with WinDVD7 may cause the video
color to become darker
Changelog:
applications.
Vista driver.
on system restart
system to fail
Custom Clocks test
Crossfire systems
GB of system RAM
AVCHD files
enabled
Features
Blue-ray titles
responding
enabled
responding
instability
These include:
transcoding process
These include:
file
times in XP
using PowerDVD
