muem
- Juli 2003
Mit dem Freeware-Tool nLite kann man sich eine eigene Windows Installations CD erstellen um z.B. Service Packs, Hotfixes und Treiber einbinden
http://www.nliteos.com/download.html
#1.0 beta 1
general
- new: Windows XP x64 Pro Support
- new: Patches page
- new: nLite Processing Priority option
- new: Program Files path
- new: Clean MUI Languages support entries
- new: XPize uAE integration support
- new: Turkish translation
- fix: Win2k mxdr_ file report
- fix: Win2k C-Index error pop
- fix: RVMPack copy issue
- fix: Win2k3 manual install
- fix: Chinese lang issues in specific removal setup
- fix: PressAnyKey prompt removal
- fix: few services name entries (ipx mostly)
- fix: Server Unattended options enabled for Win2k server
- fix(#0000001): Tcpip patch (also now shows current value)
- fix(#0000008): win2k missing inf files on browse
- fix(#0000022): refresh after slipstream
- fix(#0000026): gsicon.exe integration
- fix(#0000028): driver install popup (for all windows)
- fix(#0000035): Windows 2003 SBS winnt.sif
components
- new: Tape drives driver
- new: Administrative templates
- new: Document Templates
- update: Ports (files and services removed, be careful)
- update: IPX (more files removed)
- update: Color Schemes (more entries removed)
- fix(#0000030): Sysprep Compatibility
- fix(#0000002): Desk Clean Reg leftover
- suspended: NetDDE (some problems, will be back)
#1.0 beta 1
general
- new: Patches page
components
