Microsoft (R) Windows Debugger Version 6.10.0003.233 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Complete Dump File: Full address space is available
Symbol search path is: SRV*C:\symbols*
http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16385.x86fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0x82a52000 PsLoadedModuleList = 0x82b9a810
Debug session time: Mon May 3 13:14:26.390 2010 (GMT+2)
System Uptime: 0 days 0:08:57.828
WARNING: Process directory table base 5EFAE5A0 doesn't match CR3 00185000
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
kd> !analyze -v
* Bugcheck Analysis *
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 00000000, MCA_ASSERT
Arg2: 855177d4, Address of WHEA_ERROR_RECORD structure
Arg3: b2000000, High 32 bits of MCi_STATUS MSR for the MCA bank that had
the error
Arg4: 00070f0f, Low 32 bits of MCi_STATUS MSR for the MCA bank that had
the error
Debugging Details:
*** ERROR: Module load completed but symbols could not be loaded for ALCXWDM.SYS
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: kernel32!pNlsUserInfo ***
*** work. ***
WHEA_ERROR_RECORD: !errrec ffffffff855177d4
BUGCHECK_STR: 0x124_AuthenticAMD
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: audiodg.exe
CURRENT_IRQL: 1f
STACK_TEXT:
82b75d2c 82a29f3f 00000124 00000000 855177d4 nt!KeBugCheckEx+0x1e
82b75d68 82b20f04 854b49a9 855177d4 82aba4f0 hal!HalBugCheckSystem+0xab
82b75d98 82a2a1f1 852fc0a8 82a37e40 00000000 nt!WheaReportHwError+0x230
82b75eac 82a2a2e3 852fc0a8 852fc0f8 00000000 hal!HalpMcaReportError+0x3b
82b75ed0 82a2a54f 00000000 852fc0f8 82b75ff0 hal!HalpMceHandler+0x8b
82b75ee0 82a205f5 00000000 00000000 00000000 hal!HalpHandleMachineCheck+0x3b
82b75ff0 82a1d261 00000002 801dc000 00000000 hal!HalpMcaExceptionHandler+0x87
82b75ff0 82a33ff8 00000002 801dc000 00000000 hal!HalpMcaExceptionHandlerWrapper+0x89
9c172800 8d0288e5 0000dc24 0000000f 858a2000 hal!READ_PORT_USHORT+0x8
WARNING: Stack unwind information not available. Following frames may be wrong.
9c172828 8d028b7d 858a2000 00000012 9c172854 ALCXWDM+0xa8e5
9c172858 8d034ef4 858a2000 00000012 00000000 ALCXWDM+0xab7d
9c172884 8d05dfeb 858a2000 00000013 00000000 ALCXWDM+0x16ef4
9c1728b0 8d06389d 00ba3000 00000000 8d05e34e ALCXWDM+0x3ffeb
00000000 00000000 00000000 00000000 00000000 ALCXWDM+0x4589d
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: hardware
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: 0x124_AuthenticAMD_CPER_Sev_1
Followup: MachineOwner
