TeamViewer Motive 4
Java java.net.SocketException: Socket is closed
F
Furtano
Nachdem ich die erste Eingabe an den Server schicke bekomme ich die Meldung:
PHP:
Apr 29, 2012 9:24:21 PM parksockets.Client send
Schwerwiegend: null
Eingabe:
	at java.net.Socket.setSoTimeout(Socket.java:1089)
	at parksockets.Client.send(Client.java:57)
	at parksockets.ParkSockets.main(ParkSockets.java:62)
ParkSockets.java
PHP:
 * To change this template, choose Tools | Templates
 * and open the template in the editor.
package parksockets;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
import java.net.InetAddress;
import java.net.Socket;
import java.util.logging.Level;
import java.util.logging.Logger;
 * @author chris
public class Client {
    public int port;
    public InputStream in;
    public OutputStream out;
    public  Socket sock;
    public Client() {
        port = 6700;
    public void startClient() {
        try {
            //InetAddress ip = InetAddress.getLocalHost();
            sock = new Socket("127.0.0.1", port);
            in = sock.getInputStream();
            out = sock.getOutputStream();
            // Verbindungen schliessen
            in.close();
            out.close();
            sock.close();
        } catch (Exception e) {
            System.out.println(e.toString());
    public void send (String command){
        try {
            // Timeout setzen
            sock.setSoTimeout(300);
            // Kommando an Server schicken
            out.write(command.getBytes());
        } catch (IOException ex) {
            Logger.getLogger(Client.class.getName()).log(Level.SEVERE, null, ex);
Client.java
PHP:
 * @author chris
    public int port;
    public  Socket sock;
    public Client() {
        port = 6700;
        try {
            in.close();
            out.close();
            sock.close();
        try {
            // Timeout setzen
Server.java
PHP:
import java.io.InterruptedIOException;
import java.net.ServerSocket;
 * @author chris
public class Server extends Thread {
    public int port;
    private boolean stoprequestet;
    public Server() {
        port = 6700;
        stoprequestet = false;
    public synchronized void requestStop() {
        stoprequestet = true;
    public void run() {
        try {
            ServerSocket serversock = new ServerSocket(port);
            int a = 0;
            System.out.println(a);
            // ab hier wartet der Server auf eine Verbindung
            Socket useSocket = serversock.accept();
            InputStream in = useSocket.getInputStream();
            OutputStream out = useSocket.getOutputStream();
            byte[] b = new byte[100];
            int len;
            try {
                int i = 0;
                while (!stoprequestet) {
                    try {
                        if ((len = in.read(b)) == -1) {
                            break;
                        System.out.write(b, 0, len);
                    } catch (InterruptedIOException e) {
            } catch (IOException e) {
                System.err.println(e.toString());
             * if (in.read(b) == "in"){
            in.close();
            out.close();
            useSocket.close();
            serversock.close();
Versuch mal die Reihenfolge der beiden Anweisungen zu tauschen (in Server und Client):
Code:
InputStream in = socket.getInputStream();
OutputStream out = socket.getOutputStream();
(hab einfach mal socket als Variable genommen, hat entsprechend anpassen)
Hier kann eine Art Dead-Lock entstehen...
Grund:
Der Server wartet auf den Eingabe-Stream vom Client. D.h. er wartet darauf, dass der Client einen Ausgabe-Stream erzeugt. Der ist aber selbst damit beschäftigt, auf den Eingabe-Stream vom Server zu warten, der aber nicht erstellt wird, da der Server ja wartet...
Vereinfacht gesagt: Es gilt das U-Bahn-Prinzip: Erst die Leute rauslassen (outstream) und dann einsteigen (instream)
Ich weiß allerdings nicht, ob das das Problem löst ^^
Hilfreich wäre es übrigens, wenn du nicht zwei mal die Client-Klasse gepostet hättest...
Edit------------------------------------
Eigentliche Ursache:
Warum werden in Client.startClient() die Streams und der Socket eigentlich sofort wieder geschlossen? oO
Da haben wir nämlich auch das Problem, dass du die Socket aufmachst, aber im gleichem Atemzug wieder schließt. Ergibt natürlich irgendwie gar keinen Sinn, daher solltest du die close-Methoden in eine andere Methode auslagern und es sollte funktionieren.
