Hellracer
- Okt. 2001
Hi @ all!
Nachtrag zu den letzten beiden Treats, Originalbeiträge sind aus dem MSI-Forum (vielen Dank),
Grüsse
Overclocking BIOS Guide for KT3 Ultra ARU
WARNING : OVERCLOCKING YIELDS YOUR SYSTEM RUNNING OUT OF SPECIFICATIONS. YOU NEED TO HAVE VERY HIGH QUALITY HIGH YIELD COMPONENTS TO ACHIEVE STABLE OVERCLOCKING. OVERCLOCKING MAY ALSO DAMAGE YOUR SYSTEM!! TRY ON YOUR OWN RISKS!!
Here is my overclocking attempt for KT3 Ultra ARU.
BIOS Settings:
LOAD HIGH PERFORMANCE DEFAULT
Advanced Bios Features:
SMART for harddisk : DISABLED / ENABLED when installing WinXP
Advanced Chipset Features:
PCI Delay Transaction : DISABLED
DRAM Timing Control:
Configure SDRAM Timing by : USER
SDRAM Frequency : HCLK
SDRAM CAS# Latency : 2
Row Precharge Time: 2T
RAS Pulse Width: 5T
RAS to CAS Delay: 2T
SDRAM Bank InterLeave: 4
SDRAM Burst Length: 8QW
SDRAM 1T command: Enabled
Fast Command : Ultra
AGP Timing Control:
all AUTO, Fast Write ENABLED, Aperture Size : 64MB, Master READ/WRITE and SYNC: DISABLED
PNP/PCI Configuration:
PnP OS: YES
PCI Latency Timer : 128 !!!
PCI IDE Bus Master : ENABLED
Frequency/Voltage Control:
all AUTO
***for KingMax DDR user, DO NOT INCREASE THE RAM VOLTAGE . In fact, TinyBGA perform BETTER in low voltage!!
CPU FSB Clock: 150Mhz
Spread Spectrum : DISABLED
My Rig is :
AMD AthlonXP1600+ LOCKED (not unlocked!)
Alpha PAL8045U with 46.5cfm Delta fan
MSI KT3 Ultra ARU
256MB KingMax PC2400 DDR300
60GB Maxtor D740x
4MB Trident975 AGP 1x
52x Samsung SC-152B (I can't find any firmware for it!!)
Realtek 8139 NIC
SBLive! Value
KT3 Ultra with PC2700 RAM
NORMAL NON-OVERCLOCKED SETTINGS for KT3 Ultra with PC2700 RAM running at 133Mhz FSB and 166Mhz RAM
BIOS Settings:
LOAD HIGH PERFORMANCE DEFAULT You might need to change back to LOAD BIOS SETUP DEFAULT if you have problem with this settings
SMART for harddisk : DISABLED / ENABLED when installing Win2k/XP or if you have data corruption problem occured
PCI Delay Transaction : DISABLED don't ever enable it, will cause your system instable!
Configure SDRAM Timing by : USER never trust SPD settings
SDRAM Frequency : HCLK+33
RAS Pulse Width: 5T
SDRAM Burst Length: 4QW
AGP Timing Control:
all AUTO, Fast Write ENABLED, Aperture Size : xxMB (do your display cards 2x size), Master READ/WRITE and SYNC: DISABLED
PnP OS: YES/NO
all AUTO
CPU FSB Clock: 133Mhz
running with 166Mhz FSB and PC2700 RAM !!
OVERCLOCKED SETTINGS for KT3 Ultra with PC2700 RAM running at 166Mhz FSB and 166Mhz RAM
BIOS Settings:
RAS Pulse Width: 5T
AGP Timing Control:
PnP OS: YES/NO
CPU FSB Clock: 166Mhz
CPU Radio : AUTO/ lower than your default multiplier
CPU Vcore (V): AUTO/ higher than default 1.775V or 1.80V should be OK
DDR Voltage (V): AUTO
***for KingMax or other PC2700 DDR with BGA RAM chips users, DO NOT INCREASE THE RAM VOLTAGE IF YOU ARE ATTEMPTING EXTREME OVERCLOCKING, 170MHZ AND ABOVE. In fact, BGA perform BETTER in low voltage!!
AGP Voltage (V) : AUTO
BIOS Settings:
RAS Pulse Width: 5T
AGP Timing Control:
PnP OS: YES/NO
162 Mhz FSB
Since my system's limiting factor is the LOCKED XP1600+ and PC2400 KingMax RAM, 162Mhz FSB is the best I can go from BIOS settings. 163/164/165Mhz is successful to POST but can't run stably at WinXP.
BIOS Settings:
LOAD HIGH PERFORMANCE DEFAULTS
Standard CMOS Features:
Primary IDE Master -> 32-bit transfer : ON
repeat for other IDE devices
SMART for harddisk : ENABLED, needed for installing WinXP
RAS Pulse Width: 5T
SDRAM 1T command: ENABLED / DISABLED for 155Mhz and above if not stable
Fast Command : ULTRA / NORMAL for 155Mhz and above if not stable
AGP Timing Control:
Power Management Features:
CPU Critical Temperature : 70C to play safe
PnP OS: YES
PCI Latency Timer : 128 !!! let a breathing space for SBLive not to produe any crackling sounds
Integrated Peripherals:
FDC Function : AUTO
Serial Port1 : DISABLED *
Serial Port2 : DISABLED *
OnBoard Parallel Port : DISABLED *
OnBoard Midi Port : DISABLED
OnBoard IDE : Both
OnBoard ATA133 RAID : DISABLED
AC'97 Audio: DISABLED
MC'97 Modem: DISABLED
USB Controller : ALL USB Port
USB Legacy Support : ALL Devices
Port 64/60 Emulation : DISABLED
* I don't use any of those ports so I disabled them. As for printer, I use Bluetooth Printer Adapter
CPU FSB Clock: 162Mhz
CPU Ratio : AUTO
CPU Vcore : AUTO / 1.85v for over 158Mhz
DDR Voltage : AUTO / 2.7v for my KingMax PC2400 to run stable at 155Mhz~ 160Mhz, 2.8v for 160Mhz onwards to 172Mhz max
AGP Voltage : AUTO
***for KingMax PC2700 DDR user, DO NOT INCREASE THE RAM VOLTAGE . In fact, TinyBGA perform BETTER in low voltage!!
My Rig is still:
MSI KT3 Ultra ARU
60GB Maxtor D740x
Realtek 8139 NIC
SBLive! Value
I managed to maintain stable at 158Mhz (158.5) ~ 1664.25Mhz for my XP1600+, to complete DivX encoding. I managed to run quite steadily at 162Mhz FSB from BIOS.
At 100% load after 30 minutes
CPU Temp: 46C , thanks to the 120mm side exhaust fan
Sys temp: 42C
Hdd temp: 50C ~ 54C heavily spinned
ambient temp: 30C
in a closed casing : a Skyhawk clone - AVF AL-09A
with 0.32A 120mm 1 side exhaust fan
Grüsse
BIOS Settings:
RAS Pulse Width: 5T
AGP Timing Control:
PnP OS: YES
all AUTO
My Rig is :
MSI KT3 Ultra ARU
60GB Maxtor D740x
Realtek 8139 NIC
SBLive! Value
BIOS Settings:
RAS Pulse Width: 5T
AGP Timing Control:
PnP OS: YES/NO
all AUTO
BIOS Settings:
RAS Pulse Width: 5T
AGP Timing Control:
PnP OS: YES/NO
BIOS Settings:
RAS Pulse Width: 5T
AGP Timing Control:
PnP OS: YES/NO
162 Mhz FSB
BIOS Settings:
RAS Pulse Width: 5T
AGP Timing Control:
PnP OS: YES
FDC Function : AUTO
OnBoard IDE : Both
CPU Ratio : AUTO
AGP Voltage : AUTO
My Rig is still:
MSI KT3 Ultra ARU
60GB Maxtor D740x
Realtek 8139 NIC
SBLive! Value
Sys temp: 42C
ambient temp: 30C
