Hier die Auswertung mit WinDbg:
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [D:\HELP\meerbi\Mini090213-02.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\Symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows XP Kernel Version 2600 (Service Pack 3) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 2600.xpsp.080413-2111
Machine Name:
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055b1c0
Debug session time: Mon Sep 2 17:04:36.718 2013 (UTC + 2:00)
System Uptime: 0 days 0:22:28.293
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image ati3duag.dll, Win32 error 0n2
WARNING: Unable to verify timestamp for ati3duag.dll
ERROR: Module load completed but symbols could not be loaded for ati3duag.dll
Bugcheck Analysis:
Use !analyze -v to get detailed debugging information.
BugCheck 1000008E, {c000001d, e3753970, b7dd888c, 0}
Probably caused by : ati3duag.dll ( ati3duag+109648 )
Followup: MachineOwner
kd> !analyze -v
Bugcheck Analysis:
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: c000001d, The exception code that was not handled
Arg2: e3753970, The address that the exception occurred at
Arg3: b7dd888c, Trap Frame
Arg4: 00000000
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc000001d - {EXCEPTION} Illegal Instruction
An attempt was made to execute an illegal instruction.
FAULTING_IP:
+109648
e3753970 f20fd6d5 movdq2q mm2,xmm5
TRAP_FRAME: b7dd888c -- (.trap 0xffffffffb7dd888c)
ErrCode = 00000000
eax=e43f5ec0 ebx=e3d6c040 ecx=0000008b edx=00000120 esi=e3dbaac0 edi=e3dbaac0
eip=e3753970 esp=b7dd8900 ebp=b7dd890c iopl=0 nv up ei ng nz na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010286
Resetting default scope
CUSTOMER_CRASH_COUNT: 2
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0x8E
PROCESS_NAME: NFSC.exe
LAST_CONTROL_TRANSFER: from bf2b6648 to e3753970
FAILED_INSTRUCTION_ADDRESS:
+109648
STACK_TEXT:
WARNING: Frame IP not in any known module. Following frames may be wrong.
b7dd890c bf2b6648 e3dbaac0 b7dd89a0 e3c4e448 0xe3753970
b7dd8910 e3dbaac0 b7dd89a0 e3c4e448 bf2b6672 ati3duag+0x109648
b7dd8914 b7dd89a0 e3c4e448 bf2b6672 e3c4e454 0xe3dbaac0
b7dd8918 e3c4e448 bf2b6672 e3c4e454 e3c4e2e0 0xb7dd89a0
b7dd89a0 00000000 7dccccce 7dccccce 7dccccce 0xe3c4e448
STACK_COMMAND: kb
FOLLOWUP_IP:
ati3duag+109648
bf2b6648 ?? ???
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: ati3duag+109648
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: ati3duag
IMAGE_NAME: ati3duag.dll
DEBUG_FLR_IMAGE_TIMESTAMP: 493448c7
FAILURE_BUCKET_ID: 0x8E_BAD_IP_ati3duag+109648
kd> lmvm ati3duag
start end module name
bf1ad000 bf59af40 ati3duag T (no symbols)
Loaded symbol image file: ati3duag.dll
Image path: ati3duag.dll
Image name: ati3duag.dll
Timestamp: Mon Dec 01 21:27:51 2008 (493448C7)
CheckSum: 003F7D8B
ImageSize: 003EDF40
Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4
