NAja, kommt drauf an wofürs du verwenden willst, ich denke mehr als 4 festplatten wirst du nicht haben und firewire brauchst du ja auch eigentlich nur bei ner videokamera... und raid brauchst du wahrscheinlich auch nicht
Clear the CMOS memory directly from the back panel, using abit's innovative new EZ switch. So if you are pushing your hardware to the extreme and experiment with risky settings, you now have a an easy and convenient way to go back to save grounds..
With abit's unique µGuru technology now even the most novice users can fully monitor and control their system including voltages, fans and temperatures; it's all just a click away. The more advanced you become, the more you will appreciate the multitude of fine tuning features abit's µGuru technology holds for you.
