Zombie mod Night vision?
headX
Dabei seit
Juni 2009
Hallo ich habe den zombie mod bei mir drauf und zwar die version: 2.0.0 Z und ich bin jetzt schon die ganze zeit am rum machen das man im game als zombie auch die night vision nuzten kann aber es klappt einfach net hier mal meine zombie mod.cfg:
Code:
// ZombieMod Configuation file.
// Executed at server start and on every map load.
// www.ZombieMod.com
// To load your settings once you've finished, use the console command zombie_loadsettings
// File with list of models to use for zombie mod.
// If headless models are enabled, each model must have a _head and a _hs counterpart.
// ZombieMod will detect the heads automatically so both types of models may be used together.
zombie_model_file  "cfg/zombiemod/models.cfg"
// File with list of materials. Clients download everything in this list when they connect.
zombie_download_file  "cfg/zombiemod/downloads.cfg"
// How often zombies play zombie sounds. The lower the value, the more often they emit a sound.
zombie_sound_rand  50
// Health that zombies get. First zombie is this times two.
zombie_health   2500
// The speed that zombies travel at.
zombie_speed   325
// Field of vision of the zombies. Normal human FOV is 90.
zombie_fov   90
// The knockback multiplier of zombies. Set to 0 to disable knockback.
zombie_knockback  3
// Space separated list of guns that are restricted during zombie mode. Takes effect immediately on change.
// Can be any combination of the following
// all - All weapons
// equip - Equipment
// shotgun - All shotguns.
// rifles - All rifles.
// Or each weapons short name. Ex: famas, awp, mac etc etc.
zombie_restrictions  "flash"
// Makes maps very dark if enabled. If disabled, the map doesn't have to be reloaded to start zombiemode.
zombie_dark   0
// When enabled, ZombieMod will use the scoreboard to display which players are a zombie and which are humans.
// The CT team shows the humans and the T team shows the Zombies.
// On round_end everyone is randomly placed onto either team to allow for buying at the start of the next round.
// The teams are not changed again until the first Zombie is chosen and then everyone else is moved to the CT team.
zombie_teams   1
// If enabled, zombies who are killed respawn as a human after zombie_respawn_delay seconds.
zombie_respawn   1
// Time before players are respawned in autorespawn mode.
zombie_respawn_delay  1
// If enabled, ammo is set to 1000 clip.
zombie_unlimited_ammo  1
// If enabled, zombies can only voice with zombies and humans with humans.
zombie_talk   0
// When enabled, disables players from suiciding.
zombie_suicide   1
// When enabled, disables players from suiciding by switching teams.
zombie_changeteam_block  0
// Text for suiciding assholes.
zombie_suicide_text  "Dont be an asshole."
// If this is in your config.cfg ZombieMod attempts to auto load itself at first round_start.
zombie_startup   1
// Maximum amount of seconds after round_freeze_end for first random Zombification.
zombie_timer_max  15
// Minimum amount of seconds after round_freeze_end for first random Zombification.
zombie_timer_min  10
// Amount of extra frags awarded for killing a zombie.
// 1 kill is awarded regardless, but some people feel that when health is as high as it is, more kills should be awarded.
// So, if this is 0, 1 kill is awarded.
// If it is 1, 2 kills are awarded, and so on,
zombie_kill_bonus  1
// Amount of headshots before a zombie's head comes off. 0 means on death only.
zombie_headshot_count  0
// If enabled, zombies heads get blown off on headshot deaths.
zombie_headshots  0
// When 1, allows zombies to disable their own night vision.
zombie_allow_disable_nv  1
// When enabled, shows an icon in the top right corner of a players screen when someone gets turned into a zombie. (Thanks LDuke)
// It also logs a player_death event using zombie_claws_of_death as the weapon name.
// If you are a plugin developer, you should check for this weapon in FireEvent.
// The actual Event_Dying and Event_Killed events are not fired and the player is not dead.
zombie_notices   1
// When enabled, over-rides fog for all maps with a predefined Zombie-Fog.
zombie_fog   0
// When enabled, over-rides the sky for all maps so it corresponds with the fog.
zombie_fog_sky   1
// Primary fog colour.
zombie_fog_colour  "176 192 202"
// Secondary fog colour.
zombie_fog_colour2  "206 216 222"
// How close to a players Point-Of-View fog is rendered.
zombie_fog_start  30
// How far from a players Point-Of-View that fog stops rendering.
zombie_fog_end   4000
// Enables fog blending between colours.
zombie_fog_blend  1
// Enables the cool smoke effect seen by all players when zombies are turned.
zombie_effect   1
// Enable screen shake on zombification.
zombie_shake   1
// Enables the JetPack for Zombies.
zombie_jetpack   0
// Enables the JetPack for Humans.
humans_jetpack   0
// Amount of seconds zombies are allowed to use the JetPack in one round.
zombie_jetpack_timer  6
// The material to use for the sky.
// This material should have four vmt files located in materials/skybox.
// Their naming scheme is as follows..
// %MATERIALNAME%dn.vmt
// %MATERIALNAME%ft.vmt
// %MATERIALNAME%lf.vmt
// %MATERIALNAME%rt.vmt
// %MATERIALNAME%up.vmt
// %MATERIALNAME%bk.vmt
zombie_fog_sky_material  "zombie_sky"
// The radius around a players location to check for other players on Zombification.
zombie_stuckcheck_radius 35
// Delay in seconds after a player joins a server to send the welcome message. 0 to disable.
zombie_welcome_delay  2
// The text to send to new players.
zombie_welcome_text  "[ZOMBIE] This server is using the ZombieMod Server Plugin. Type !zhelp in chat for help.\nGet it at www.ZombieMod.com"
// The url to direct people to when they enter !zhelp in chat.
zombie_help_url   "http://www.zombiemod.com/zombie_help.php"
// When enabled, all players hear 'undead ambient sounds'.
zombie_undead_sound_enabled 1
// Can be used to higher or lower the volume of the sound played.
zombie_undead_sound_volume 0.7
// The sound to play to players, is precached and added to the client download list automatically.
zombie_undead_sound  "ambient/zombiemod/zombie_ambient.mp3"
// A comma delimited string of maps with wich not to use zombie_undead_sound.
zombie_undead_sound_exclusions "de_aztec"
// When enabled, Zombies only take damage via headshots.
zombie_headshots_only  0
// When enabled, after zombie_balancer_player_ratio amount of players are zombies, each additional new zombies health is reduced by this percentage. 0 Disables.
zombie_balancer_health_ratio 0
// The ratio of players whom must be a zombie to start reducing new Zombies health. So when this percentage of the server is a zombie, new zombies health is reduced by the percentage of zombie_balancer_health_ratio.
zombie_balancer_player_ratio 0
// If this is 1, zombie_balancer_player_ratio is the ratio of players who must be zombies before health is decreased. Otherwise, zombie_balancer_player_ratio is the count of Zombies ex:6.
zombie_balancer_type  1
// This is the minimum health you want Zombies to ever end up with while using the balancer.
zombie_balancer_min_health 100
// Number of times a player can use zstuck per round.
zombie_teleportcount  4
// If enabled keeps tracks of damage that players do to zombies and shows them a list on round end or zombification.
zombie_damagelist  1
// Length of time to display damage list. -1 is forever.
zombie_damagelist_time -1
// Amount of red saturation to use for zombie vision.
zombie_vision_r   0
// Amount of green saturation to use for zombie vision.
zombie_vision_g   0
// Amount of blue saturation to use for zombie vision.
zombie_vision_b   0
// Alpha colour to use for zombie vision.
zombie_vision_a   50
// Time in seconds between checks to se if zombie_vision is still enabled on a client. If you notice it disabling often try reducing this number.
zombie_vision_timer  20
// If enabled, players are protected for this amount of time after they respawn.
zombie_respawn_protection 10
// If enabled, when players spawn in they respawn as a Zombie.
zombie_respawn_as_zombie 1
// If enabled, allows players to spawn in once when they join regardless of zombie_respawn value.
zombie_respawn_onconnect 1
// If enabled, the first time a player spawns in they will be spawned as a zombie. This removes the clients ability to 'retry' and spawn as a human.
zombie_respawn_onconnect_as_zombie 1
// When enabled only allows !ztele to be used by zombies.
zombie_teleport_zombies_only 0
// When 1 sends a custom message to a zombie every time they zombify someone displaying their current health, when 2 it uses HintText.
zombie_show_health 1
// This is the time between health regeneration for zombies. 0 disables.
zombie_regen_timer 20
// Amount of health to regen every health regen.
zombie_regen_health 10
// Primary weapon to give players who spawn after round start
zombie_respawn_primary "weapon_tmp"
// Secondary weapon to give players who spawn after round start.
zombie_respawn_secondary "weapon_usp"
// When enabled, gives players a frag grenade once their protection ends.
zombie_respawn_grenades 1.0
// Comma delimited string to ignore weapon slots when dropping weapons after respawn. Example: 2,3
// Ignored if zombie_respawn_dropweapons is 0.
//SLOT_PRIMARY      0
//SLOT_SECONDARY    1
//SLOT_KNIFE        2
//SLOT_NADE         3
//SLOT_BOMB         4
zombie_respawn_dontdrop_indexes "1,3"
// When enabled ZombieMod will drop the players weapons before giving new weapons.
zombie_respawn_dropweapons 1.0
// When enabled, uses different zombie classes as defined in zombie_classes.cfg
zombie_classes 1.0
// Material to use for zombie_vision, located in vgui/hud/zombiemod/. If blank zombie_vision will be disabled. zombie_vision is also included with the release add it to downloads.cfg aswell as changing here if you want to use it.
zombie_vision_material	"zombie_view"
// If enabled saves players class selections to a file on map change and reloads it the next time the server starts. Also server command zombie_writeclasses.
zombie_save_classlist 1.0
// Percentage of specified health to give zombie classes. Usefull for balancing maps. Only applies when zombie classes are enabled.
zombie_health_percent 100
// Percentage of specified speed to give zombie classes. Usefull for balancing maps. Only applies when zombie classes are enabled.
zombie_speed_percent 100
// Percentage of specified jump height to give zombie classes. Usefull for balancing maps. Only applies when zombie classes are enabled.
zombie_jump_height_percent 100
// Percentage of specified knockback to give zombie classes. Usefull for balancing maps. Only applies when zombie classes are enabled.
zombie_knockback_percent 100
// The file to use for end_round overlay, set blank to disable. If file names are 1024_zombies and 1024_humans this setting should be 1024. The _zombies and _humans must be there.
zombie_end_round_overlay 1024
// *EXPERIMENTAL* Amount of zombies to spawn at round_start, 0 for regular method. Defaults to ( player count - 2 ) if the total amount of players is less than this value.
zombie_count 1
// Type of double health to give first zombie(s):
// 0 disable double health (also applies if zombie_count is 0 or 1
// 1 first chosen gets double health
// 2 all first zombies get double health.
zombie_count_doublehp 1
// Enables/Disabled the zstuck player command.
zombie_zstuck_enabled 1
// Percent of players needed to kickstart zombie selection - 0 disables.
zombie_kickstart_percent 70
// Time in seconds that kickstart is enabled after first vote.
zombie_kickstart_timer 120
// Global time in seconds interval between votes.
zombie_vote_interval 60
// String to use for zombie's weapon.
zombie_weapon "zombie_claws_of_death"
// When enabled it will call the random zombie functionality as if it was round start when the last living zombie disconnects.
zombie_disconnect_protection 1.0
// When enabled forces round end at mp_roundtime -4 seconds.
zombie_force_endround 1.0
// Language file to use, it must exist in /cfg/zombiemod/language
zombie_language_file "english.cfg"
// Error string to give when missing language key values.
zombie_language_error "*** %s not found in language file ***"
// When enabled will teleport first zombie back to spawn.
zombie_first_zombie_tele 0.0
// When 0 zombiemod only gives the cash cvar cash values for events as specified, when it's 1 it does what pre 2.0 Q did (16000 start), otherwise the value you specify.
zombie_startmoney 16000
// The amount of cash to give a player that kills a zombie that's on their own team - i.e. what the server takes for tks.
zombie_tk_money 3000
// Amount of extra cash to give players that kill zombies (additional to 300 css default).
zombie_kill_money 300
// Amount of extra cash to give zombies that zombify a human.
zombie_zombie_money 500
// When enabled uses a nice dissolve effect on ragdools.
zombie_dissolve_corpse 1.0
// Delay before dissolve effect on zombies.
zombie_dissolve_corpse_delay 1.0
// When enabled zombiemod will delete any weapons a player drops when they are zombified.
zombie_delete_dropped_weapons 1.0
// When 1, random class chosen each time a zombie dies. When 2, random zombie chosen each time a player connects. When 3 uses same behaviour as 1 but until player choses class themselves.
Ich hoffe ihr könnt mir da weiter helfen.
mfg
Bitte helft mir..
kann mir da keiner helfen??
AW: Zombie mod Night vision???
ruhig tiger wird schon einer kommen;)
ja ok sry ^^
wäre trotzdem nett wenn sich einer melden würde^^
mfg
Hi
schonmal die befehle angesehen?
Code:
zombie_vision_r   0
zombie_vision_g   0
zombie_vision_b   0
zombie_vision_a   50
mfg
ja habe ich mir angesehen und night vision ist doch an gestellt also auf 1
Deswegen verstehe ich es ja nicht warum es nicht geht.
Du weißt aber schon, dass das nur heißt, dass wenn die Zombis eine Nightvision haben diese ausschalten können und nicht dass somit die auch automatisch für die Zombies freigeschaltet wird ?
Gibt es keinen Befehl wie "zombie_allow_enable_nv 1" ?
Nein es gibt nur diese stelle hier:
mfg
Top
