Helfen diese Informationen.
CPU-Z TXT Report
Binaries
CPU-Z version 1.77.0.x32
Processors
Number of processors 1
Number of threads 2
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 2.083 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Core 2 Duo E6400
Codename Conroe
Specification Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz
Package (platform ID) Socket 775 LGA (0x0)
CPUID 6.F.2
Extended CPUID 6.F
Core Stepping L2
Technology 65 nm
Core Speed 1600.1 MHz
Multiplier x Bus Speed 6.0 x 266.7 MHz
Rated Bus speed 1066.7 MHz
Stock frequency 2133 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 8.0x
Max VID 1.325 V
Temperature 0 51 degC (123 degF) (Core #0)
Temperature 1 49 degC (120 degF) (Core #1)
Clock Speed 0 1600.06 MHz (Core #0)
Clock Speed 1 2133.41 MHz (Core #1)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01008001h
Max CPUID level 0000000Ah
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 1 thread(s)
Cache descriptor Level 1, I, 32 KB, 1 thread(s)
Cache descriptor Level 2, U, 2 MB, 2 thread(s)
Chipset
Northbridge Intel P35/G33/G31 rev. A2
Southbridge Intel 82801GB (ICH7/R) rev. A1
Memory Type DDR2
Memory Size 2 GBytes
Channels Dual, (Symmetric)
Memory Frequency 333.3 MHz (4:5)
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 15
Row Refresh Cycle Time (tRFC) 36
Command Rate (CR) 2T
Host Bridge 0x29C0
