Vmware 3.0
U
Unregistered
Möchte gerne eine Anleitung in Deutsch, wie ich Linux Mandrake 8.1 unter VMWare 3.0 installiere. Die englische Anleitung kapier ich nicht!
To install Linux-Mandrake 8.0 in a virtual machine:
Insert the Linux-Mandrake 8.0 CD in the CD-ROM drive and click the Power On button.
Follow the installation steps as you would for a physical machine. Be sure to make the choices outlined in the following steps.
Use the Expert installer.
In the partitioning step, unless you have special requirements, let Linux-Mandrake auto-allocate the space.
When selecting a boot loader, use LILO with text menu. Do not use the graphical version of LILO. It causes the virtual machine to hang.
On the "Select a Graphic Card" screen, choose Other > Generic VGA compatible.
Near the end of the installation, after files have been copied, you reach the monitor setup screen. Choose Super VGA, 800x600 @ 56 Hz.
When the installer asks whether to start X when you reboot, answer No.
Install VMware Tools in your guest operating system.
Note: With a Linux-Mandrake 8.0 guest, you should install VMware Tools from the Linux console. Do not start X until you have installed VMware Tools and carried out the final step.
Be sure you are logged in as root (su), then enter the following commands to set up a symbolic link to the correct XFree86 configuration file.
cd /etc
ln -s /etc/X11/XF86Config.vm XF86Config
Use the startx command to start your X server.
Eigentlich brauche ich nur Infos zu dieser VGA-Geschichte und VMware Tools. Alles andere weiß ich schon!
Andi
Top
