CPU übertakten:D
crime954
Juli 2009
hallo ich will mein pc im bios übertakten aber er will das einfach net das fenster ist so grau und ich weiß net wie ich das änder kann meine daten über dem rechner
Operating System System Model
Windows XP Professional Service Pack 2 (build 2600)
Install Language: Deutsch (Deutschland)
System Locale: Deutsch (Deutschland) FUJITSU SIEMENS M2R-FVM 1.XX
Enclosure Type: Desktop
Processor a Main Circuit Board b
2,60 gigahertz AMD Pentium 4
256 kilobyte primary memory cache
1024 kilobyte secondary memory cache
64-bit ready
Multi-core (2 total)
Not hyper-threaded Board: ASUSTeK Computer INC. M2R-FVM 1.XX
Bus Clock: 200 megahertz
BIOS: Phoenix Technologies, LTD FUJITSU SIEMENS M2R-FVM 0501 08/31/2006
Drives Memory Modules c,d
250,05 Gigabytes Usable Hard Drive Capacity
166,23 Gigabytes Hard Drive Free Space
GRC C5UF8DY SCSI CdRom Device [CD-ROM drive]
Optiarc DVD RW AD-7170A [CD-ROM drive]
Generic 2.0 Reader -CF USB Device [Hard drive] -- drive 1
Generic 2.0 Reader -MS USB Device [Hard drive] -- drive 4
Generic 2.0 Reader -SD USB Device [Hard drive] -- drive 3
Generic 2.0 Reader -SM USB Device [Hard drive] -- drive 2
Generic 2.0 Reader -xD USB Device [Hard drive] -- drive 5
ST3250820AS [Hard drive] (250,06 GB) -- drive 0, SMART Status: Healthy 1024 Megabytes Usable Installed Memory
Slot 'DIMM_A1' is Empty
Slot 'DIMM_B1' is Empty
Slot 'DIMM_A2' has 512 MB
Slot 'DIMM_B2' has 512 MB
Local Drive Volumes
c: (NTFS on drive 0) 250,05 GB 166,23 GB free
Network Drives
None detected
Users (mouse over user name for details) Printers
local user accounts last logon
timo 10.07.2009 03:29:54 (admin)
local system accounts
Administrator never (admin)
Gast 28.06.2009 13:00:55
Hilfeassistent never
SUPPORT_388945a0 never
DISABLED Marks a disabled account; LOCKED OUT Marks a locked account
None detected
Controllers Display
ATI IDE Controller
Primärer IDE-Kanal [Controller] (2x)
Sekundärer IDE-Kanal [Controller]
Standard-Zweikanal-PCI-IDE-Controller NVIDIA GeForce 7300 SE [Display adapter]
(Standardmonitor)
Medion MD1786LH [Monitor] (15,7"vis, s/n 220640081, Mai 2002)
Bus Adapters Multimedia
ATAR5PSR IDE Controller
Standard erweiterter PCI-zu-USB universeller Hostcontroller
Standard OpenHCD USB-Hostcontroller (5x) Pinnacle PCTV 310i PAL Stereo DVB-T Capture Device
Realtek High Definition Audio
Virus Protection [Back to Top] new Group Policies
Avira AntiVir PersonalEdition Version 8.0.1.30
Virus Definitions Version Up To Date
Realtime File Scanning On
None discovered
Communications Other Devices
1394-Netzwerkadapter
Realtek RTL8139/810x Family Fast Ethernet NIC
primary Auto IP Address: 192.168.2.102 / 24
Gateway: 192.168.2.12
Dhcp Server: 192.168.2.12
Physical Address: 00:18:F3:93:5A:83
Networking Dns Server: 192.168.2.12
Texas Instruments OHCI-konformer IEEE 1394-Hostcontroller
HID-konformes Benutzersteuergerät
HID-konformes Gerät
USB-HID (Human Interface Device) (3x)
Agfa ePhoto 1280-Digitalkamera
HID-Tastatur [Keyboard]
HID-konforme Maus [Mouse]
USB-Massenspeichergerät
USB-Root-Hub (6x)
USB-Verbundgerät
xd ist mal wirklich alles würde mich freun wenn ihr mir helfen könnt
habe schon gehört das es ne sperre gibt aber habe noch keine beitrak von meine gefunden darum habe ich das nun gestelt danke schonmal
Sieht ziemlich schlecht für OC aus - es dürfte sich um einen FUJITSU SIEMENS Komplettrechner mit OEM Asus-Board handeln. Da wird der Umfang der BIOS-Einstellungen stark beschnitten bis völlig unzugänglich sein.
exakt - auch ein bios-update wird da i.d.R. nicht weiterhelfen.
ehrlich gesagt würde es auch nichts bringen ...ob jetzt PIV @ 2,6 o. 3,0 GHz
wirst du in der praxis kaum - gar nicht merken.
auch bei der graka lohnt sich nicht ein übertakten.
hm erstmal danke für die schnelle antwort allso ich sag so ich kann auf vieles im bios drauf gehn aber nur net da wo ich aus 2,6ghz zumbeispiel 3,0ghz machen kann das ist das einzigste was im bios gespert ist .....hm
hm bloos kein geld:D bin schüler^^
und irgendwie muss man die sperre ja raus machen können
Yup, Mami & Daddy um 50€ anbetteln :evillol:
Mit einem BIOS-Flash wirst Du das Board vermutlich killen, wenn es kein spezielles MOD-BIOS von Deiner Version gibt.
Letzte Möglichkeit wäre per Software übertakten.
allso gibts keine möglichkeit das zumachen?
allso weiß keiner wie mann die sperre raus macht oder
meint ihr wenn ich es mach das alles duchbrent?
Du kannst es per OC Tools machen. Aber naja.
Du könntest nach einem Mod-BIOS suchen, aber ob es funktionieren wird, hm glaub ich kann dir keiner beantworten...Es könnte funktionieren, aber gerade so gut auch dein Mobo im Grab liegen. Ich hatte auch mal diese Idee da mein Mobo auch OEM Opfer ist, aber schliesslich hab ich mich entschlossen ein anderes Mobo zu kaufen, da mir das andere zu Riskant ist.
Kannst ja deinen Eltern was vorgaukeln dass dein PC nicht mehr funktionieren wird wenn du das und das nicht hast etc, aber auch nur wenn sie gar nichts davon kennen hehe:;)
Zieh den 4Pin stecker der CPU raus und zeig deiner MUTTER!!!<----- das dein Rechner nich hochfährt
Anbei kannste ja sagen : Oh nein ich werde nie wieder im Internet für die Schule recherchieren können ^^
So zack neu kaufen gut ist...
MFG
