Shutdown Shortcut
If you have XP, you can make shutting down a little less tedious by creating a simple shortcut.
1. Right click on the desktop and Create a New Shortcut
2. Browse for the file c:windowssystem32shutdown.exe (or c:winntsystem32shutdown.exe)
3. Click Next, name your shortcut, and click Finish.
4. Right click the shortcut and select Properties from the pop-up menu.
5. Next, you'll need to append a command line switch to the target box. Add the switch -l to log off, -s to shut down, or -r to reboot.
