Tearing Videoplayback Linux HD6950
feinmann
Okt. 2011
Code:
System:    Host: beehome Kernel: 3.11.0-12-generic x86_64 (64 bit) Desktop: N/A Distro: Linux Mint 16 Petra
Machine:   Mobo: ASUSTeK model: P8H67 version: Rev X.0x Bios: American Megatrends version: 3706 date: 07/18/2013
CPU:       Quad core Intel Core i5-2400 CPU (-MCP-) cache: 6144 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx)
           Clock Speeds: 1: 1600.00 MHz 2: 1600.00 MHz 3: 1600.00 MHz 4: 1600.00 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Cayman PRO [Radeon HD 6950]
           X.Org: 1.14.5 drivers: ati,radeon (unloaded: fbdev,vesa) Resolution: 1920x1080@60.0hz
           GLX Renderer: Gallium 0.4 on AMD CAYMAN GLX Version: 3.0 Mesa 9.2.1
Audio:     Card-1: Advanced Micro Devices [AMD/ATI] Cayman/Antilles HDMI Audio [Radeon HD 6900 Series] driver: snd_hda_intel
           Card-2: Intel 6 Series/C200 Series Chipset Family High Definition Audio Controller driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture ver: 1.0.2x-130606-v5.18
Network:   Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
           IF: eth0 state: down mac: 14:da:e9:ed:f9:58
           Card-2: Belkin F7D2101 802.11n Surf & Share Wireless Adapter v1000 [Realtek RTL8192SU] driver: r8712u
           IF: wlan0 state: up mac: 08:86:3b:42:f2:76
Drives:    HDD Total Size: 250.1GB (3.9% used) 1: id: /dev/sda model: Samsung_SSD_840 size: 250.1GB
Partition: ID: / size: 221G used: 9.1G (5%) fs: ext4 ID: /boot size: 237M used: 45M (20%) fs: ext2
           ID: swap-1 size: 8.56GB used: 0.00GB (0%) fs: swap
RAID:      No RAID devices detected - /proc/mdstat and md_mod kernel raid module present
Sensors:   System Temperatures: cpu: 35.0C mobo: 29.8C gpu: 65.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 205 Uptime: 3 min Memory: 1765.7/7953.1MB Client: Shell inxi: 1.8.4
Hallo Grafikfreunde. Habe leider total Probleme mit tearing (ich weiß erst seit kurzem dass das überhaupt so heißt). Unter Windows lief alles immer super. Jetzt nutze ich Linux Mint und habe seither Probleme mit der Darstellung beim Video-schaun.
Habe sowohl den freien Treiber als auch den proprietären Treiber ausprobiert, jeweils gleiches Ergebnis.
Kann mir jmd weiterhelfen, wie ich das in den Griff kriegen kann? LG
p.s. bei der Verwendung des offenen Treibers xserver-xorg-video-ati wird die Karte sehr laut bzw warm.
Hast du im Catalyst den Haken bei "Rissfreies Bild erzeugen"(oder so ähnlich)?
Zu hart. Habe es nun aktiviert und einen Neustart gemacht und es ist auf jeden Fall besser.
Vielen Dank.
