hey leute,
kriege neuerdings, wenn ich "PS3.ProxyServer" starte, folgende fehlermeldung:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentNullException: Value cannot be null.
at PS3.ProxyServer.Listener.set_ListenSocket(Socket value)
at PS3.ProxyServer.Listener.Start()
at PS3.ProxyServer.GUI.Form1.button1_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
PS3.ProxyServer.GUI
Assembly Version: 1.0.2613.32692
Win32 Version: 1.0.2613.32692
CodeBase: file:///G:/PlayStation%203/PS3.ProxyServer/PS3.ProxyServer.GUI.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Data
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
AxInterop.SHDocVw
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///G:/PlayStation%203/PS3.ProxyServer/AxInterop.SHDocVw.DLL
Interop.SHDocVw
CodeBase: file:///G:/PlayStation%203/PS3.ProxyServer/Interop.SHDocVw.DLL
Accessibility
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
Microsoft.mshtml
Assembly Version: 7.0.3300.0
Win32 Version: 7.0.3300.0
CodeBase: file:///G:/PlayStation%203/PS3.ProxyServer/Microsoft.mshtml.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
habe auf den ersten 7 seiten bei google jeden thread mir durchgelesen, aber da haben auch mehr leute das problem als es ne lösung gibt. hoffe ihr könnt mir da irgendwie weiterhelfen :\ (die sufu hat nichts ergeben).
danke im voraus
mscorlib
PS3.ProxyServer.GUI
System
System.Data
System.Xml
System.Drawing
AxInterop.SHDocVw
Interop.SHDocVw
Accessibility
Microsoft.mshtml
enabled.
For example:
<configuration>
</configuration>
danke im voraus
