Ich habe die Lösung gefunden.
Für alle die evtl. das gleiche Problem haben, hier die Lösung:
Error When You Open Add or Remove Programs: 'Value Creation Failed " At Line 410'
Article ID : 823768
Last Review : November 12, 2003
Revision : 1.0
SYMPTOMS
After you install Windows XP Service Pack 1 (SP1), and you try to open Add or Remove Programs or Set Programs and Defaults, you may receive the following error message:
Value creation failed " at line 410
CAUSE
This problem may occur if the following file is corrupted or missing:
C:\WINDOWS\System32\Shellstyle.dll
RESOLUTION
To resolve this problem, use any of the following methods:
• Obtain a copy of the shellstyle.dll file from another Windows XP SP1 computer (Professional or Home Edition), and then copy the file to the following location on the affected computer:
C:\WINDOWS\system32\
Tip To open the C:\WINDOWS\system32\ folder, click Start, click Run, type %windir%\system32 in the Open box, and then click OK.
• If the following file is found in the system32 folder, you can rename the file to Shellstyle.dll:
C:\WINDOWS\system32\class_ss.dll
To do this, right-click the Class_ss.dll file, click Rename, and then type:
Shellstyle.dll
• If any of the following files are on the computer, copy the file to the C:\WINDOWS\system32 folder:
C:\WINDOWS\Resources\Themes\Luna\Shell\NormalColor\Shellstyle.dll
C:\WINDOWS\Resources\Themes\Luna\Shell\Homestead\Shellstyle.dll
C:\WINDOWS\Resources\Themes\Luna\Shell\Metalic\Shellstyle.dll
Note When you use this method, the appearance of some windows (such as the Add or Remove Programs or Set Programs and Defaults windows) may be affected by the Luna theme. For example, the colors may be different from what they were before the problem occurred. Therefore, you may prefer to use one of the previous methods to resolve this problem.
STATUS
Microsoft has confirmed that this is a problem in the Microsoft products that are listed in the "Applies to" section of this article.
MORE INFORMATION
When you install Windows XP SP1, the following files are renamed to Shellstyle.dll:
C:\WINDOWS\System32\Class_ss.dll
C:\WINDOWS\Resources\Themes\Luna\Shell\NormalColor\Blue_ss.dll
C:\WINDOWS\Resources\Themes\Luna\Homestead\Home_ss.dll
C:\WINDOWS\Resources\Themes\Luna\Shell\Metalic\Metal_ss.dll
If these files are still present, you can rename the files to Shellstyle.dll and then copy one of the files to the C:\WINDOWS\system32 folder.
APPLIES TO
• Microsoft Windows XP Professional Edition
• Microsoft Windows XP Home Edition
Keywords:
kbprb KB823768
