CORSAIR Marcus
Corsair Support
- Okt. 2021
Hier könnt ihr die aktuellen Release Notes von iCUE einsehen inkl. download.
Software Enhancements
- Discord Certified headsets will now appear with a ‘Certified’ tag under Voice and Audio > Input Device / Output Device
- Updated CPUID SDK to expand CPU and motherboard detection
- Certain icons and tooltips have been improved for a better overall user experience
- Numbers have been removed from duplicate devices of the same type but may still appear due to
- firmware updates done with a hub – this will be fixed in a future release
- iCUE will no longer be stuck if the user cancels a request to uninstall
- iCUE installer window can now be dragged across different screens
- Resolved an issue with the sliders associated with Scenes creation
- Lighting Effects are now displayed in the same alphabetical order across all device types
- Resolved various translation text errors
HID Product Enhancements
- Watercolor will now properly show the options for lighting customization
- Holding down the Sniper button will no longer keep it depressed after the button release
- The mute indicator on a keyboard will now properly turn off when mute is disabled while using iCUE
- Resolved an issue with the Undo feature after recording a macro• The Audio Visualizer lighting effect for K100 now displays properly – this effect still requires a CORSAIR headset to display properly
- Win Lock indicator no longer displays as ‘OFF’ on K57 if enabled
- Resolved an issue with the toggle function for Nexus button remaps
- Improved the scaling of the clock widget for Nexus
- Text assignments will no longer disappear from Nexus on restart
DIY Product Enhancements
- The Turbo icon for Elite LCD Coolers has been updated
- Resolved an issue with Lighting Effect – Visor not displaying properly on 8-LED fans
- The 12V output on PSU is now properly labeled when using iCUE with Simplified and Traditional Chinese languages
- Alerts tab for coolers will now properly enable Emergency Shutdown by default at 60 degrees Celsius
- Updating GPU drivers will cause no longer cause an error with the Elite LCD display
- Fixed the text spacing and size issues for Elite LCD when numbers only have three digits.
