ATI-TOOL 0.0.21 ist da!
- Ersteller BodyLove
Fox Azzameen
- März 2003
und für was ist das sonst noch gut? Hat man da auch was von mit einer "alten" Radeon, z.B. 9600Pro?
Fox Azzameen
- März 2003
/edit: irks, Doppelpost - sorry! Hatte grad irgendwie ein Problem mit dem Internet! Nach neu einwählen ist das dann wohl passiert...
- Apr. 2003
Schaut einer mal auf der Seite nach dem Changelog?
Wizzard schrieb:ersion 0.0.21
Scan for Artifacts now makes a log entry every 15 minutes.
Added and tested X800SE PCI-E overclocking support.
When the main window is partly or completely off screen when launched, it will be moved to be visible.
Render window requires a hw accelerator + running driver.
Disabled maximizing/minimizing of render window.
Moved I2C access code into kernel driver.
Added option to set video card PCI latency
Improved theme support (more like enabled it).
Added option to create desktop icon after install.
Added RV410 support.
Added Video Memory Timings Editor (not in 0.0.21 release but in next dev. build)
Added option to disable the tray icon (icon will always be visible while ATITool is initializing).
Added Gamma Control
Added experimental "Remove 9000/9200/9550/9600 clock lock"
Trying to overwrite the default profile now gives an error msg.
Added option to limit log file size.
Bugfixes to the installer.
Added fan control for X800.
Added options to disable Direct3D error messages.
Added shared memory, other applications can now get ATITool data.
Fixed settings window popping up in wrong place.
Statically linked version - distribution is now only 820 KB in size!
Updated Kernel Mode driver - getting ready to port to 64 Bit.
Tray icon is automatically recreated when explorer crashes
If the tray icon can't be created (possible during windows startup, explorer is not running yet) just continue loading and create the icon as soon as explorer is ready.
Added text field with temperature to main window.
Added support for Radeon 9550 - these cards are overclocking locked. Use the softmod drivers.
Added support for sending clock/temp. data to MBM
Added option to log temperatures
Added overclocking/temp. monitoring support for X600.
Added temp. monitoring support for 9800 PRO on XT PCB with temp. chip.
Profile selection is no longer saved on exit, but on change.
room.x now included in executable.
Fixed bug where the tray temperature display would get stuck on desktop resize.
3D detection seems to have issues with DirectX 9.0C beta - this will not be addressed until the final version of DX9.0C is out.
Fixed bug with temperature detection
Fixed bug where find max. would try too high clockrates when clock frequency limits are enabled.
Added warning if D3D Debug Runtimes are active.
Screensaver will be disabled during 'find max' and 'scan for artifacts'
Added 'add to start menu' all users/current user
Tweaked*3D detection, will*now work with UT2K4's d3d9 renderer
Added option to change font/color of temperature in systray
Added temperature monitoring for ASUS cards, thanks Peter
Added extra checks to low-level hardware code
- Apr. 2003
Für die älteren Karten scheint es keine großen Veränderungen zum 0.0.20 zu geben. Ich kan aber hiermit sagen, dass die Lüftersteuerung einwandfrei funktioniert. Die Temps gehen auch rasant nach unten (~10°C), wenn ich auf 100% stelle, und das beim Inet!
Ich werde mal jetzt den max. Coretakt ausloten, um zu schauen, wie gut es sich kühlen lässt...
I-T
- Jan. 2004
BodyLove schrieb:Für die älteren Karten scheint es keine großen Veränderungen zum 0.0.20 zu geben. Ich kan aber hiermit sagen, dass die Lüftersteuerung einwandfrei funktioniert. Die Temps gehen auch rasant nach unten (~10°C), wenn ich auf 100% stelle, und das beim Inet!
Was ich sehr genial finde ist das mit mimaler Erhöhung z.B. auf 50% die Karte beim 3D Test dauerhaft unter 70° bleibt und sich schon eine ganze Ecke höher takten läßt.
Die Karte ist dann immer noch nicht hörbar (es sei denn man hat einen wirklichen Silentrechner) und es waren gleich 20 Mhz mehr Core drin.
So kann man prima feststellen ob es sich lohnt zwecks OC einen neuen Kühler draufzuballern,oder ob die GPU nicht mehr mitmacht.
Und die Ultra-Silentfreaks können selbst für Windows noch weiter runterdrehen.
Mal sehn was bei 100% rauskommt.
spatz
- Feb. 2004
erstmal danke für die info .
also entweder spinn ich jetzt oder es ist möglich bei meiner 9800pro ( ! ) die temps auszulesen .
ich habe weder nen anderes bios drauf noch sonst irgendwas , es ist alles auf standard . trotzdem zeigt mir das tool unten die temperatur von gpu und temp-chip an ( nachdem ich es in den settings eingestellt habe ) .
verändern tun sich diese werte auch , also nen anzeigefehler scheints nicht zu sein .
btw , meine pro ist im xt layout mit r360er chip .
- Apr. 2003
Dumbo schrieb:Hallo,
wo muss ich was einstellen damit sich der Lüfter sich schneller dreht ?
Den irgendwie verstehe ich nich wie man das da einstellen muss !!
gruS
Wenn du dir das neue Tool heruntergeladen hast, dann musst du unter Settings, oben statt Overclocking, FanControl einstellen. Danach kannst du es dir manuell einstellen.
@Spatz
Verändern sich die Werte, wenn du auf Search for Artifacts klickst? Steigt die Temp an? Wenn ja, glückwunsch, da du einen R360 Design hast, besitzt deine Karte einen Sensor am PCB.
spatz
- Feb. 2004
ja die werte verändern sich ...
nur eine frage nebenbei , wie heiss darfn son chip werden ? das sind meine ersten erfahrungen in der hinsicht
edit :
steht ja auch im changelog drin dass es jetzt funzt mit dem tempauslesen ...
edit :
Twisterking
- Jan. 2004
Bei GPU's kann man IMHO allgemein IN ETWA eine Grenze von 90°C nehmen!
Aber heißer sollte die GPU dann wirklich nicht mehr werden!
idle, bzw. beim surfen etc. für ich langzeitmäßig 60-70°C nehmen!
Ist aber alles nur MEINE MEINUNG!
Keine Garantien auf irgendwas (auch NICHT auf diese Temps.)!
SaBoCB
- Aug. 2004
spatz schrieb:also entweder spinn ich jetzt oder es ist möglich bei meiner 9800pro ( ! ) die temps auszulesen .
Steht doch auch so da
Sascha
I-T
- Jan. 2004
Twisterking schrieb:Bei GPU's kann man IMHO allgemein IN ETWA eine Grenze von 90°C nehmen!
ATI gibt auf seiner Homepage 105° C als mamimalen Höchstwert für UNBEDENKLICHKEIT aus.
Bis dahin soll weder die Stabilität noch die Haltbarkeit negativ beeinflußt werden.
-RGC-excoutor
Banned
- Juni 2004
aber bei einer 9800pro kann man denn lüfterspeed nich regeln, oder?
