Fireplace
Mobile Footer Layer
COD5 Absturz beim Fortsetzen einer Mission
MightyGrave
Juli 2007
immer wenn ich meine Mission weiterspielen will lädt zwar alles aber wenn ich dann eine Taste zum starten drücke stürzt das Game ab und ich lande mit dieser Fehlermeldung in Windows:
load xanim "crew_truck_driver_drive_reaction".
Error: Could not load xanim "crew_truck_guy8_climbin".
Error: Could not load xanim "crew_truck_guy7_climbin".
Error: Could not load xanim "crew_truck_guy6_climbin".
Error: Could not load xanim "crew_truck_guy5_climbin".
Error: Could not load xanim "crew_truck_guy4_climbin".
Error: Could not load xanim "crew_truck_guy3_climbin".
Error: Could not load xanim "crew_truck_guy2_climbin".
Error: Could not load xanim "crew_truck_guy1_climbin".
Error: Could not load xanim "crew_truck_passenger_climbin".
Error: Could not load xanim "crew_truck_driver_climbin".
Error: Could not load xanim "ai_zombie_shot_leg_right_2_crawl".
Error: Could not load xanim "ai_zombie_shot_leg_left_2_crawl".
Error: Could not load xanim "ch_climb_tree_a".
Error: Could not load xanim "ai_zombie_traverse_crawl_v1".
Error: Could not load xanim "ai_zombie_traverse_v2".
Error: Could not load xanim "ai_zombie_traverse_v1".
Error: Could not load xanim "ai_zombie_idle_crawl_base".
Error: Could not load xanim "ai_zombie_idle_base".
Error: Could not load xanim "ai_zombie_idle_crawl".
Error: Could not load xanim "ai_zombie_idle_v1".
Error: Could not load xanim "ai_mg_shoulder_run".
Error: Could not load xanim "ai_mg_shoulder_run2crouch".
Error: Could not load xanim "ai_mg_shoulder_crouch_idle".
Error: Could not load xanim "ai_mg_shoulder_run2stand".
Error: Could not load xanim "ai_mg_shoulder_stand_idle".
Error: Could not load xanim "v_opelblitz_driverdoor_climbout".
Error: Could not load xanim "step_up_low_wall".
Error: Could not load xanim "jump_across_100".
Error: Could not load xanim "p_makinraid_hatch".
Error: Could not load xanim "crew_sherman_passenger9_combatidle_player".
Error: Could not load xanim "crew_sherman_passenger8_combatidle_player".
Error: Could not load xanim "crew_lvt4_peleliu1_character9_player".
Error: Could not load xanim "crew_lvt4_peleliu1_character5_player".
Error: Could not load xanim "crew_lvt4_peleliu1_character4_player".
Error: Could not load xanim "pb_prone_crawl_right_hold_satchel".
Error: Could not load xanim "pb_prone_crawl_left_hold_satchel".
Error: Could not load xanim "pb_prone_crawl_back_hold_satchel".
Error: Could not load xanim "pb_prone_crawl_hold_satchel".
Error: Could not load xanim "pb_crouch_hold_run_right_satchel".
Error: Could not load xanim "pb_crouch_hold_run_left_satchel".
Error: Could not load xanim "pb_crouch_hold_run_back_satchel".
Error: Could not load xanim "pb_crouch_hold_run_satchel".
Error: Could not load xanim "pb_hold_run_left_satchel".
Error: Could not load xanim "pb_hold_run_right_satchel".
Error: Could not load xanim "pb_hold_run_back_satchel".
Error: Could not load xanim "pb_hold_run_satchel".
Error: Could not load xanim "pb_sprint_hold_satchel".
Error: Could not load xanim "pb_crouch_hold_idle_satchel".
Error: Could not load xanim "pb_hold_idle_satchel".
Error: Could not load xanim "pb_prone_hold_satchel".
Error: Could not load xanim "pt_hold_prone_throw_satchel".
Error: Could not load xanim "pt_hold_throw_satchel".
lod_info doesn't have a spawn function
'0' is not a valid value for dvar 'bg_shock_viewKickPeriod'
Domain is any number from 0.001 to 1000
'0' is not a valid value for dvar 'bg_shock_soundFadeInTime'
'0' is not a valid value for dvar 'bg_shock_soundFadeOutTime'
Error: Could not load xmodel "".
=== G_LoadGame ===
WARNING! Map too large for complete burn map coverage. reducing burn map size
AI (entity 265, origin 2375.4 9109.3 7.5) couldn't find path to goal.
Connecting player #0 has a zero GUID
Going from CS_FREE to CS_CONNECTED for (num 0 guid 0)
Received packet 0 of stats data
Received packet 1 of stats data
Received packet 2 of stats data
Received packet 3 of stats data
Received packet 4 of stats data
Received packet 5 of stats data
Received packet 6 of stats data
DynEnt_WriteGameState wrote 2 bytes
Setting state to CA_LOADING in CL_DownloadsComplete
Setting state to CA_LOADING in CL_InitCGame
Player 0 no longer burning at time: 0
Error: Could not load material "nightvision_overlay_goggles".
Error: Could not load material "decode_characters".
Error: Could not load material "decode_characters_glow".
Error: Could not load material "killicondied".
Error: Could not load material "killiconcrush".
Error: Could not load material "killiconfalling".
Error: Could not load material "killiconsuicide".
Error: Could not load material "killiconheadshot".
Error: Could not load material "killiconmelee".
LOADING... collision map
LOADING... graphics
LOADING... maps/pel2.d3dbsp
Foliage: --------------------------
Foliage: smodelCount = 15722
Foliage: foliage model count = 15722 (max=16384)
Foliage: sizeof(g_modelInfos) = 16384, element size = 1
vertex stream 2: --------------------------
vertex stream 2: needs 964468 bytes
vertex stream 2: vertex buffer allocate ok
LOADING... game media
LOADING... - textures
Error: Could not load material "headicondisconnected".
Error: Could not load material "headiconyouinkillcam".
Error: Could not load material "objective_up".
Error: Could not load material "objective_down".
Error: Could not load material "compassping_friendly".
Error: Could not load material "objective_friendly_chat".
Error: Could not load material "compassping_enemy".
Error: Could not load material "compass_radarline".
Error: Could not load material "compass_objpoint_airstrike_busy".
Error: Could not load material "compass_objpoint_airstrike_friendly".
Error: Could not load material "hud_flashbangicon".
LOADING... - models
LOADING... - items
LOADING... - inline models
LOADING... - server models
Error: Could not load fx "vehicle/treadfx/fx_treadfx_sherman_mud".
Error: Could not load fx "explosions/artilleryexp_dirt_brown_test".
Error: Could not load fx "weapon/grenade/fx_american_smoke_grenade".
Error: Could not load fx "misc/fx_flare_sky_white_10sec".
Error: Could not load fx "weapon/grenade/fx_gas_grenade_22sec".
Error: Could not load fx "weapon/molotov/fx_molotov_burn_trail".
Error: Could not load fx "weapon/molotov/fx_molotov_burn_trail2".
Error: Could not load fx "weapon/molotov/fx_molotov_wick".
Error: Could not load fx "env/fire/fx_fire_player_sm_smk_2sec".
Error: Could not load fx "treadfx/heli_dust_default".
Error: Could not load fx "treadfx/heli_water".
Error: Could not load fx "smoke/smoke_trail_white_heli".
Error: Could not load fx "smoke/smoke_trail_black_heli".
Error: Could not load fx "fire/fire_smoke_trail_L".
Error: Could not load fx "fire/jet_afterburner".
Error: Could not load fx "vehicle/water/fx_wake_lvt_churn".
LOADING... - game media done
LOADING... clients
Error: Could not load menufile "ui/scriptmenus/briefing.menu".
Error: Could not load menufile "ui/scriptmenus/loadout_splitscreen.menu".
*** CLIENT SPAWN 0 script_brushmodels 0 script_models.
Error: Could not load material "terrain_scorch_bark".
Error: Could not load material "terrain_scorch_brick".
Error: Could not load material "terrain_scorch_carpet".
Error: Could not load material "terrain_scorch_cloth".
Error: Could not load material "terrain_scorch_concrete".
Error: Could not load material "terrain_scorch_dirt".
Error: Could not load material "terrain_scorch_flesh".
Error: Could not load material "terrain_scorch_foliage".
Error: Could not load material "terrain_scorch_glass".
Error: Could not load material "terrain_scorch_gravel".
Error: Could not load material "terrain_scorch_ice".
Error: Could not load material "terrain_scorch_metal".
Error: Could not load material "terrain_scorch_paper".
Error: Could not load material "terrain_scorch_plaster".
Error: Could not load material "terrain_scorch_rock".
Error: Could not load material "terrain_scorch_snow".
Error: Could not load material "terrain_scorch_water".
Error: Could not load material "terrain_scorch_wood".
Error: Could not load material "terrain_scorch_asphalt".
Error: Could not load material "terrain_scorch_ceramic".
Error: Could not load material "terrain_scorch_plastic".
Error: Could not load material "terrain_scorch_rubber".
Error: Could not load material "terrain_scorch_cushion".
Error: Could not load material "terrain_scorch_fruit".
Error: Could not load material "terrain_scorch_paintedmetal".
Error: Could not load material "terrain_scorch_player".
Error: Could not load material "terrain_scorch_tallgrass".
CL_InitCGame: 0.60 seconds
Com_TouchMemory: 0 msec. Using sum: -1852700415
Hiding channel: gamenotify
Hiding channel: obituary
Adding channel: gamenotify
Adding channel: obituary
Hiding channel: boldgame
Adding channel: boldgame
Hiding channel: subtitle
Adding channel: subtitle
Hiding channel: coopinfo
Adding channel: coopinfo
Fade in 34771 1250
Too many visible static models - not drawing static model
R_MAX_SKINNED_CACHE_VERTICES((1024 * 192)) exceeded - not drawing surface
MAX_SCENE_SURFS_SIZE(131072*2) exceeded - not drawing surface
Unhandled exception caught
Habe den neuesten Nvidia Graka Treiner und Direct X drauf.
Ich hoffe ihr habt eine idee.
DAnke
Neu installieren bzw. vielleicht Patch installiert ohne die dafür "richtige" exe ?
