Alternate 1
Linux Anfänger Problem
also bei lsmod kommt raus:
cb
parport_pc 36260 0
lp 12324 0
parport 37832 3 ppdev,parport_pc,lp
joydev 13120 0
uvcvideo 58116 0
compat_ioctl32 2304 1 uvcvideo
iwl4965 105844 0
videodev 29440 1 uvcvideo
v4l1_compat 15492 2 uvcvideo,videodev
v4l2_common 18304 2 uvcvideo,videodev
snd_hda_intel 344728 1
iwlwifi_mac80211 219108 1 iwl4965
nvidia 7825536 36
snd_pcm_oss 42144 0
snd_mixer_oss 17920 1 snd_pcm_oss
snd_pcm 78596 2 snd_hda_intel,snd_pcm_oss
cfg80211 15112 1 iwlwifi_mac80211
snd_page_alloc 11400 2 snd_hda_intel,snd_pcm
snd_hwdep 10500 1 snd_hda_intel
sr_mod 17956 0
i2c_core 24832 1 nvidia
cdrom 37408 1 sr_mod
battery 14212 0
snd_seq_dummy 4868 0
snd_seq_oss 35584 0
snd_seq_midi 9376 0
snd_rawmidi 25760 1 snd_seq_midi
snd_seq_midi_event 8320 2 snd_seq_oss,snd_seq_midi
snd_seq 54224 6 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq_midi_event
container 5632 0
video 19856 5
output 4736 1 video
psmouse 40336 0
snd_timer 24836 2 snd_pcm,snd_seq
snd_seq_device 9612 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_rawmidi,snd_seq
serio_raw 7940 0
intel_agp 25492 0
pata_acpi 8320 0
ata_generic 8324 0
button 9232 0
shpchp 34452 0
pci_hotplug 30880 1 shpchp
ac 6916 0
snd 56996 13 snd_hda_intel,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_hwdep,snd_seq_dummy,snd_seq_oss,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
pcspkr 4224 0
iTCO_wdt 13092 0
iTCO_vendor_support 4868 1 iTCO_wdt
acer_acpi 18112 0
led_class 6020 1 acer_acpi
evdev 13056 6
agpgart 34760 2 nvidia,intel_agp
soundcore 8800 1 snd
wmi_acer 9644 1 acer_acpi
ext3 136712 1
jbd 48404 1 ext3
mbcache 9600 1 ext3
sg 36880 0
sd_mod 30720 3
usbhid 31872 0
hid 38784 1 usbhid
ahci 28420 2
ata_piix 19588 0
libata 159344 4 pata_acpi,ata_generic,ahci,ata_piix
scsi_mod 151436 4 sr_mod,sg,sd_mod,libata
ehci_hcd 37900 0
uhci_hcd 27024 0
usbcore 146028 5 uvcvideo,usbhid,ehci_hcd,uhci_hcd
thermal 16796 0
processor 36872 4 acpi_cpufreq,thermal
fan 5636 0
fbcon 42912 0
tileblit 3456 1 fbcon
font 9472 1 fbcon
bitblit 6784 1 fbcon
softcursor 3072 1 bitblit
fuse 50580 3
und bei alsaconf steht command not found
tut mir leid etwas schlecht rauskopiert
Wie ichs sehe ist das Modul geladen. ist alsa-utils installiert? Der Name könnte bissl unterschiedlich sein, da ich hier vor einem Debian Rechner sitze und kein Ubuntu zur Hand habe.
und alsaconf gibt's nicht?
Hast du mit root Rechte ausprobiert? Bei mir, wenn ich den Befehl alsaconf nur mit meinem normalen User eingebe, gibt's dann nicht. Du musst mit root ausführen.
Die genauere Fehlermeldung ist hilfreich, da ich ja nicht vor deinem Computer sitze, sondern am anderen Leitungsende. Kein Ton ist keine Fehlermeldung.
Überprüf nochmal (Photon hat oben schon erwähnt) dein Alsamixer bzgl. Mute und Unmute.
Anstelle von Einzeilerantworten sollten du dich mit dem Thema kurz beschäftigen.
Ein Forum ist nunmal kein chat und wenn du so einfache Sachen nicht hinkriegst, solltest du bei windows bleiben.
Diese Anleitung hab ich schon mehrmals durchgemacht aber ich hab es trotzdem nicht geschafft. Vielleicht versuche ich es in ein paar Monaten wenn mein notebook kompatibler zu linux ist.
Genau darin liegt das Problem.
Wir wissen nicht wo es hackt und können auch nicht helfen.
Ein geht nicht ist einfach keine Grundlage auf der man dir helfen kann.
Ich habe besseres zu tun als dein Problem zu erraten.
Es kann natürlich sein, dass die hardware zu neu ist.
Man braucht dann kernel patches und Sachen, die ein wenig mehr ausprobiert werden müssen.
Wir wissen ja nicht mal welches notebook es ist.
Du siehst, wir drehen uns hier im Kreis.
Manch einem muss man eben die Sachen immer aus der Nase ziehen weil sie schlichtweg keine ahnung haben was alles notwendig ist zu wissen um zu helfen. Ich kann auch nicht in die Werkstatt mein Auto bringen und dem Mechaniker einfach sagen : "Das Auto geht nicht". Er würde mich auch für bescheuert halten :) . Leider versuchen es immer wieder welche und hoffen auf Lösungen. Wenn es nicht geht geht es eben nicht :)
ich habe jetzt die Möglichkeit entdeckt, über "Yast - Partitionierung" meine Windows-Partitionen nicht beim Systemstart einhängen zu lassen.
Genau meine Welt und so spare ich mir das, bisher vergebliche, suchen nach einem entsprechenden Befehl für die Konsole.;)
Allerdings nimmt er die Option "kann vom Benutzer eingehangen werden" nicht an, sondern das Einhängen geht nur als "root".
Reicht es wenn ich manuell "sync" in die "/etc/fstab" schreibe, so wie es bei meinem Diskettenlaufwerk steht?
"/dev/fd0 /media/floppy auto noauto,user,sync 0 0"
Gruß der LinuxTester
mit YaST? Der ist doch mit Konsole grad überfordert, da die Befehle vergeblich zu suchen sind.
Aber es gibt ja noch google oder dergleichen.
@jimmi:
Sieh doch bitte mal nach ob Alsa deine Soundkarte richtig ausgewählt hat. Ich hatte mit Feisty mal das Problem das die Erkennung nicht meine HDA-Intel Karte sonder die TV-Karte als Primär-Soundausgabe gewählt hat.
Schau mal im Audiomixer von KDE oder Gnome (steht im ubuntuusers wiki wo man die findet) ob HDA_Intel gewählt ist oder was anderes. Dann schauen wir mal weiter.
@Sug82: Das mit alsaconf ist mal wieder ein Ubuntu-only Bock. Es gibt kein alsaconf :rolleyes:
Danke für den Tip e-Laurin!
Sug82 hat geschrieben:
Und weißt du was sync überhaupt macht?
"sync schreibt die gepufferten Blöcke auf die Platte"
"Linux unterhält zur Optimierung der Festplatten und Diskettenzugriffe ein Blockdepot (Cache), in dem einige Datenblöcke des Massenspeichers im Arbeitsspeicher bereitgehalten werden."
Da nun das Disketten-LW nach dem Systemstart nicht eingehangen ist und trotzdem von jedem Benutzer gemounted werden kann, war mein erster Gedanke es hat was mit diesem Befehl zu tun.
Hört mir blos auf mit Google, wenn ich nicht schon graue Haare hätte dann wäre es nun soweit.;)
Allein die unterschiedlichen Auffasungen über die Methoden der Datensicherung(en) bringen mich durcheinander.
Kaum sage ich mir, das ist ne Möglichkeit kommt ein anderer und sagt - so geht es aber auch.
Na egal, ich mache es jetzt mit rsync(Grsync).
Noch bin ich nicht überfordert da ich die Konsole bisher kaum nutze, aber das kommt noch wenn ich bei Google das Stichwort "Apparmor" eingebe.:)
mMn nach ist dein User nicht in der für mount nötigen Gruppe eingetragen. Ich bin mir jetzt nicht sicher, ob die disk oder storage ist.
Du kannst es ja mal ausprobieren, ob du dann noch root-Rechte brauchst:
In Gruppe eintragen: gpasswd -a Username disk
Aus Gruppe austragen: gpasswd -d Username disk
