immer wieder 1e Bluescreen
C
Clio-Sebbel
vorab, ich nutze Win7 64bit seit ich meinen Rechner habe (Januar 2013)
bisher, bzw. seid min. 1 Jahr ohne Probleme.
nun habe ich am Dienstag mein 120GB SSD auf eine 256GB SSD geclont mit easeus partition master 10.1
hat alles reibungslos funktioniert, bis Mittwoch plötzlich bluescreen auftrat.
und seitdem bis gerade eben 5 Stück
3x im Leerlauf, 2x beim video schauen auf youtube
whocrashed sagt folgendes:
System Information (local)
Computer name: SEBBEL-PC
Windows version: Windows 7 Service Pack 1, 6.1, build: 7601
Windows dir: C:\Windows
Hardware: ASUSTeK COMPUTER INC., P9X79 DELUXE
CPU: GenuineIntel Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz Intel586, level: 6
12 logical processors, active mask: 4095
RAM: 17117769728 bytes total
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Fri 06.11.2015 00:32:44 GMT your computer crashed
crash dump file: C:\Windows\Minidump\110615-13400-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x73590)
Bugcheck code: 0x1E (0x0, 0x0, 0x0, 0x0)
Error: KMODE_EXCEPTION_NOT_HANDLED
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: iastora.sys (iaStorA+0x63AA8)
file path: C:\Windows\system32\drivers\iastora.sys
product: Intel Rapid Storage Technology Enterprise driver
company: Intel Corporation
description: Intel Rapid Storage Technology Enterprise driver - x64
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: iastora.sys (Intel Rapid Storage Technology Enterprise driver - x64, Intel Corporation).
Google query: Intel Corporation KMODE_EXCEPTION_NOT_HANDLED
On Thu 05.11.2015 21:58:33 GMT your computer crashed
crash dump file: C:\Windows\Minidump\110515-14102-01.dmp
On Thu 05.11.2015 08:04:44 GMT your computer crashed
crash dump file: C:\Windows\Minidump\110515-14305-01.dmp
On Wed 04.11.2015 10:30:01 GMT your computer crashed
crash dump file: C:\Windows\Minidump\110415-15568-01.dmp
PC ist nicht übertaktet
seit dem clonen hatte ich nur 1 Problem, dass mein Thrustmaster T300RS nicht mehr erkannt wurde, daraufhin habe ich den Treiber deinstalliert und wieder installiert, ohne Erfolg.
Treiber wieder deinstalliert, mit ccleaner die registry aufräumen lassen, Treiber wieder installiert, funktioniert wieder.
hoffe ihr könnt mir irgendwie helfen.
weiß nicht ob es was damit zutun haben könnte, aber habe die SSD (850 pro) zusammen mit der alten SSD (840 basic series) und 2 HDD (1000GB Seagate Barracuda 7200.14 ST1000DM003) und 1 LiteOn iHBS112 Blu-ray Disc Writer SATA alles an einem Strang vom Netzteil. dürfte aber eigentlich nicht relevant sein, denke ich, bin mir da aber nicht 100% sicher.
Netzteil ist ein 700 Watt be quiet! Straight Power E9 Non-Modular 80+ Gold
desweiteren ist eine 4096MB Asus GeForce GTX 680 verbaut sowie 16GB (2x 8192MB) Corsair Vengeance LP Black DDR3-1600 DIMM CL10-10-10-27 Dual Kit
Guten Morgen Sebbel,
überprüfe mal mit MEMTEST deinen Arbeitsspeicher. Wenn der Kernel Probleme macht, hat es oft mit defektem Arbeitsspeicher zu tun. Und mit Corsair hatte ich auch schon so meine Probleme. Musste meinen Speicher 2x tauschen, bevor ich ein Kit bekommen habe, welches keine Fehler aufweist.
Gruß,
Langnese
@Lagnese: memtest86 habe ich gestern schon ne Stunde laufen lassen, keine Fehler und wie gesagt lief es ja seit 2013 ohne Probs
@Hanne: habe erst versucht nach Anleitung vorzugehen wenn das T300RS nicht erkannt wird. Also abziehen vom USB > L3+R3 gedrückt halten und wieder anstecken an USB. als auch das nach mehrmaligen probieren nicht geholfen hat, habe ich es so gemacht wie du schreibst.
treiber deinstalliert, gerät ab, PC neu gestartet, Treiber installiert, bei Aufforderung T300RS angeschlossen, doch da ging es nicht weiter, er erkannte es nicht. Daraufhin abgebrochen (oder das Installprogramm automatisch, weiß nicht mehr genau), Treiber deinstalliert, ccleaner über die registry gejagt, PC neugestarten, Treiber installiert, bei Aufforderung angeschlossen und es funktionierte.
habe dennoch jetzt eben mal das Firmewareupdate gemacht, hatte noch die V24 drauf.
glaube dennoch nicht das es daran liegt/lag.
Sebbel, eine Stunde ist nicht ausreichend. Bei einer Stunde hatte er bei mir auch 0 Fehler gebracht. Ich hab es dann gestartet, als ich zur Arbeit los bin, und als ich nach Hause kam, hatte ich 57,000 defekte Bereiche erkannt. Also, wenn du Zeit hast, mal deutlich länger laufen lassen.
gut dann werde ich das heute mal laufen lassen. kurze Frage dazu, nur 1 prozessor verwenden, oder alle? kann man ja auswählen...
hatte vorhin wieder bluescreen, diesmal zeigt whocrashed etwas anderes.
On Fri 06.11.2015 10:40:57 GMT your computer crashed
crash dump file: C:\Windows\Minidump\110615-14679-01.dmp
This was probably caused by the following module: vwififlt.sys (vwififlt+0xD110)
file path: C:\Windows\system32\drivers\vwififlt.sys
description: Virtual WiFi Filter Driver
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
habe jetzt erstmal den soundtreiber aktualisiert und den Asmedia SATA Controller Driver
BIOS werde ich auch gleich noch update machen
das sind die einzigsten 3 sachen die es neuer gibt für mein board alles andere ist aktuell.
wenn ich mir die Treiberfehler so ansehe
vermute ich da eher den Fehler als beim Speicher. Würde mal schauen, ob alle Kabel an der Festplatte richtig sitzen (ggf mal neue besorgen) und da die Treiber erneuern.
Hände weg von CCleaner, TuneUp und Konsorten! Die richten alle mehr Schaden an als sie nutzen wenn man nicht weiß, was man tut! Eine Registry muss man nicht "aufräumen", vollkommener Nonsens.
VG,
Mad
so, habe jetzt nochmal den "Intel Management Engine Interface" und "Intel Chipset Software Installation Utility" Treiber installiert und das neueste BIOS drauf von der ASUS Website für mein p9x79 deluxe
gestern Abend ohne Bluescreen, doch heute dann wieder mehrere. nach dem ersten heute habe ich die 2 oben genannten Treiber aktualisiert, doch eben schon wieder ein Bluescreen.
Kabel schließe ich aus, weil waren beim Board damals dabei und war noch original verpackt, weil ich es bisher nicht brauchte. Kabel sind auch sauber eingerastet.
noch irgendwelche Ideen? ich verzweifel langsam, immer wenn du denkst jetzt läuft es, kommt wieder ein BlueScreen.
hier nochmal alle bisherigen von Whocrashed
Welcome to WhoCrashed (HOME EDITION) v 5.51
This program checks for drivers which have been crashing your computer. If your computer has displayed a blue (or black) screen of death, suddenly rebooted or shut down then this program will help you find the root cause and possibly a solution.
Whenever a computer suddenly reboots without displaying any notice or blue (or black) screen of death, the first thing that is often thought about is a hardware failure. In reality, on Windows most crashes are caused by malfunctioning device drivers and kernel modules. In case of a kernel error, many computers do not show a blue screen unless they are configured for this. Instead these systems suddenly reboot without any notice.
This program will analyze your crash dumps with the single click of a button. It will tell you what drivers are likely to be responsible for crashing your computer. It will report a conclusion which offers suggestions on how to proceed in any situation while the analysis report will display internet links which will help you further troubleshoot any detected problems.
To obtain technical support visit www.resplendence.com/support
Click here to check if you have the latest version or if an update is available.
Just click the Analyze button for a comprehensible report ...
Home Edition Notice
This version of WhoCrashed is free for use at home only. If you would like to use this software at work or in a commercial environment you should get the professional edition of WhoCrashed which allows you to perform more thorough and detailed analysis. It also offers a range of additional features such as remote analysis on remote directories and remote computers on the network.
Click here for more information on the professional edition.
Click here to buy the the professional edition of WhoCrashed.
RAM: 17115860992 bytes total
Crash Dump Analysis
On Sat 07.11.2015 16:35:53 GMT your computer crashed
crash dump file: C:\Windows\Minidump\110715-14523-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x741D0)
This was probably caused by the following module: iastora.sys (iaStorA+0x64024)
On Sat 07.11.2015 13:34:08 GMT your computer crashed
crash dump file: C:\Windows\Minidump\110715-15194-01.dmp
Conclusion
8 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination with the errors that have been reported for these drivers. Include the brand and model name of your computer as well in the query. This often yields interesting results from discussions on the web by users who have been experiencing similar problems.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Wieder der RST (oder sind das noch die alten Dumps?) und der Virtual WiFi Filter Driver. Deinstalliere den RST und deaktiviere den Virtual WiFi Filter Driver.
Ob einer der beiden für das Problem verantwortlich ist lässt sich schwer sagen, ohne dass sich jemand die Minidumps mal genauer anschaut.
Nur weil etwas neu ist, heißt das noch lange nicht, dass es auch sauber funktioniert. Poste mal einen Screenshot von CrystalDiskInfo, Fenster ganz aufziehen.
Es hat sich aber nur die SSD am PC geändert, sonst nichts? sfc/scannow mal als Admin ausgeführt?
sfc/scannow keine Probleme festgestellt
das sind alle bisherigen dumps
es hat sich nur die SSD geändert.
diese habe ich neu gekauft und die alte SSD da drauf geclont mit easeus partitions master 10.1
die alte SSD sowie die eine HDD hängt ganz rechts an den grauen anschlüssen (6GB/s)
das BluRay-Laufwerk an einem blauen 3GB/s Anschluss
die andere HDD hängt an dem mit "SSD Caching" gekennzeichneten 6GB/s Anschluss und an diesen habe ich auch die neue SSD angeschlossen.
die beiden sind Marvell®Serial ATA 6.0 Gb/s connectors (7-pin SATA6G_E1/E2 [gray])
die anderen sind Intel®X79 Serial ATA 6.0 Gb/s connectors (7-pin SATA6G_1/2 [gray])
und Intel®X79 Serial ATA 3.0 Gb/s connectors (7-pin SATA3G_3–6 [blue])
nur falls es vielleicht etwas zu Sache hilft.
habe schon überlegt die neue SSD einfach an den Anschluss zustecken wo jetzt die alte SSD steckt und die alte aus dem PC zu entfernen. weiß aber eben nicht ob es damit was zu tun haben könnte und PC ist unterm Schreibttisch gut verbaut, da hab ich nicht Lust das auszuprobieren und den Schreibtisch halb zu zerlegen und wieder zusammen zubauen.
einmal die neue 850pro und die alte 840 basic
EDIT:
habe vorhin nach dem letzten crash den RST nochmal neu installiert, hat dieses mal auch funktioniert. davor hatte sich jedesmal nach dem neustart des PC die installationsroutine vom RST gestartet, ich klicke auf ausführen, aber es passierte nichts. jetzt hatte es dann aber funktioniert und er hat das installprogramm zu ende gemacht.
wo finde ich den virtual Wifi Filter Driver zum deaktivieren? Gerätemanager? zur Info, ich nutze WLAN um online zugehen, funktioniert das dann noch?
Es hat sich also geändert, dass jetzt auch der Marvell-Controller genutzt wird?
SSDs an den Intel 6Gb/s, alles andere an den Intel 3Gb/s. "SSD Caching" wird da nicht umsonst draufgeklebt sein, wer weiß, inwiefern der Controller hier anders arbeitet. Möglicherweise ist auch der Marvell-Treiber veraltet/fehlerhaft.
an dem Marvel-Controller hing vor der neuen SSD schon die eine HDD, also wurde er vorher auch schon genutzt
die 2 HDD's habe ich ebenfalls an die 6GB/s angeschlossen weil sie dafür ausgelegt sind.
sind diese http://www.mindfactory.de/product_i...3-64MB-3-5Zoll--8-9cm--SATA-6Gb-s_775365.html
ich lasse ihn heute mal laufen, bin guter Dinge seit dem die Install vom RST nach dem Neustart abgeschlossen wurde.
Gestern Abend (19-1:30 Uhr) hatte ich keinen crash.
sollte ich heute wieder einen bekommen, dann stecke ich mal um auf dem Board
EDIT:
hab ihn heute den ganzen Tag am laufen gehabt, kein Bluescreen... läuft würde ich sagen.
nochmals vielen Dank an Euch
