Hallo;
Erster Schlüssel:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Control Panel\PowerCfg]
"CurrentPowerPolicy"="4"
[HKEY_CURRENT_USER\Control Panel\PowerCfg\GlobalPowerPolicy]
"Policies"=hex:01,00,00,00,00,00,00,00,03,00,00,00,10,00,00,00,00,00,00,00,03,\
00,00,00,10,00,00,00,02,00,00,00,03,00,00,00,00,00,00,00,02,00,00,00,03,00,\
00,00,00,00,00,00,02,00,00,00,01,00,00,00,00,00,00,00,02,00,00,00,01,00,00,\
00,00,00,00,00,01,00,00,00,03,00,00,00,02,00,00,00,04,00,00,c0,01,00,00,00,\
04,00,00,00,01,00,00,00,0a,00,00,00,00,00,00,00,03,00,00,00,01,00,01,00,01,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,02,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,03,00,00,00,00,\
00,16,00,00,00
[HKEY_CURRENT_USER\Control Panel\PowerCfg\PowerPolicies]
[HKEY_CURRENT_USER\Control Panel\PowerCfg\PowerPolicies\0]
"Name"="Desktop"
"Description"="Dieses Schema eignet sich für die meisten Desktopcomputer, die ständig mit der Stromversorgung verbunden sind."
"Policies"=hex:01,00,00,00,00,00,00,00,01,00,00,00,00,00,00,00,02,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,2c,01,00,00,32,32,00,03,04,00,00,00,04,00,\
00,00,00,00,3a,77,2e,f2,07,00,b0,04,00,00,2c,01,00,00,00,00,00,00,58,02,00,\
00,01,01,64,50,64,64,92,7c
[HKEY_CURRENT_USER\Control Panel\PowerCfg\PowerPolicies\1]
"Name"="Tragbar/Laptop"
"Description"="Dieses Schema verlängert die Batterielebensdauer bei tragbaren Computern."
"Policies"=hex:01,00,00,00,02,00,00,00,01,00,00,00,00,00,00,00,02,00,00,00,01,\
00,00,00,00,00,00,00,b0,04,00,00,2c,01,00,00,32,32,03,03,04,00,00,00,04,00,\
00,00,00,00,3a,77,2e,f2,06,00,84,03,00,00,2c,01,00,00,08,07,00,00,2c,01,00,\
[HKEY_CURRENT_USER\Control Panel\PowerCfg\PowerPolicies\2]
"Name"="Präsentation"
"Description"="Dieses Schema lässt den Monitor für Präsentationen eingeschaltet."
00,00,00,00,00,00,00,00,00,00,00,84,03,00,00,32,32,03,02,04,00,00,00,04,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,2c,01,00,\
00,01,01,50,50,64,64,00,00
[HKEY_CURRENT_USER\Control Panel\PowerCfg\PowerPolicies\3]
"Name"="Dauerbetrieb"
"Description"="Dieses Schema lässt den Computer in eingeschaltetem Zustand, so dass auf diesen vom Netzwerk zugegriffen werden kann. Verwenden Sie dieses Schema, wenn Sie nicht über Hardware verfügen, die es erlaubt, den Computer vom Netzwerk aus einzuschalten."
"Policies"=hex:01,00,00,00,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,32,32,00,00,04,00,00,00,04,00,\
00,00,00,00,00,00,00,00,00,00,b0,04,00,00,84,03,00,00,00,00,00,00,08,07,00,\
00,00,01,64,64,64,64,00,00
[HKEY_CURRENT_USER\Control Panel\PowerCfg\PowerPolicies\4]
"Name"="Minimaler Energieverbrauch"
"Description"="Dieses Schema lässt den Computer an und optimiert ihn für hohe Leistung."
"Policies"=hex:01,00,00,00,02,00,00,00,01,00,00,00,00,00,00,00,02,00,00,00,00,\
00,00,00,00,00,00,00,10,0e,00,00,2c,01,00,00,32,32,03,03,04,00,00,00,04,00,\
00,00,00,00,3a,77,2e,f2,07,00,08,07,00,00,2c,01,00,00,00,00,00,00,84,03,00,\
00,00,01,64,64,64,64,92,7c
[HKEY_CURRENT_USER\Control Panel\PowerCfg\PowerPolicies\5]
"Name"="Minimale Batteriebelastung"
"Description"="Dieses Schema spart am meisten Energie."
"Policies"=hex:01,00,00,00,02,00,00,00,01,00,00,00,00,00,00,00,02,00,00,00,05,\
00,00,00,00,00,00,00,b0,04,00,00,78,00,00,00,32,32,03,02,04,00,00,00,04,00,\
00,00,00,00,00,00,00,00,00,00,84,03,00,00,3c,00,00,00,00,00,00,00,b4,00,00,\
00,01,01,64,32,64,64,00,00
Zweiter Schlüssel:
[HKEY_USERS\.DEFAULT\Control Panel\PowerCfg]
"CurrentPowerPolicy"="0"
[HKEY_USERS\.DEFAULT\Control Panel\PowerCfg\GlobalPowerPolicy]
00,00,00,00,00,01,00,00,00,03,00,00,00,03,00,00,00,00,00,00,c0,01,00,00,00,\
05,00,00,00,01,00,00,00,0a,00,00,00,00,00,00,00,03,00,00,00,01,00,00,00,01,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,16,00,00,00
[HKEY_USERS\.DEFAULT\Control Panel\PowerCfg\PowerPolicies]
[HKEY_USERS\.DEFAULT\Control Panel\PowerCfg\PowerPolicies\0]
"Name"="Desktop"
00,00,00,00,00,00,00,00,00,00,b0,04,00,00,2c,01,00,00,00,00,00,00,58,02,00,\
00,01,01,64,50,64,64,00,00
[HKEY_USERS\.DEFAULT\Control Panel\PowerCfg\PowerPolicies\1]
00,00,00,00,00,00,00,00,00,00,84,03,00,00,2c,01,00,00,08,07,00,00,2c,01,00,\
[HKEY_USERS\.DEFAULT\Control Panel\PowerCfg\PowerPolicies\2]
[HKEY_USERS\.DEFAULT\Control Panel\PowerCfg\PowerPolicies\3]
[HKEY_USERS\.DEFAULT\Control Panel\PowerCfg\PowerPolicies\4]
00,00,00,00,00,00,00,00,00,00,00,2c,01,00,00,32,32,03,03,04,00,00,00,04,00,\
00,00,00,00,00,00,00,00,00,00,84,03,00,00,2c,01,00,00,00,00,00,00,84,03,00,\
[HKEY_USERS\.DEFAULT\Control Panel\PowerCfg\PowerPolicies\5]
Einfach den Ersten Schlüssel kopieren und in eine neue txt-Datei einfügen.
Dann als "irgendeinname.reg" (egal, wie die heissen - nur ohne die " " ) abspeichern.
Dito mit dem Zweiten Schlüssel.
Du mußt nur 2 verschiedene Namen für die *.reg-Dateien vergeben.
